rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. It may not look like much but this is two full days of work. The new pieces went together just fine until i tried to put the mag in. Everything had to come apart. The blocks that the fittings screwed into were removed. The fittings were welded on without the blocks. This gave me a half inch. The p***enger side of the ideler bracket was re shaped. The fittings on that side were re positioned. It was alot of fitting then machining and repeating it over and over. Once a decision to cut something is made its very hard to go back and start over like nothing happened. The five pounds of **** now fits in a one pound bag. If it was easy everyone would be doing it. 20220327_184858.jpg 20220327_175408.jpg 20220327_185031.jpg 20220327_184907.jpg 20220327_181034.jpg 20220327_184851.jpg
    bchctybob, mad mikey, OFT and 18 others like this.
  2. DDDenny
    That's a cool piece Brian, you can't buy that at Jegs!
    427 sleeper, racer-x and Nicholas Coe like this.
  3. enloe
    enloe
    from east , tn.
  4. I spent the whole weekend hooking things up. The radiator is in with new 16 lines. There were alot of possible routing options for the coolant lines. With a large selection of different angled fittings getting the right fit was possible. Now im just waiting on rods. Everything else is done. I ordered them last October. 20220403_182740.jpg 20220403_182815.jpg
    bchctybob, Stogy, mad mikey and 12 others like this.
  5. I have done all that i can do until the rods show up. Im moving on to the barn find 57 vette; the Chevelle floor and getting the trailer ready for this season. 20220410_185602.jpg
    Stogy, mad mikey, OFT and 7 others like this.
  6. The crew shirts showed up. If we are going to crash cars and have fires we should look good doing it. They match the car perfectly. My camera takes poor pictures. 20220411_094955.jpg 20220411_094930.jpg
    bchctybob, spot, Stogy and 15 others like this.
  7. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Brian;
    1st cl*** crew shirts.
    Marcus...
    mad mikey, Nicholas Coe and racer-x like this.
  8. 427 sleeper
    427 sleeper
    Now THAT'S Friggin' Cool!!! :cool::cool::cool:
  9. Finally the rods that i ordered last October have shown up. Like my rods in the past they are GRP rods. They are cut from aluminum plate. They are .100 longer than a stock hemi rod to move the piston up away from the cranks counter weights. I use a block with the cam in the stock location. All big show fuel cars move the cam up in the block. The reason for this is the exhaust lobe will hit the rod when the cam gets in the .700 lift range. To fix this the rods are ordered cam cut. The big end gets machined for cam clearance on one side of the rod. The big stroker cranks and big aluminum rods can create all kinds of clearance issues. I almost forgot to mention last years price was 1250.00 this year its 1450.00 dollars. The big hemi will get finished this weekend. You might hear the thunder. 20220505_205548.jpg 20220505_205603.jpg 20220505_205607.jpg 20220505_205612.jpg
  10. Johnboy34
    Johnboy34
    from Seattle,Wa
    Those look amazing!
  11. Its time to build a nitro hemi. The bottom end is done. The top end goes on tomorrow. Hopefully a fire up Tuesday. 20220507_110107.jpg 20220507_110237.jpg 20220507_225925.jpg 20220507_180310.jpg
    saltflats, Stogy, mad mikey and 2 others like this.
  12. I lowered the piston height .100 This dropped the compression from 7.5 to 6.8. This will hammer the bottom end less when i set the timing at 50 degrees of lead.
    I put a pin in the new piston and the old one to show the difference. The rings are in the same location. If i like this new set up i can put all of the old pistons in the lathe and cut them down to match. 20220506_204212.jpg
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I'd like to see a better picture of your piston/rod organizer/holder.
    Something you made?
  14. I will get you a pic. Its from wizzards warehouse. It holds the the rod ***embly and bearings. There are holes for the rod bolts and caps. Its plastic coated so it wont scratch the rods. A nice high quality piece.
    mad mikey and 427 sleeper like this.
  15. mad mikey
    mad mikey
    Brian. How do you think the lower compression will effect how she runs on gas? Or will it not really matter with your program? Everything looks fantastic for this season.
    427 sleeper likes this.
  16. It hit over a thousand horsepower at the tire on the dyno. I dont race it on the street so i dont think it will matter much. The engine on the gas side would really like more compression. Its a big trade off. If it isnt to my liking then i will put in the .034 head gaskets.
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That piston rack IS nice. Thanx!
  18. 57 Fargo
    57 Fargo
    @racer-x Brian, what do you figure it makes for horsepower at the wheels on Nitro?
  19. At nitro im thinking 2500-3000. Theres alot of variables on the nitro tune up. Most guys think more nitro equals more power. While that is true more gain can be achieved with more timing lead. The engine sounds great at 40. Now give the mag a twist and put 50 in it. It sounds completely different and bad ***. When the throttle is blipped it goes boom. Put 55 in it and it wants to jump off the car stands. Adding timing leans the engine out.
    I usually run between 75 and 80 percent nitro. Putting more in things get crazy. I dont have the time and money to do that very often.
    Any of these tuning adjustments for more power require a increase in fuel volume.
  20. 57 Fargo
    57 Fargo
    Thanks, I’m an engine guy, I’ve built lots but nothing even close to this caliber, I’m fascinated by it and truly appreciate you walking us through it.
    racer-x, 427 sleeper and mad mikey like this.
  21. Hemi Joel
    Hemi Joel
    from Minnesota
    Brian, I remember reading an article about the surfers nitro team. They said that they're secret to speed and reliability was to use 100% nitro but back off on the timing. What's your take on that?
  22. mad mikey
    mad mikey
    Good question Joel. I think it was Tom Jobe who said that.
  23. There are many ways to run nitro.
    Big nitro load big timing
    Big nitro load soft timing
    The nostalgia guys have pump limits so some run high compression. Keep in mind the surfers were using iron blocks and 50 year old technology. They didnt have the pumps or the mags we have today. As good as they were back then they only ran in the mid 8s. That would have won indy in 65.
    bchctybob, SS327, mad mikey and 3 others like this.
  24. The more lead and nitro you put in the hp will go up thats for sure. It also results in smashed upper bearing shells; cracked cranks; pinched ring lands; spark plug porcelain bits on the valve seats etc. Its a pay to play kind of thing. A man has to know his limits. Those limits include your time; money and fire suit.
  25. That’s one Bad Bad Boy,,,,!
    No matter what anyone thinks,,,,there is nothing like the Mighty Chrysler Hemi !
    Recognized and respected,,,,around the world !
    Tommy
  26. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Brian;
    If you get a few minutes sometime, would you mind explaining how advancing the timing leans the motor out? A nitro thing?
    TIA.
    Marcus...
  27. Budget36
    Budget36
    I’d say a 1000 HP on pump gas agrees with ya;)
