So I'm spraying single stage paint, after stripping panel down to metal, I applied summit voc 2k primer, sanded. Then summit voc black sealer, cleaned good then applied paint, the whole panel had fisheyes on it, so I drained compressor, I do have a small water separator at the compressor and at gun, so I got a piece of galvanized at home depot and cleaned it with wax and grease remover and prep sol, sprayed primer on it and looks like I have some very small bumps when zoomed in on camera. Any ideas what I should try next?
sand those little bumps with some 1000 grit paper and see what they are, possible solvent pocket, possible your material wasn't stirred or shaken properly, try filtering your material into your gun
