Technical Copper-Nickel Brake Lines
Discussion in 'The Hokey Ass Message Board' started by jaw22w, Jan 14, 2022.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    Friggen furreners ..:p
  2. Beanscoot
    Beanscoot
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Or sumpin like dat..
  4. nochop
    nochop
    from norcal
    Where are you guys buying in-copp from? I’d like on shore stuff, thanks
  5. oldiron 440
    oldiron 440
    Sounds like a good idea but how would you know?
    2OLD2FAST and nochop like this.
  6. Dino 64
    Dino 64
    from Virginia
    Got mine from Advanced Auto Parts, big chain, probably from China but never had an issue with it
    nochop likes this.
  7. nochop
    nochop
    from norcal
    I wouldn’t, but maybe someone here does. Probably doesn’t matter much for fuel lines though. I think that on shore products may be more consistent quality than off shore stuff.
  8. oldiron 440
    oldiron 440
    I .ok at this way, Chinese stainless steel is junk so why would there copper blended tubing be any better?
    nochop and 72yenkonova like this.
  9. Dan Timberlake
    Dan Timberlake
    In the mid 70s ( and maybe before) Volvo used steel brake lines coated with some white stuff. I always figured it was enamel or something.
    After 100,000 miles in salty M***achusetts the lines would rust and fail where the fitting tore up the coating.
    Shortly thereafter Volvo went to cunifer etc. SAAB and Mercedes followed suit.
    Now it's use is the law "over there."
    I think single flares are actually illegal for brake lines per DOT.
    It definitively is easier for a single flare to thin the stretched/flared edge, and crack when being formed.
    Double flaring folds the material at the end of the tube back on itself without a thinning. at all.
    I think I can find the SAE Standard for that. SAE does not make laws, but in many industries their Standards must be followed
    https://rbisj.com/2020/11/do-brake-lines-need-to-be-double-flared/
    https://brakeexperts.com/do-brake-lines-need-to-be-double-flared/
    Fabulous50's likes this.
  10. Beanscoot
    Beanscoot
    The Fedhill company claims their tubing is thicker than their compe***ors' and better in every way, and imply that it is made in Britain:
    https://store.fedhillusa.com/
    The AGSCompany claims their NiCopp tubing is the cat's meow of tubing, better than the compe***ion, and the Chinese companies claim their cunifer is made to all the applicable standards.
    https://www.agscompany.com/products/nicopp-nickel-copper-brake-fuel-transmission-line-tubing-coil
    I guess if I were plumbing a whole car I'd spend a few hours on the internet trying to figure out what's really going on.
  11. nochop
    nochop
    from norcal
    Amazon sells Nicopp brand tubing
  12. Thomas K.
    Thomas K.
    Got mine from Inline Tube off of Ebay. I think they are located somewhere in the Detroit area. Have had no problems with there NiCo tubing.
    caseywheels and Fabulous50's like this.
  13. Fabulous50's
    Fabulous50's
    from Maine
    I've bought a lot of NiCop tubing from Inline Tubing on ebay as well.
    All made in the USA and has a DOT number printed on the tubing. They are a speed shop.
    caseywheels likes this.
  14. deathrowdave
    deathrowdave
    from NKy
    There is a big difference in copper plated and nicop be super sure what your purchasing . I will never use anything but nicop .
  15. David Gersic
    David Gersic
    from DeKalb, IL
    The Stop Shop on Amazon.
    nochop likes this.
  16. SuperWildcat
    SuperWildcat
    I bent all my brake lines from steel and used the Eastwood Flaring tool. The Nickel Copper line isn't as sharp looking. I hit the steel line some with Scotch Brite and then clear coat.
  17. Flathead Freddie
    Flathead Freddie
    Well I've seen a lot of copper shiny as new mainly on ships lots of the stuff and depends on moisture in the environment and how much 0000 steel wool you get . Just lay on a creeper every now and then and enjoy your handy work
  18. Flathead Freddie
    Flathead Freddie
    I'd seal your garage floor so emits less moisture at the car and directs it away from your car . Moisture travels up
  19. Bandit Billy
    Bandit Billy
    I apologize for breaking that HAMB rule (actually more of a guideline, technically). :cool:
    Here is a few of the 41 PU's lines in SS and SS gravel guard. I used these loops to allow the cab to be removed for painting without opening my bled brake system.
    I use the SS guard near the tires and high traffic spots on the frame. I have wondered what polished SS guard over polished Nicop would look like? Hmmm
    It doesn't stop any faster but that ni-copp stuff would clash with me chrome!
    Harder to bend, harder to flare, but hard as hell.
    And since the roadster gets upset when I fail to post a picture of her and only the truck....
    Bend it, flare it, polish it (why wouldn't you? :cool:) and install it.
    It is my preferred brake line material.
    I mean, it would have been easier for Michelangelo to sculpt his statuary from foam or plaster. I'm not saying my brake lines belong in the Louvre but I have been there and seen worser creations on display. :cool:
    winr, lake_harley and 31 B'ville like this.
  20. X38
    X38
    It wouldn't surprise me if you had chrome toilet paper.:rolleyes:
  21. Bandit Billy
    Bandit Billy
    Hmmm. Like Mylar, probably would back up my septic.
  22. 6sally6
    6sally6
    Funny.........Ni Cu is almost as shiny as stainless
    Cu Ni is almost as dull as copper
    6sally6
