Projects 1949 Buick Sedanette Mild Custom Build
Discussion in 'Traditional Customs' started by rockable, Mar 16, 2019.
  1. guthriesmith
    guthriesmith
    Wow! That was close! Thankful to hear a happy ending.
    Thor1 and loudbang like this.
  2. BJR
    BJR
    What's a hunert?
    123pugsy likes this.
  3. rockable
    rockable
    $100. LOL! ;)
    JalopyJimbo, BJR and loudbang like this.
  4. BJR
    BJR
    "Buy your pal a beer or a hunert". OK, but how do you buy a hunert? With a $100 bill? :D:p:D
  5. 40StudeDude
    40StudeDude
    That's the first thing I do to any of my cars-put in a master cut-off switch...not only is it a good idea, but saves the battery when the car sits for a long time...also a fusible link that can blow when you have something shorting out is the very first thing you should do while wiring...
    Glad to hear that there wasn't much damage...your guardian angel was watching over you...
    R-
  6. rockable
    rockable
    Actually, there was a master fuse that didn't blow. The guy from AA told me that should have happened. I said, "it didn't ".
  7. rockable
    rockable
    Taking the carefully ***embled and painstakingly detailed engine in my Buick apart. It wiped a lobe on the camshaft. The Buick Gods hate me.
    JalopyJimbo, LAROKE and chryslerfan55 like this.
  8. wstory
    wstory
    from So Calif
    Well ****!!!! Hate when that happens!
    rockable likes this.
  9. 1-SHOT
    1-SHOT
    from Denton
    There is a lot of cams going flat on initial start up. You are not the only one to have this happen. Had a very reputable engine builder build my peg one and had Gibbs brake in oil and a additive in it. While breaking it in on his dyno the cam went flat in the first run. He said this is not the first he had fail. It took 4 sets of lifters to make a good set. If the lifters don’t rotate when turning the motor over they are not ground correct on the bottom. After we dissembled the motor and cleaned it up new bearings we re***embled it and it ram perfect on the dyno.
    Thor1 and chryslerfan55 like this.
  10. oestek
    oestek
    from Midwest
    That's a beautiful car, and you've done some awesome work. Hate to hear about the setbacks, but we all get 'em along the way. You'll come out on top. Thanks for sharing the car build!
    Thor1 likes this.
  11. rockable
    rockable
    I wish someone at Crower would explain to me how 15 lifters look perfect and one failed. ****! 0505221502a.jpg 0505221502.jpg 0505221459.jpg
  12. milwscruffy
    milwscruffy
    You can be rest ***ured that they'll tell you it's something you did and there product is flawless. Went through this with Comp. Cams years ago and it's always a no win situation. Good luck on the tear down and hope the damage is minimal.
  13. 123pugsy
    123pugsy
    China cast iron. They throw anything into the melting pot.
  14. rockable
    rockable
    All 15 other lobes and lifters looked perfect. ****!
    Okie Pete and chryslerfan55 like this.
  15. i.rant
    i.rant
    Damn,that ****s big time. :mad:I feel for you.
    rockable and lothiandon1940 like this.
  16. BJR
    BJR
    So close and yet so far. That ****s big time Rock Able. I feel your pain. Nothing worse that putting your newly painted car together and then have to tear the engine apart.:(
    chryslerfan55, Thor1 and rockable like this.
  17. rockable
    rockable
    You got that right!
    chryslerfan55 and BJR like this.
  18. gatz
    gatz
    you just know they're gonna blame the lifter.
    chryslerfan55 and rockable like this.
  19. 1-SHOT
    1-SHOT
    from Denton
    Been their done that
  20. milwscruffy
    milwscruffy
    I'd be checking bearings !
  21. rockable
    rockable
    Well, the particles get washed directly into the pan...and they were there. The filter only had very small particles in it. The pump looks good and its inlet has a fine strainer. The cam bearings look ok, so I'm going to roll with it.
  22. 1-SHOT
    1-SHOT
    from Denton
    I would flush out all the oil gallery and check the pump for gaulding any where that small metal particles can hide.
  23. rockable
    rockable
    Since the oil pump is integral to the timing cover, I've already dis***embled and inspected it. No horrors there.
  24. FortMoe
    FortMoe
    First I've seen this thread. I moved a few years back and am still working on my new shop so I haven't been to the forum much. I have a 49 Roadmaster Sedanette. I used the same OT front as you but went with the Chevy long trailing arm rear suspension. Your build has given me a lot of great tips and ideas for mine. I love your inner fenders. I hope to get back started this fall on my build. Pic is an old one from my previous garage.
    Hope you get your fire issue straightened out soon! :eek:
  25. Deuce Daddy Don
    Deuce Daddy Don
  26. rockable
    rockable
    The Buick God's truly despise me. I have now failed 2 camshafts. This one failed in 10 minutes, and yes I was using proper lubricants, etc. It's not like i dont know what I'm doing. This is defective parts. This is expensive and a lot of work to repair. I'm calling TA Performance on Monday. Until then, I will be tearing it down once again. Sigh.
    JalopyJimbo and chryslerfan55 like this.
  27. vtwhead
    vtwhead
    Feel for ya Rockable. That is a bunch of **** and certainly none of us ever want to experience that. Good luck with your conversation with TA.
  28. BJR
    BJR
    I am so sorry you are going through all this bs, just to get a good running engine.
  29. SS327
    SS327
    Was it the same lobe or a different one?
    rockable and chryslerfan55 like this.
