Projects Banger Speedster project
Discussion in 'Traditional Hot Rods' started by Brendan1959, Dec 21, 2021.
  1. Brendan1959
    Brendan1959
    Is the tail to long?
    Stogy, 1biggeorge, ClarkH and 2 others like this.
  2. Outback
    Outback
    from NE Vic, Oz
    Looks ok to me, but you really need yo get the whole profile to really know. They need to flow front to back.
    Stogy and ClarkH like this.
  3. Brendan1959
    Brendan1959
  4. Jeff34
    Jeff34
    Now create the shell with blue painters tape to get a good vision of the shape of the tail. You may find that you want to increase the radius on the upper corners as you move forward toward the ****pit, or that you want to change the shape in another way.
    Great progress!
    Stogy and brEad like this.
  5. Brendan1959
    Brendan1959
    Yes jeff I think you are right, 8B733A40-B764-4D0D-A63E-42EED2554B34.jpeg 2AE59DDA-2948-48B7-850A-086FA036FB89.jpeg it is a little square near the seats, I have made a start on the mock up.
  6. wheeldog57
    wheeldog57
    Yowza! That looks cool man!!
    Stogy likes this.
  7. Brendan1959
    Brendan1959
    What do you think of the lines/shape? I think its close. photo_2022-05-25_13-51-52.jpg photo_2022-05-25_13-51-57.jpg photo_2022-05-25_13-52-07.jpg
  8. Daniel Dudley
    Daniel Dudley
    I wonder how it would look if it dropped 1/2 or 3/4" at the first former behind the seat to fair out the line.
  9. flatheadgary
    flatheadgary
    from boron,ca
    it looks perfect! if it were mine, a little half circle as a door to get in. otherwise it is great. after all it's your vision not mine. i have several models of the 35c so i do like them. i have an old kit car book with several of the kits they used to make.
    Stogy likes this.
  10. Looking good, you’re not sticking out to far above it either.
    Stogy likes this.
  11. Brendan1959
    Brendan1959
    How does everyone feel about a steel frame with aluminium skin?
    Stogy and Oldtmtech like this.
  12. Squablow
    Squablow
    Looks good, aluminum skin over a steel frame sounds good to me. I like the proportions, doesn't look too big on it's own or too small with a person in it, which is important.
    Stogy likes this.
  13. More to the point, how do you feel about it?
    Stogy likes this.
  14. Brendan1959
    Brendan1959
    I am concerned about electrolysis with 2 dissimilar metals
    Stogy and Barrelnose pickup like this.
  15. I would think if the frame is painted then you shouldn’t have a problem.
    Stogy likes this.
  16. SR100
    SR100
    If the body can move, even just a slight amount compared to the framework, paint will only slow down the inevitable. You need to insulate between the two.
    A few years ago I was on a shop tour when the owner showed me a neat little OT aluminum-bodied Italian coupe. It was in after an engine fire. As I recall, the quote for the fire damage was $115k. He then showed me the damage to the bodywork from contact with the steel body framing. The Italians insulated the steel from the aluminum with fiber disks. After enough heat cycles, condensation rotted the fiber disks. After the paint on the framing rubbed off, the two metals came in contact. The quote for fixing the corrosion and dents from the contact was $80K. The kicker here is that insurance paid the $115k, but the corrosion damage was considered 'wear and tear' and thus not covered.
    The shop was going to insulate between the two with some kind of polymer.
  17. Brendan1959
    Brendan1959
    Back home for a week or so from our country place, managed to get my A roadster going for a run around the hills while there, it was back firing and the wolf whistle was pulsing. Stuck exhaust valve, managed to pop it down from the spark plug hole. Now the wolf whistle sounds normal, who would of thought that they could be used to diagnose problems.
    Back on the speedster, I got some steel tube delivered, I thought I might be able to bend the 50 x 25mm rhs with a plank and rope, no luck, so I went with the multi cuts on the inside. 10 at 200mm apart and 20 at 100mm apart at the tail end. Looks better than I thought it would. 60A52600-A55C-4A1A-9080-D85D8D6C6A5B.jpeg 5825BCCD-E69E-4C10-9B7A-E19D001BE87C.jpeg 3AD1EFE8-EB38-42A0-B4E6-9FCB374732BB.jpeg F5F3311F-D293-4C91-9FBF-2BF3084DBBEC.jpeg
  18. v8flat44
    v8flat44
    Well, I sure like it ..... bang on
    Stogy likes this.
  19. brEad
    brEad
    Looks good. Nice even arc without obvious flats!
    Stogy likes this.
  20. Brendan1959
    Brendan1959
    Stogy, 1biggeorge and Ziggster like this.
  21. Brendan1959
    Brendan1959
    Stogy, 1biggeorge, ccain and 6 others like this.
  22. Dave G in Gansevoort
    from Upstate NY
  23. Brendan1959
    Brendan1959
    She is in her sewing room doing what ever it is that is done in sewing rooms, so no!
    Stogy and 1biggeorge like this.
  24. Ziggster
    Ziggster
    Just found this thread. Looking good! Liking the older vehicles more and more. Just watched a short YT about Duncan Pittaway and his p***ion for prewar vehicles. Also saw another YT about NDR Bentley spe******ts. Really incredible people. Says folks are parking their Ferraris etc and purchasing vehicles like Bentleys that they can take anywhere and race. I think there is a resurgence in these vehicles that reflect simpler times which also give the driver a more immersive experience on the road.
  25. Brendan1959
    Brendan1959
    Sun frame some what done, seats and sliders bolted in.
    Stogy, 1biggeorge, ccain and 4 others like this.
  26. Jay A Driggars
    Jay A Driggars
    Stogy and Ziggster like this.
  27. Brendan1959
    Brendan1959
    Stogy likes this.
  28. Ziggster
    Ziggster
    Just in case you weren’t aware. There is a young guy (he just started university 2-3 yrs ago) who built a speedster from scratch including the frame rails. I haven’t checked in on his build in quite some time, but his build skills were incredible for a novice. You never know until you try.
    https://youtube.com/playlist?list=PLAOSTFKtoB9maO-cBAZQCy5vT10cain0i
    Stogy and Tow Truck Tom like this.
  29. Ziggster
    Ziggster
    I’ll also mention that I recently discovered another gifted builder/ fabricator on YT who has some incredible metal working skills. Of all the metal working vids I’ve watched, I find his the most informative and he shows step by step from template development to finished piece. He also admits he is a “novice” with the English wheel, and is still learning which is nice to see. On a rear filler panel for his personal Zephyr project, it took him 4-5 attempts to get the correct curvature and profile before he was satisfied with the fit.
    https://youtube.com/c/MakeItKustom
  30. brEad
    brEad
    I’ll 2nd @Ziggster in recommending both of those YouTube channels. Great resources for DIY builds!
    Stogy and Jet96 like this.
