Customs Grinding Sound part throttle
Discussion in 'The Hokey Ass Message Board' started by "Whitey Ford" 62 Uni, May 9, 2022.
  1. "Whitey Ford" 62 Uni
    from Tampa, FL
    Ive got a 41 Plymouth with a 350/350 combo and a Chrysler rear end 8.25. I have been fighting a weird grinding sound for several months now which is usually at part throttle OR anything past 70 mph.
    So far i have rebuilt the entire rear end, new U joints, new wheel bearings etc. havent done anything with the transmission because this sound seems to come from the rear. ive had a buddy look into this rear end several times with different shims etc. he also states there are no marks in the rear end.
    Its really bad once i get up to 70. after the u joints its gotten better at lwoer speeds but still there. its only under part throttle at low speeds but once i get up to 70 it sounds like absolute hell. Ive read that maybe transmission? from previous owner that was rebuilt as well. anyway anyone have some past issues with a major grinding sound at around 70.
      146.9 KB
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Nice looking Plymouth.
    SECURELY place it on a lift or on blocks and engage the wheels. Get yourself an old radiator hose and do some investigating.
  3. vtwhead
    vtwhead
    U joints phased correctly? Check drive line angle?
    hidez57 and Almostdone like this.
  4. tommyd
    tommyd
    from South Indy
    And driveline noise can travel up and down the shaft making it harder to locate.
    egads likes this.
  5. pprather
    pprather
    Is the pinion angle correct, relative to angle of trans output shaft?
  6. Kevin Ardinger
    Kevin Ardinger
    Sounds like something may be grounded out to me. Exhaust hitting the frame or something, motor or trans mount. Something like that. Very seriously doubt it is the transmission.
    lostmind, spudshaft and jaracer like this.
  7. "Whitey Ford" 62 Uni
    from Tampa, FL
    yeah the driveline was redone and put on a lift to check pinion angle. we adjusted it which helped with the lower speeds but higher speeds still there. there are literally no rub marks anywhere. had several people ride with me putting their face and hands everywhere trying to figure this out.
    and its not a whirrling its a straight horrible grinding sound....only reason i thought maybe transmission was because everything ele has bene checked. not saying something wasnt missed but damn i have had that rear end checked a dozen times.
    pprather likes this.
  8. alchemy
    alchemy
    Tires rubbing wheelwells, rear bumper s****ing pavement, drag plaque dragging, exhaust hitting top of axle, parking brake cable rubbing driveshaft, flexplate rubbing smashed dust cover?
    tommyd likes this.
  9. ClayMart
    ClayMart
    Have you checked to make sure that the prop shaft slip-yoke isn't bottoming out in the transmission? Remember that this will have to be checked with the rear suspension compressed to ride height or maybe a bit lower. With the rear suspension extended (no load on reear axle) it will tend to add some end play at the slip-yoke and give you a false reading.
  10. Kevin Ardinger
    Kevin Ardinger
    That thing I awfully low.Can I ***ume it’s on air ride? If so, what if you raise and lower it when the problem comes in. Basically changing the pinion angle.
  11. "Whitey Ford" 62 Uni
    from Tampa, FL
    yeah so thats what i was thinking as well. which is why we adjusted the 4 link and made sure the angle was correct. it sounds exactly like a 'binding' noise...
  12. "Whitey Ford" 62 Uni
    from Tampa, FL
    yes its on bags. so it changed a little by raising it. not much. weird enough it did change more prior to ensuring the angle was correct.
  13. "Whitey Ford" 62 Uni
    from Tampa, FL
    none of that stuff on it but we did make sure the flexplate bolts were tight and not damaged. but thats the type o sound it makes as if the starter wasnt properly engaging the flexplate at high speeds.
  14. "Whitey Ford" 62 Uni
    from Tampa, FL
    the bottom is really clean under there and i canf find one rub mark....i wish it was.
