Technical Loudest Junkyard Horns I can find: Which?
Discussion in 'The Hokey Ass Message Board' started by MrCreosote, May 14, 2022.
  1. MrCreosote
    MrCreosote
    from USA
    Have really wimpy horns in my old car and want something really loud. Teeth shattering loud if possible.
    Not interested in aftermarket - I'm thinking boneyard all the way. (Back in the 60's I'd probably just take some Cadillac horns. Nowadays I have no clue.)
    alanp561 and Deuces like this.
  2. Budget36
    Budget36
    You want them to drop their cell phone and spill their Latte? ;)
    juan motime, Tman, 40two and 14 others like this.
  3. nrgwizard
    nrgwizard
    from Minn. uSA
    68 cad eldo were fairly loud. Sounded similar to a train.
    If loud is what you want, go to a semi-boneyard or repair shop. Will need a small air compressor & small air tank - but you better have hearing protection when you pull that trigger...
    You didn't mention size... :) .
    Marcus...
    dana barlow, VANDENPLAS and Deuces like this.
  4. 1989 Chevy Astro van. That's what I have on my '62 Chevy II. Loudest horns I've ever heard next to a semi^^^^^^
    Elcohaulic, Bob Lowry and VANDENPLAS like this.
  5. mrspeedyt
    mrspeedyt
    some Italian ****...
  6. cfmvw
    cfmvw
    Roadrunner horn is pretty loud, and it even has his picture on it.
    SS327 and Deuces like this.
  7. MrCreosote
    MrCreosote
    from USA
    I'm not going the compressed air route (I actually have an old air horn (might even be a twin - don't remember) and it was pretty bad***
    Found just one 89 Astro horns on car-parts.com (wonder what year range had the same horns...)
    That Road Runner horn: did they go Meep Meep ?
    I actually have a hotrod a-OOG-a horn with control cable but that is more of an "entertainment."
    Found this cool graphic showing FIAM horn db levels: Rock has the 125db new for about $15 + shipping. Need to see what the dealeo is on the FB, R and UB models. But I'm really looking for something that would mount where the OE horns were. NOTE: I'm going to look for those Studebaker horns - I think I have at least a set and would be a cool nostalgia sound I would enjoy.
  8. MrCreosote
    MrCreosote
    from USA
    LOL just discovered the 4-note Cadillac horn which is what I sort of remember. From the 90's so clearly available.
    juan motime, WB69, 40two and 5 others like this.
  9. Mr48chev
    The 4 note Caddy horns are actually 4 horns on a bracket with a relay, Usually tucked under the fender in front of the wheel well on rear wheel drive Caddys. I've got at least one set saved for my truck. More authoritive than loud though.
    I've got one of those after market horns that was advertised to be super loud that I was going to put on my wife's driver because she fussed about the weak horn.
  10. Dave Downs
    Dave Downs
    from S.E. Penna
    In the old days we’d use a 6 volt horn on 12 volts…..
  11. BJR
    BJR
    That's what I use is 6 volt horns on 12 volt. Find them at swap meets.
  12. What do you need a horn for?
    ekimneirbo and Deuces like this.
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Probably hard to source, but if you get hold of late 40s. early 50s Mopar ( "Sparton" ) you can create hysteria. Even running 6 volt, ( preferred, sweeter sound than 12 V ) you can jangle the peace and serenity of any dreamer. Also found a commanding note from '90s Caravans ( yes that would be a Dodge ). They have the sound that I would call 'Highway Horns'. If you're into sweet, my vote is any Oldsmobile.
  14. manyolcars
    manyolcars
    the 1997-2003 F150 horns sound loud
    Tman and 69thumper like this.
  15. lucas doolin
    lucas doolin
    I replaced the stock horns in my '56 Ford Victoria (12 V) with a pair of 6 V trumpets from a 40s Lincoln. They are LOUD and can't be ignored.
  16. Deuces
    Deuces
    o_O
    Truckdoctor Andy and VANDENPLAS like this.
  17. ffr1222k
    ffr1222k
    I used these on my El Camino. They are loud. I went through the Pull a Part using my electric drill battery testing horns.
    I wasn't popular that day at the yard....18 Volts made them real loud.
    ratrodrodder, Tman, Ford52PU and 6 others like this.
  18. rusty rocket
    rusty rocket
    That a good idea,You know what your buying that way.
    Ford52PU and seb fontana like this.
  19. indyjps
    indyjps
    Look up buck converters, you can step up 12V to 15 or 18V. Need to ensure proper amperage capacity.
    OE loud horns are the simplest solution, but if you wanna get LOUD, bump up the juice. Use a common horn that's easy to replace :D
    seb fontana likes this.
  20. oldolds
    oldolds
    The Riviera air horn you show above are loud. Harbor Freight sells a look alike that are loud as well. 6 volt on 12 volt is a good bet for loud. No matter what brand
  21. hepme
    hepme
    Right. In Texas everyone uses a gun so there's a huge supply of horns that were used once.
    Toms Dogs, Hnstray, 2Blue2 and 6 others like this.
  22. Lone Star Mopar
    Lone Star Mopar
    I prefer any 50's era 6 volt horns and run 12v to them. They are damn near as loud as those goofy air horns.
    Bob Lowry, seb fontana and 52HardTop like this.
  23. LOU WELLS
    LOU WELLS
    from IDAHO
  24. hrm2k
    hrm2k
    I had an aaaaoooga horn on my coupe. Much louder than my open exhaust
    -Brent-, desotot, Montana1 and 3 others like this.
  25. PhilA
    PhilA
    Pair of A B horns off any early to mid sixties Chevy. At a slight discord they sound louder than they are.
    They are also an octave lower than most modern horns but lack that acidic edge to the note (a more rounded sound like a trombone, compared to a cornet).
    Trick is to find a space on the car that amplifies the sound, if you can.
    Algoma56 likes this.
  26. i.rant
    i.rant
    Mr Creosote for the win;)
  27. Truckedup
    Truckedup
    Yeah, some of the Italian horns are loud enough to bend sheet metal. Fiamm brand? You can buy them new for reasonable money...
    Deuces likes this.
  28. MeanGene427
    MeanGene427
    from Napa
    I have an old high-pitch set of air horns off a 60 Reo mixer truck that are going on my duallie, pointed left to wake up the Kommifornia fast lane cloggers :eek:
    seb fontana and Deuces like this.
  29. MeanGene427
    MeanGene427
    from Napa
    They currently reside under my lathe, and have initiated several folks with an application of the air hose blow gun, and my compressor is set at 160- very effective :confused:
  30. 1971BB427
    1971BB427
    from Oregon
    When I was looking for horns for my '39 Chev coupe I hit the wrecking yards. I found a Crown Vic that had dual horns mounted on one bracket, and figured I could use one or both depending on where they fit. I had room for both, so mounted it that way. They definitely get people's attention, and I like that when it's needed.
