Technical Anyone have a good solution for storing C-clamps and bar clamps?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, May 12, 2022.
  1. Roothawg
    Roothawg
    I have a ****load of C-clamps and bar clamps. Right now I am storing them on the edge of my table, but they are starting to be in the way. Hambers are some of the most resourceful folks on the planet, so I thought I would ask for your thoughts.
    I kinda though about building a rolling tree of sorts using a heavy base, like an old rotor etc. and then build a cross out of angle to give them something to clamp top. The only thing I worry about is the weight being up high.
    Second option was to add a piece off of the welding table to span the width of the table and you would hang them overhead. Pictures are always a plus.
    Thanks,
    Root
  2. Budget36
    Budget36
    If he legs on your bench are out at the ends, just weld in a pipe between the legs and hang them. If the legs are inset, make it like a “towel bar”.
    jaracer, Russco, brianf31 and 5 others like this.
  3. alchemy
    alchemy
    I have a cart (which never moves) that has a couple lower shelves. One for C clamps and one for Visegrips. They are both full, unorganized, and messy. But if I took the time to make bars to clamp the tools to it would be time taken away from car work. And then I would need to take time to adjust and install each tool when I returned it to its space.
    I'll be watching this thread for good solutions.
    Roothawg likes this.
  4. chopped
    chopped
    Mine are clamped to shelves on the shop wall. then I can still use the shelf space.
  5. alanp561
    alanp561
  6. jimmy six
    jimmy six
    I know I have them….don’t have any idea where they are now…
  7. manyolcars
    manyolcars
    and chain too. How to store long chains. I have no wall space and dont want to put chains in plastic buckets that burst.
  8. alanp561
    alanp561
    I can't take credit for this one but it's what I'd do on a smaller scale given the amount of tiedown and rigging material I have.[​IMG]
  9. manyolcars
    manyolcars
  10. Dave G in Gansevoort
    from Upstate NY
    image_78528.jpg Vicegrips are right at hand on the welding bench, well when I remember to put them back. I don't have many c clamps but it seems like it would work for that. Bar clamps are attached to a shelf near the drill press, mostly. There's a couple that hang randomly on the underside of shelf brackets.
    das858, jetnow1 and guthriesmith like this.
  11. Roothawg
    Roothawg
    See, you guys are always thinking. I was thinking I should clamp it. Never even thought about just hanging them over a bar. Genius.
  12. miker98038
    miker98038
    ratrodrodder, alanp561 and Roothawg like this.
  13. Roothawg
    Roothawg
    I may make a modified version of this. Have a couple of uprights welded to the table top, with a bar across. Easy and cheap.
  14. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Vice grips clamp to the side of my hydraulic press. C clams hang on the side of same. You guys have too many clamps, please send some :)
    alanp561, WalkerMD and brEad like this.
  15. BamaMav
    BamaMav
    from Berry, AL
    You guys are too neat. My C clamps are in a drawer in one of the tool boxes, the vise grips are in the drawer that holds all my other pliers. The two bar clamps I have are hanging off a Ford shorty header that’s hanging on the wall with a couple of nails. You want to use one, dig in the drawers until you find it.
  16. 210superair
    210superair
    from Michigan
    I have peg board on two walls of my garage with all manner of things hanging around, and one spot is for clamps.
  17. harpo1313
    harpo1313
    from wareham,ma
    They clamp nicely on 2x4s on the wall.
    alanp561, brEad, lango and 1 other person like this.
  18. HOTRODPRIMER
    HOTRODPRIMER
    I keep my "C" clamps in the bottom drawer of one of my roll around tool chest. HRP
    VANDENPLAS and Roothawg like this.
  19. Marcia
    Marcia
    triumph 1, vtx1800, jaracer and 16 others like this.
  20. Graham08
    Graham08
    I have a bar on either side of my welding table to hang mine on...
  21. Dave G in Gansevoort
    from Upstate NY
    Now that is a serious welding table! I'm jealous, mine is just a 2nd hand sheet of 3/8 diamond plate with that angle iron welded on one side. But it was free. The only cost was the casters a number of years ago. Even the vise was given to me.
  22. 41rodderz
    41rodderz
    from Oregon
    As far as chains go take a steel truck rim , cut a piece of flat plate cut round to set over the lug holes and bolt/weld the plate to the wheel. Get a piece of 2 1/2”/3” round pipe about 5/6 feet in length and weld that upright on the center of your round flat circle and brace accordingly. Take some flat stock and weld tabs 3 or 4 horizontal off the pipe about 6” down . Take another length of flat stock and form in a circle ( approximately 2 1/3 ft to three feet in diameter) and weld to your horizontal tabs. You end up with a 3 ft cir***ference to slide one end or both ends ( hooks) on the vertical band .
    Roothawg and alanp561 like this.
  23. cfmvw
    cfmvw
    IMG_20220512_163616714.jpg I made this one to also hold my spring clamps as seen on the left. I have a lot more clamps, but they are currently holding a project together while the glue dries.
    alanp561, das858, mgtstumpy and 2 others like this.
  24. 41rodderz
    41rodderz
    from Oregon
    this. EA83CE6A-8F9C-49BC-8800-464E647AD446.jpeg make a flat base with wheels to move around or just sitting flat on the floor .
    das858, Jokester, akoutlaw and 4 others like this.
  25. lostone
    lostone
    from kansas
    I just pick up cheap towel racks at garage sales, mount them to the wall and hang c clamps and vise grips from them.
    I could build brackets but hey I buy the towel racks for a buck a piece or so, cheaper than the materials and definitely cheaper on my time building some.
    alanp561, Tow Truck Tom and Roothawg like this.
  26. Budget36
    Budget36
    I keep my chains outside, because I use the outside more often;). This is about 2/3rds of mine hanging the d****s over angle iron. Others are in use or laying somewhere;)
  27. TA DAD
    TA DAD
    from NC
    I used a piece of 1/2 black pipe under the front of the bench. IMG_0409.JPG
  28. Bearing Burner
    Bearing Burner
    from W. MA
    In my ba*****t I clamp the bar clamos to the floor joyces over head and "C" to X braces between floor joyces.
    brEad, Roothawg and alanp561 like this.
  29. 37slantback
    37slantback
    My wife gave me half of an old wooden ladder. Although wasn't a thought out plan , I just started putting all my clamps on different rungs. It leans against the wall and I move it if it pisses me off.
  30. Rynothealbino
    Rynothealbino
    If you have wall space sink those gold construction screws into a stud and use the screw as a hanger. I only put 2 per screw in matched pairs for c clamps since they get heavy. You can even nest clamps within clamps if you get creative. Pretty cheap and effective.