  15. 37 caddy
    37 caddy
    from PEI Canada
    Check your ****** mount,i had a 69 charger that did that,drove me nuts to find it,replaced the rubber mount,car drove like a new one after that.Mount looked good,but collapsed when you drove it,the noise was coming up through the entire car,was metal on metal that sounded like the car was on steel rails?. harvey
    ClayMart, tommyd and Desoto291Hemi like this.
  16. "Whitey Ford" 62 Uni
    from Tampa, FL
    roger that. will do. it sounds like steel just smashing
  17. chop&drop
    chop&drop
    Had the same issue once and it was the dust cover touching up around the crank. Horrible grinding sound.
    '34 Ratrod likes this.
  18. "Whitey Ford" 62 Uni
    from Tampa, FL
    one more thing. when im going slow and barely touch the accelerator the noise comes back. but i mean like a 1/4" to 1/2" of pushing the throttle. very little pressing and it sounds like its grinding. thats the only reason i thought of the plantary gears in the transmission (TH350).
  19. "Whitey Ford" 62 Uni
    from Tampa, FL
    yeah....horrible grinding. was it visible to see where it was grinding?
  20. ClayMart
    ClayMart
    Am I correct in ***uming that this is a one piece prop shaft with no center support bearing?
    Adjusting the 4-link should take care of pinion angle and locating the axle properly thru it's range of travel. But even after that, any axle travel will change the effective distance between the back of the trans and the rear axle pinion flange. If the prop shaft is too long, when the rear suspension is under load it can push the slip yoke too deeply into the transmission and bottom out.
    With the suspension loaded, unbolt the prop shaft at the rear axle. Then push the shaft forward and note the amount of travel before it stops. With everything ***embled you probably should have 3/4"to 1" clearance in the slip yoke from its bottomed out position.
    Some under-car photos of the driveline and suspension might be helpful as well.
    Desoto291Hemi likes this.
  21. pprather
    pprather
    With the light throttle noise, when engine torques over a little the noise starts. In addition to the trans mount I'd take a close look at the left side motor mount for movement.
    Nailhead Jason likes this.
  22. junkman8888
    junkman8888
    My vote is for driveshaft hitting bottom of car, but without pictures, we're all just guessing.
    Rear axle shaft bearings. Have someone follow you at night, look for sparks flying under the car. Drive shaft a tad too long.
    Oh by the way, what are you referring to when you mentioned "shims in rear end"?
  23. "Whitey Ford" 62 Uni
    from Tampa, FL
    OK....3/4" to 1" going back into the ******. i know my buddy checked all of this but ill make sure he did this too. i know what your saying though cause i told him thats what it felt like but even under no load at 70 mph the noise starts again. at lower cruising speeds its almost gone. but once that rotation gets higher its bad.
  24. "Whitey Ford" 62 Uni
    from Tampa, FL
    hahah man i dont want to do anymore to this thing....finally got AC and everythign done.
    jimmy six likes this.
  25. "Whitey Ford" 62 Uni
    from Tampa, FL
    shims for the new gears and bearings in the rear end. im also thinking of the driveshaft too long. thats what it felt like but my buddy said it was good and he does this for a living.,..but we all know the story of 'buddy' stuff.
  26. "Whitey Ford" 62 Uni
    from Tampa, FL
    will do....had 4 people under there chcking and rechecking last week for basic stuff liek this but i will.
  27. Kevin Ardinger
    Kevin Ardinger
    Make sure that front u joint isn’t a a bad angle to where the yoke is hitting the driveshaft. Mine will do that if aired all the way down.
    tommyd likes this.
  28. Jmountainjr
    Jmountainjr
    If it was the trans, and I'm not sure it would be, the pan would be full of metal grindings. Not that much of a job to drop the pan and replace the filter and cross it off your list.
  29. "Whitey Ford" 62 Uni
    from Tampa, FL
    will do
  30. "Whitey Ford" 62 Uni
    from Tampa, FL
    i know. its the only thing i havent touched on this car....but per the original owner it was rebuilt...but we all been there before.
    tommyd likes this.
