Projects To a T- Trevor's T-on-A RPU
Discussion in 'Traditional Hot Rods' started by trevorsworth, May 7, 2022.
  1. RMONTY
    RMONTY
    What is the benefit of reversing the firewall? Im a rookie to these cars......
    Stogy likes this.
  2. trevorsworth
    trevorsworth
    On a Model A, reversing the firewall gives you a couple inches to clear a V8 without having to add a hump/tunnel. But not sure what the benefit would be on this T as everything already clears with the 4 banger. There is more space behind the engine than there was on the Model A.
    Outback, Stogy and RMONTY like this.
  3. RMONTY
    RMONTY
    Patch panels should be here Wednesday. Dude from Howells called me and said we ordered some coupe part and wanted to be sure we wanted roadster parts. He was a nice guy! Said he was shipping parts as soon as we hung up.
    I am going over to my friends house tomorrow to make the hammer forms for those rails that we need. I messed around with it for a few minutes earlier and called him, he had a better idea!
    Dannerr, Stogy, Budget36 and 4 others like this.
  4. Shadow Creek
    Shadow Creek
    Stogy likes this.
  5. RMONTY
    RMONTY
    Made it over to my friend's house today and was able to get some hammer forms cut out on his bandsaw and router table. This should help make reproducing the channel that the turtledeck side panels sits in, and is welded to, a piece of cake. I have always wanted to try the hammer form thing. I made 2 sets just in case the plywood doesn't hold up. 20220517_132549.jpg
    We cut 4 strips of plywood to the proper width and length. We used a piece of hardboard as the template. We traced the shape of the piece onto the hardboard, then cut that out on the band saw. Then we used a spindle sander to fine tune the template. Next we used two sided tape to stick the hardboard template to one of the strips of plywood, and then rough cut the plywood to the shape of the pattern on the band saw, to within 1/8". Then we stuck the hardboard template to the first strip of plywood, then ran that through the router table. From there, we used the first plywood hammer form as the template, and cut out the remaining three. Thanks to my friend Ben for the use of his woodworking knowledge and wood shop.
    I thought I would wait for Trevor to come over this weekend so we can both make one of these that we need. Trying out the hammer forming technique will be great learning experience for both of us!
    Dannerr, Stogy, Paul and 8 others like this.
  6. RMONTY
    RMONTY
    Delivery from Howells Sheet Metal today. Panels look presentable to me! Ordered them on Saturday, here today. Good service from them from my perspective. Ordered through online bay site of course!
    Dannerr, Stogy, Okie Pete and 4 others like this.
  7. trevorsworth
    trevorsworth
    I'm super excited to get those burned in Sunday! Gotta make sure I bring my hood this time.
    Dannerr, Stogy and Outback like this.
  8. 1-SHOT
    1-SHOT
    from Denton
    You are making good progress. Frank
    Stogy likes this.
  9. trevorsworth
    trevorsworth
    Today we got the turtle deck broken down to its cons***uent pieces.
    The driver side quarter is nice, and all the complex internal structural elements are intact. We will have to recreate the bottom channels as mentioned above (didn't get to it today) but everything else is very solid.
    Driver side is pretty nice... OK, see that lip? That fits inside a structural rib/rain gutter. When we removed the rivets holding the p***enger side quarter at the bottom, the whole quarter just fell off. That lip is completely rotted off on that quarter...
    At first we were thinking this whole panel was a write-off. It needs attention on all the edges and the inner fender is junk. But after probing it a bit we realized the compound curves are all intact and most of what needs to be replaced is just flat, smooth sheet metal. So we cut the rot back about 1/2" to good thick metal...
    Then we threw everything in Robin's citric acid vat.
    I'm planning to get back over there Wednesday... depending on the weather we're either sandblasting the rest of the car or starting on some welding.
    Couldn't resist a picture of all this old iron together.
    Stogy, Okie Pete, Squablow and 7 others like this.
  10. Rickybop
    Rickybop
    I see bubbles in the citric acid.
    It's working...
    Stogy likes this.
  11. sloppy jalopies
    sloppy jalopies
    sorry it took so long, found the '31 insert but it is a bottom... errrr.
    Stogy likes this.
