Technical V8-60 Smith Jiggler Heads
Discussion in 'Traditional Hot Rods' started by EmperorOfWestVirginia, May 13, 2022.
  1. Need some V8-60 Smith Jiggler help!!!
    I have tried and tried but I can’t figure out what the rocker arms in a Smith Jiggler OHV conversion came from. They appear to be modified from a m*** production valve train of some kind.
    Any help would be greatly appreciated. I have several sets of heads that I am trying to get back in running condition.
    14EC9B59-667E-4BB4-A76C-7A1E5DFCCB02.jpeg 5D7AA8BE-74AD-41B5-84E9-7BF80CF69878.jpeg 56D610F4-74AA-4972-94CD-8680A436999D.jpeg EACFDF47-6BBB-4E53-8D62-FE728C05B07C.jpeg C1C28CE7-C250-42B9-A822-12C77E4CF4B9.jpeg
  2. blowby
    blowby
    from Nicasio Ca
    chryslerfan55, Tman, flyin-t and 2 others like this.
  3. alchemy
    alchemy
    Talk about cornering the market on the obscure!
    Outback, tomkelly88, Carter and 2 others like this.
  4. 51504bat
    51504bat
    Can't help but that 60 is way cool
    EmperorOfWestVirginia likes this.
  5. alchemy
    alchemy
    Have you tried the Speedway Museum? A HAMBer named Jenn's dad used to be in charge of the exhibit restorations. He even gave us a quick behind the scenes tour to see the shelves of rare parts (it looked a lot like your shelves there). Search for Jenn and send her a PM.
  6. Thank you, I appreciate it. I’ll give it a shot!
  7. alchemy
    alchemy
    Note I corrected her name spelling. Jenn.
  8. BJR
    BJR
    If you are going to hoard stuff, it might as well be very cool stuff!:D
  9. RacerRoy3
    RacerRoy3
    Sometimes it is not so much hoarding as it is rescuing stuff that would otherwise end up in the trash. This is particularly true with garage and estate sales where people have no idea what they have. It can be a challenge to find someone that actually wants to use the stuff, because the level of interest can be very small.
  10. I wish I had rescued them from an estate sale they would have been cheaper.
    Instead they were rescued from the dusty shelves of long time collectors. I say rescued because they weren’t ever going to be rebuilt and used.
  11. foolthrottle
    foolthrottle
  12. Still trying to figure this one out…
  13. Torana68
    Torana68
    from Australia
    what OHV engines were around when first designed? looks a bit aircraftie. With a torrington bearing I don't think that's a production auto part, it could have been bushed once though. Take one into someone whos good with CNC and have them made from forged material. Try a local metalwork/machining page on facebook and ask for someone who loves doing this stuff and has the right gear. I'm having a rare part fixed by going this way , commercial would have been stupid expensive.
  14. nosnhojguy
    nosnhojguy
    We call them government jobs when we slip them in at work.
    Ericnova72, Unkl Ian and sdluck like this.
  15. miker98038
    miker98038
    It’s a long shot, but you might try posting over on the Ford Barn. They belong in the early v8 section, but I’d put them in the late v8 also. There’s a member there with a lot of aviation background. If those rockers were aircraft, there’s a long shot he might know something.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Same thoughts here.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Tman likes this.
  18. So damn cool
  19. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, EoWV;
    If you have the time, would you do top n bottom shots of the rocker? Some very rough dimensions would help, like, say; length, width(s), rocker-shaft dia incl ID of the bearing bore, lift ratio(s) on both sides. A useable replacement rocker might be around, esp if a little bit of machining can be done. My 1st thought was cutting some OT aftermarket rockers, although you will probably need longer pushrods w/different tips, etc.
    Marcus...
  20. 41rodderz
    41rodderz
    from Oregon
    ****! I don’t own them . But cool .
  21. alchemy
    alchemy
    That article said they had some difficulty with castings at first. And those rockers look rather crude. Maybe they were special cast for Smith's heads.
    I bet you could have some custom made on a CNC mill rather easy. If you are lucky, there is only one profile, not rights and lefts.
    Pretty sure I saw a HAMBer who milled his own rockers to rebuild an ancient overhead conversion. Kevin Pharis: https://www.jalopyjournal.com/forum/threads/home-made-valve-covers.1218618/page-2#post-13919734
  22. ronnieroadster
    ronnieroadster
    Seeing the needle bearing is interesting but I wonder if that was original. Considering how specialized this conversion is I would expect the rockers were designed for this application not an off the shelf item. Think in the ear when the conversion was made how many overhead valve engine's existed in the U.S.
    If it was me I would simply make them out of aluminum not very hard to do.
    Ronnieroadster
  23. Sidevalvesteve
    Sidevalvesteve
    from Tennessee
    They look cast. You could still mill them using CNC since you already have a good one.
    How about a picture of the combustion chamber? Like to see how the valve is sitting.
  24. Driver McWheelman
    Driver McWheelman
    You want to sell any? My grandfather ran a jiggler in San antoniotl
    chryslerfan55 and Outback like this.
  25. Outback
    Outback
    from NE Vic, Oz
  26. WRT
    WRT
    anothercarguy and rod1 like this.
  27. V8-m
    V8-m
    from Alaska
    Very nice conversion heads. I have one V8-60 laying around and it would be awesome with those heads.
    tractorguy likes this.
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    About 20 years ago I had Harlan Sharp build me a couple of sets of shaft mounted custom rocker arms for a Ford six head with a rare crossflow cylinder head. I visited their plant in Strongsville Ohio with drawings. They found an aluminum extrusion for one of their late model products that was close enough to modify to suit. You may try Harlan Sharp.
    https://harlandsharp.com/
  29. I second the post above - talk to Harlan Sharp - they make a lot of rockers for some of the "modern" banger overhead conversions. I'm sure they could make new aluminum rockers that would work well.
    Given the roller bearing, you might consider going to a pressurized oiling setup. I know the originals used grease, but if you wanted them to have the least number of issues (for the street), I would consider how best to oil them when talking to Harlan Sharp.
  30. BCMChassisCo
    BCMChassisCo
    Bill Jones a San Antonio resident, who was a past Indy Car Team racer and owner from the fifties was involved with the Jiggler-Smith engine in the 1990's. A close personal friend and former employer, Jack Chisenhall acquired a lot of Mr Jones Offy and midget parts collection when Mr Jones p***ed in 2017. You may also attempt to contact his son Bob Jones. Both these gentlemen may have the Technical information and or correct parts you may need John Joseph Moreno
