Technical 396 overhaul
Discussion in 'The Hokey Ass Message Board' started by squirrel, Dec 5, 2021.
  1. old.hot.rodder
    old.hot.rodder
    Sharp Truck
    Deuces, 427 sleeper and squirrel like this.
  2. Beanscoot
    Beanscoot
    The 396 rod marks look like little dents vs. tiny cracks to me, so not really worrisome. As for the MG rod... who cares?
    SS327 likes this.
  3. Deuces
    Deuces
    Those can be polished out....:cool:
  4. SR100
    SR100
    It is a lot of rod for 75ci (unless the engine isn't stock).
    OFT likes this.
  5. mickeyc
    mickeyc
    In 1968 I also had a job at a salvage yard. Found a discarded 327 chevy motor
    laying on the side of an abandoned mechanic shop. Brought the motor to the
    newly established Car Shop Incorporated facility here in Metairie La.
    They had hired no other than Gene Mooneyham from California to
    run the engine rebuilding shop. Mr. Mooneyham performed all the
    machine work on the 327 to include boring, cam bearings etc. When
    he asked about pistons to be fitted to the bore I told him I did have a new
    set I had purchased from a local drag racer. They were 11to1 ratio.
    He told me to bring them so he could adjust the fit in the cylinders.
    A short time later when I picked up the motor the short block was
    ***embled including the cam Mr. Mooneyham had selected for
    the motor. I panicked thinking how the heck was I going to pay
    for all this extra work that included crank prep and bearings as such!
    When I expressed my concern Mr. Mooneyham asked me to repeat
    the quote he had given me for the original work which included
    block prep only. The price was some 90 odd dollars. He said, so
    whats the problem? I thanked him profusely and took my motor
    home. Later I did install a set of cast iron Crane prepared fuely
    heads. They used to sell for $325.00. The motor with a
    2x4 corvette intake and a couple of A.F. B. carbs ran really
    well in my 55 sedan with a 4 speed and 4.11 gears. Not many
    guys believed I had an actual Gene Mooneyham prepared motor
    but I really did. Mr. Mooneyham was a real Gentleman and
    treated the local hot rodders well. Car Shop campaigned a first
    gen Camaro funny car for a few seasons out of the facility.
    There is a famous photo around showing the car standing
    literally straight up in the air in an ill fortuned starting line launch.
  6. Deuces
    Deuces
    Con rod on the left... On the right side beam.. About an inch and a half down from the red circle... I'd be worried about that little crack....o_O:confused:
    Take them in and have them magnafluxed.....
  7. 57 Fargo
    57 Fargo
    I’m pretty sure Jim has it covered….
    Blues4U, Deuces, milwscruffy and 2 others like this.
  8. enloe
    enloe
    from east , tn.
    cool another Squirrel thread :)
    loudbang and Deuces like this.
  9. ratrodrodder
    ratrodrodder
    from Boston
    Haven't had the thrill of a big block ride-along yet, but maybe some day. In the meantime, I'll have to live vicariously through the HAMB - thanks for taking us along, Jim!
    Thor1 and Deuces like this.
  10. Blues4U
    Blues4U
    from So Cal
    Those dents can be stress risers, which can result in a concentration of stress forces at that location leading to a failure. Those pictured are not bad, and in a low stress motor would probably not be a problem; but it wouldn't take a lot of work to remove them.
    https://mechanics.stackexchange.com/questions/18183/what-is-a-stress-riser
    Truckdoctor Andy and Thor1 like this.
  11. bchctybob
    bchctybob
    I had a ‘66 396 and a Muncie 4 spd in my ‘33 5w coupe back in ’68-69. It was a stock 325 hp but I installed an L88 cam and springs, a 360hp cast iron intake, and 780 Holley. It ran low 12s - high 11s with 3.55 gears and Indy tires. It seemed to eat valve springs until I switched to Isky springs. After many runs at Lions, it finally spun a rod bearing and got replaced with an LS6 from Gledhill Chevrolet. I’ve still got a runnable 375 horse 396 under my workbench. Love those big block Chevys.
    Looking forward to seeing this one revived.
    enloe, bobss396, loudbang and 5 others like this.
  12. squirrel
    back to work....
  13. blowby
    blowby
    from Nicasio Ca
    Me too. Like most of the kids I grew up with, Chevys were cheap and plentiful, so that's what we had. 283s, then 327s, and later 350s and even a 400, but when I got my first 396, slipped in a cam, headers and big Holley, that was the big leagues baby, my SBC buddies were beaten. Had 427s, 454s (currently in my Vette) but I'll always have a soft spot for those 396s.
    OFT, bchctybob, Blues4U and 4 others like this.
  14. bobss396
    bobss396
    I have the same engine on a stand in my garage. 325 HP, also went with an L88 solid cam when I had it in a stock car Nova. Even the built small blocks couldn't match the pull it had on the straights. I believe the stock CR was around 10 or 10.25:1. This one also spun a main bearing in the pits at Islip, noisy but the oil pressure was still at 60.
    bchctybob and Thor1 like this.
  15. squirrel
    After a few distractions, I'm back at work on it. I pulled the LS-7 454 out of the truck yesterday.