  12. RMONTY
    RMONTY
    Did a little work tonight. This was my first attempt ever at hammer forming. It needs a little tune up along the edges but this will never be seen once the quarters are revived and made to fit. I cut these long until we can get a final measurement. 20220523_221354.jpg 20220523_221428.jpg
    Dannerr, Nailhead A-V8, Stogy and 7 others like this.
  13. micshotrodgarage
    micshotrodgarage
    from colorado
    Hi, I'm enjoying this build, I've got lots of the same stuff going on as you do! keep up the good works. Mike
    Stogy, trevorsworth and RMONTY like this.
  14. RMONTY
    RMONTY
    Did a little more tonight. Got the roached p***enger bucket side off. Trevor is going to wake up in the morning and **** himself when he sees I am tearing his car apart! 20220524_002439.jpg 20220524_002508.jpg 20220524_002500.jpg
    Dannerr, Stogy, Okie Pete and 11 others like this.
  15. trevorsworth
    trevorsworth
    Hahaha! Be careful with that, it’s an antique!
    Dannerr, Stogy, J.Ukrop and 3 others like this.
  16. Koz
    Koz
    Just as a little inspiration, here's one I recently built for Hacksaw Bill. No show winner but a good runner that handles well.
    Tim, treb11, OFT and 11 others like this.
  17. trevorsworth
    trevorsworth
    That looks perfect. I was just thinking about a louvered deck lid.
    Stogy likes this.
  18. RMONTY
    RMONTY
    @Koz Love the taillights and roll bar! Any build pictures?
    Stogy likes this.
  19. trevorsworth
    trevorsworth
    Need to remember to bring my tail lights tomorrow to see how they look..
    Stogy likes this.
  20. Koz
    Koz
    RMONTY. I believe Bill is going to put a build thread up. I have a a load of pics in the shop. You wouldn't believe what this one looked like 6 months ago.
    trevorsworth, We had one '26 and one '27 rear quarter. The rest iss just sheetmetal from the shop. Homemadehardtop57, (Jerry), punched the louvers for me.
  21. trevorsworth
    trevorsworth
    Having done the research, my concern is relocating the fill neck so I can still use the Model A cap. There are no old school radiator shops anywhere nearby that I could find… and I can’t solder that well. Wish I could because I think that would really work nicely.
    Stogy likes this.
  22. 1-SHOT
    1-SHOT
    from Denton
    I know it's out of the way but they are on Mocking Bird Ln. just west of Irving Blvd. and they do radiators for commercial equipment. They can fix anything or build anything br*** and copper so this type of repair is right up their alley. Not like the people who crisp plastic tans on aluminum cores. IMG_5426 2.jpg
    Dannerr, Stogy, Atwater Mike and 2 others like this.
  23. trevorsworth
    trevorsworth
    That’s only an hour from me! I didn’t see them when I was searching, I think they are just outside the radius I set.
    Stogy and Atwater Mike like this.
  24. 1-SHOT
    1-SHOT
    from Denton
    Just trying to help. Was building a 27 roadster on a Es*** frank when Uncle Sam grabbed me and left it with my boss and he sold it and gave me the $$$ when I got out. Anxious to see yours done. Frank
    Stogy and trevorsworth like this.
  25. RMONTY
    RMONTY
    Building the new bucket side is going to be challenging but I think we can come up with a reasonable facsimile. I'm thinking about flattening what is left of it and then tracing it out on either cardboard or maybe even poster board. My hopes are that we can bend the flanges and angles on the poster board and tweak the poster board as needed until we have the right fitment, and then transfer the pattern to metal and recreate the shape(s). Does that sound reasonable? I have a 3' break, an English wheel, shrinkers and stretchers, and a bead roller with several dies including a tipping die.
    Stogy likes this.
  26. Koz
    Koz
    This body was pretty much made with the tools you mentioned. No reason not to make that panel. Watching this thread to see the great outcome. Keep at it!
  27. MojoRacing
    MojoRacing
    That ****s man. It's just sitting on the shelf so if you do find someone that can work it out for just let me know and it's yours.
  28. Shadow Creek
    Shadow Creek
    @RMONTY if you look at this thread I linked earlier he uses a portion of a Chevy van hood to make the majority of that piece, just another option to consider
    Dannerr and Stogy like this.
  29. rjgideon
    rjgideon
    You guys are really after it! Great job!
    Stogy likes this.
  30. brEad
    brEad
    @Shadow Creek beat me to it. That is a great thread if you haven’t checked it out yet.
    Stogy likes this.
