Technical Bondo test
Discussion in 'The Hokey Ass Message Board' started by Pats55, May 17, 2022.
  1. Pats55
    Pats55
    from NJ
    This is a 28-day salt fog test. I used the Bondo brand body filler on bare metal , over epoxy zinc phosphate primer , and the aluminum pigmented moisture cure urethane primer. The primer I used was Restoration Shop epoxy and the urethane primer is Mastercoat. Panel number one epoxy three coats over a miniscule amount of rust. Panel number Two urethane down first Bondo, urethane over it. Panel number 3, epoxy down first, filler epoxy over it three coats. Panel number four Bondo over bare metal epoxy over it . panel number 5 three coats of epoxy primer. Panel number 6 Master coat three coats.
  2. 41rodderz
    41rodderz
    from Oregon
    Cool tech test . Thanks.
  3. ccain
    ccain
    SCIENCE!!!
    Love it!
    '28phonebooth and anthony myrick like this.
  4. squirrel
    Makes me glad I live in AZ
  5. Based on the photos, it's hard to tell which performed the best...what is your conclusion seeing them first hand and knowing exactly what you started with?
  6. mrspeedyt
    mrspeedyt
    Dad used lead back in the day but when Bondo came out he embraced it and enjoyed working with it it far better...
  7. Blues4U
    Blues4U
    from So Cal
    #2 & #6 both appear to have suffered much less corrosion than the others
    slowmotion likes this.
  8. So they all rust? #2 does look the best...
  9. gimpyshotrods
    gimpyshotrods
    So this is Bondo brand filler?
    Tman likes this.
  10. slowmotion
    slowmotion
    Agree with Blues, 2&6 seem to have 'weathered' the uh, weather the best....o_O
  11. Pats55
    Pats55
    from NJ
    Sorry for the confusion this was going to be a video but I've got tired. Number one is the zinc phosphate epoxy three coats over a slight bit of flash rust. Not great. Number two Master coat down first another coat of Master coat over the Bondo. this one seemed to work pretty decent number three epoxy primer down first Bondo epoxy over it not too bad. Number 5 three coats of epoxy over 80 grit . Not great. Panel number 6, 3 coats mastercoat no deterioration or creepage along the edge
    anothercarguy likes this.
  12. Pats55
    Pats55
    from NJ
    YES
  13. 56don
    56don
    They all look pretty bad.......o_O
    Tman likes this.
  14. Mike VV
    Mike VV
    from SoCal
    Pat -
    Umm, still confusion...where's your explanation of #3 and #4 ?
    Mike
  15. Pats55
    Pats55
    from NJ
    Panel number 3 had two coats of epoxy primer, Bondo was applied over it followed by another coat of epoxy primer over the bando. Number four is Bondo applied over 80 grit panel and three coats of epoxy primer over it
    Panel number 5 is three coats of epoxy primer , no body filler over a q panel ground with 80 grit bare metal
  16. Blues4U
    Blues4U
    from So Cal
    Neither one looks great, but I would say #4 bondo first covered with 3 layers of epoxy came out better than #3 two layers of epoxy first then the bondo with a 3rd coat of epoxy over the bond. But the difference is slight.
  17. Pats55
    Pats55
    from NJ
    Panel number 4 had a large blister in the middle
    Number two and number six survived the test. These panels will not be rinsed off they will continue to rust even though they're not in the tank any longer . I will post a picture in a month. The moral of the story as soon as you can rinse the salt off, the better off you are.
    rusty valley likes this.
  18. HOTRODNORSKIE
    HOTRODNORSKIE
    Thanks for the test the bottom line is that you have to get ride of the rust first then seal it when done with the repair remember all plastic fill is poures. Repair,prime,seal,topcoat.
  19. overspray
    overspray
    I'm interested in which epoxy zinc phosphate primer you used (brand/part number).
  20. I know of nobody that uses actual Bondo brand fillers on any real project making this test moot.
    badshifter and HSF like this.
  21. ronzmtrwrx
    ronzmtrwrx
    What differing characteristics are there between brands of body filler? I’m not challenging your opinion, just asking. I would have thought the body filler would react about the same, no matter what brand. Is it better quality resins in the higher end brand fillers, making it not as porous? Fill me in. (No pun intended):D
  22. Russco
    Russco
    from Central IL
    All of my cars have been done basically like # 4 and seemed to have held up pretty well over the years. I do the metal work my buddy does the filler on bare metal then epoxy then slick sand spray polyester. But he always uses Evercoat Gold filler.
  23. Sandability, edge feathering, pinholes/air bubbles, how it takes primer. Lots of small variables. I prefer Evercoat products but have friends that really like Upol as well.
    overspray likes this.
  24. Pats55
    Pats55
    from NJ
    overspray and Tman like this.
  25. Pats55
    Pats55
    from NJ
    I use rage gold on my projects. The gallon of Bondo I used on my van. Here's the beauty of it once I put down My primer and then any kind of filler and my primer over it doesn't go anywhere . It's sealed Solvent proof , pin holes are filled in and no shrinkage. if anyone would like to send me a panel with your favorite combo I'd be happy to put it in my tank and test for you
    Russco likes this.
  26. K13
    K13
    We salt spray test all our fillers and they will last from a range of about 200 hours to over 500 hours so there can be a pretty marked difference in how they react.
  27. indyjps
    indyjps
    I use it to fill cracks in my garage floor. Lasts about 5 years o_O
  28. ronzmtrwrx
    ronzmtrwrx
    I have used about every flavor of Rage that has been made and liked them all fairly well. I switched to 3M for a stretch, trying the select, platinum plus, etc, but went back to Rage recently. My question was not about the physical characteristics that make us like/dislike different brands. I was asking what would make one brand of filler less/more susceptible to corrosion than another.
    Tman likes this.
  29. fordor41
    fordor41
    I used Bondo brand on our '41 in '95. never lifted or had any problems. only time it cracked was when we hit a deer and demolished the front end.
  30. overspray
    overspray
    https://images.tcpglobal.com/sds-sheets/CUS/KUS-EPOXY-PRIMER_TDS.pdf
    Well, this epoxy looks to be better than most. According to the tech sheet info it is lead and chromate free, it has a higher film build (1.5 mils per coat) and shorter cure time than some others (like PPG DP primer) and it isn't recommended for use in cold shop conditions. If you do another test, lay a water wet rag and a thinner wet rag on the cured primer and see if it absorbs either. I personally seldom use epoxy primer, if I do it's usually as a sealer/tie coat for automotive repair. I used to use some sikkens epoxy and Evercoat had a really good high build epoxy for a short time, but they are both gone. Thanks for posting the info and the test.