    Then I pulled the heads off, and the cam and lifters out. It's a hydraulic roller, and new stuff is hard to find these days, or real expensive, so I'm reusing it in the 396. The heads are the close chamber oval port heads I got in 1980 from Denny Wykoff, they had large valves installed and had been the subject of a magazine article that David Vizard wrote, but he never could find it to show me. The heads work well, and have a bit of nostalgic value to me.
    I cleaned up the block this morning, and started putting parts in it.
    I checked the bearing clearance on one main, just to make sure. The crank mic'd ok, and I trust the Clevite bearings, but it's good to make sure.
    When I put a rear seal in a Chevy, I offset it a bit, and also put Aviation gasket sealer between the cap and block.
    Double checking the timing marks. This chain set and ****on were in the 454.
    Now I need to put a stop in the back of the timing cover, for the ****on to contact.
  16. fresh hops
    fresh hops
    I have a couple of books from David Vizard, the guy knows his stuff!
  17. squirrel
    He used to hang out at Denny's shop, and at Tucson Dragway, when I was young. HP books was in Tucson.
  18. Good job Jim ,
    That ole 396 is gonna be very nice,,,,,,and I see the chain is a good D.I.D. model,,,,,good timing set .
    Very good pics,,,,,keep them coming,,,it should turn out great .
    Tommy
    Thor1 and squirrel like this.
  19. Budget36
    Budget36
    Hey Jim, you mentioned pulling the LS7, what did they come in? I know of the LS5 and LS6, but not the LS7.
    Thanks.
    Desoto291Hemi likes this.
  20. squirrel
    The LS-7 never came in anything. It was the baddest crate big block you could buy from Chevy, for about 20 years. 3965774 was the part number. Pretty good deal, mine cost $2700 in 1989. 4 bolt block, forged crank, forged 12:1 pistons, big rods, rect port open chamber iron heads, etc. Most of them got taken apart and different pistons and cam installed, like I did to mine.
    dearjose, AHotRod, Deuces and 4 others like this.
  21. squirrel
    thanks
    I welded a washer to the back of the timing cover, for the cam ****on to contact. Then put on the cover and damper.
    Checked the first rod bearing clearance, it's ok...
    so put the rest in, and the oil pump.
    I then installed the pan and painted the bottom of the engine some reddish orange color. Flipped it over, put in the lifters, and set the first head on.
    AHotRod, Deuces, Thor1 and 2 others like this.
  22. This motor was originally slated as a production option in the '70 performance cars. GM released a pre-production prototype LS7-powered Chevelle to Hot Rod magazine for a feature article in advance of offering it to the general public. Hot Rod blew it up in testing (pitched a rod out IIRC) and GM quickly canceled it for production due to the bad press (although that was never specifically stated). As they had already built a fair number of the motors, it became a over-the-counter item.
    Thor1 and Budget36 like this.
  23. SS327
    SS327
    Jim what brand timing chain is that? Looks a lot nicer than the cloys I have been using forever.
  24. squirrel
    Deuces and SS327 like this.
  25. Back in the old days,,,,,,Cloyes always used a D.I.D. chain,,,,,,they were the best in my book .
    I’ve torn down a few engines with them,,,…and the chain was still tight with no slack .
    Then,,,.,the bean counters got involved,,,,,and Cloyes chains became ****,,,,like everyone else’s .
    I never knew what the DID letters meant,,,,,I always ***umed it was a company logo,,,,either way,,,,they were tops in my book .
    I also remember using DID drive chains in off road bikes and Atvs,,,,,,top quality product .
    That’s my story,,,,, and I’m sticking to it ,,,,,,LoL .
    Oh yeah,
    I knew a guy back in the day that had a crate LS7,,,,brand new,,,,,,this was about 1985-86,,,,,,a truly bad piece of news .
    He put it in a real 70 Chevelle LS6 car,,,,,,he wanted to save the original engine for the future .
    Tommy
    Thor1, squirrel and Budget36 like this.
  26. 427 sleeper
    427 sleeper
    The 396 is lookin' good, but I'm curious, are you going to put the LS7 back to factory spec and build another Bad *** AWB car to put it in?
    Budget36 likes this.
  27. lippy
    lippy
    from Ks
    So the heads have the 1.88 exhausts? I use to run Boss 302 rockers on my 454 when you could run down to ford and buy them. Straightened the geometry right up. Lippy
  28. squirrel
    I doubt it. But I still don't know what I'll do with the engine. For now it'll sit on a dolly and wait for some attention. It was dropping oil pressure when hot, so it needs some attention inside.
    Thor1 and 427 sleeper like this.
  29. SS327
    SS327
    The last few cloyed sets I installed were so loose after a few thousand miles it pissed me off. In a few thousand miles cam retarded 4*-6*. That set looked great and still tight that’s why I wondered. Thanks.
    Thor1 and Desoto291Hemi like this.
  30. Truckedup
    Truckedup
    DID chain is manufactured in Japan...They make chains to a price but all grades are good quality
    Thor1, Desoto291Hemi and AHotRod like this.
