Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. milwscruffy
    milwscruffy
    Trying to finish up the chassis inner structure. Just the trans. mount and a couple cross pieces left to go. The final engine is a 398 Blown, injected 1958 Chrysler Hemi so building things stout for the Vicky project. IMG_0222.JPG IMG_0223.JPG IMG_0224.JPG
    Texas John, TA DAD, mgtstumpy and 8 others like this.
  2. Almostdone
    Almostdone
    Thank you kind sir.
    John
  3. chevyfordman
    chevyfordman
    mgtstumpy, blowby, Blues4U and 8 others like this.
  4. vtwhead
    vtwhead
    sorry but my neck hurts today:rolleyes:
  5. TA DAD
    TA DAD
    from NC
    A few more details completed. I stopped by a friends shop and picked up a vent for the rear axle ( my friends have made this build happen ) I got that installed and also got the front turn signals hooked up. Now here is a nice rear ! A Dana 60 with Moser axles a spool and with 4:10 gears sitting on Chrysler 002/003 SS springs. Sliders on the rear with 2 degrees negative pinion angle. Bullet proof early SS/Pro Stock technology !
    My current rear wheels are 8 and 1/2 in. wide Fentons . I need some 10's or 12's and I am in the process of locating the pieces to band some steel wheels and put a pair together with some hoops. Then I can put some slicks on the Fentons.
    It's a great day to be alive ! IMG_0424.JPG IMG_0426.JPG IMG_0427.JPG IMG_0430.JPG
  6. RICH B
    RICH B
    Worked on installing the laminated dash knobs, drilled and tapped a couple for set screws, threaded another, and drilled the others so I can JB weld them in place. Need to wet sand a couple marks out and buff them again before installing for good.
    Started to smooth out the bumper guard lights; but my shoulder decided it wasn't ready for a DA yet (hey don't tell the doc).
    Tried getting the latches on my buddies trunk thing for his '33; but found out I didn't have a chance of drilling #36 holes in the stainless fasteners. Need to get some regular or aluminium pieces. Sure has been a headache so far. The rack I made came out ok; but I think Model 40's look better plain on the back. To bad someone needs to take so much with on road trips. IMG_20220521_144120.jpg IMG_20220521_134148.jpg IMG_20220521_150400.jpg IMG_20220521_151134.jpg
  7. topher5150
    topher5150
    Bought my wife carpet, padding and install for the basement... Maybe I'll be rewarded with car parts
  8. X-cpe
    X-cpe
    An unspoken cost of our hobby.
    topher5150 likes this.
  9. fastcar1953
    fastcar1953
    Tested the color on wife's Nova. She likes it. Aqua marine blue firemist. tcp enamel. 282292317_3048374122140553_6935807960437007039_n.jpg 282345441_1021284642114593_749972223324717103_n.jpg 283304940_685834819151435_9157986253772867854_n.jpg 1.jpg 2.jpg 3.jpg
  10. TA DAD
    TA DAD
    from NC
    I have spent some time installing a couple switches. One is a momentary used for a NAPA brake parking lock I will use as a line lock. Another mounted on the shifter handle is for the trans brake. All though I don't drive at night ( my vision is like the rest of me ! worn out ) I am working on the headlight wiring. I mounted the dimmer switch next to the seat so it can be hand operated. There is still a ways to go with this task.
    Also coming up with a plan to get the handbrake in working order. IMG_0437.JPG IMG_0439.JPG IMG_0433.JPG IMG_0434.JPG IMG_0435.JPG
    Lil32, milwscruffy, LAROKE and 2 others like this.
  11. Blues4U
    Blues4U
    from So Cal
    I'd like to hear more about the 2500 rpm stall converter. What rear end gears are you running? OD trans? How do you like the way it works?
  12. Bad Bob
    Bad Bob
    from O.C. Baby
    Well, yesterday, after stalling 3 times on the way home from our show, I figured out it was the carb, not anything electrical, that was my problem. So I pulled the Holley off and put an Edelbrock carb on my Coupe. The Holley had three broken vacuum plugs, so i'm sure that was the problem. Ran great this morning, on the way to work.
  13. TA DAD
    TA DAD
    from NC
    The handbrake is complete and working. final cost , zero . I had all the parts on hand. Even the piece to hook the cables in. It doesn't get any better than this ! IMG_0444.JPG IMG_0446.JPG
    Hamtown Al, LAROKE, mgtstumpy and 5 others like this.
  14. fastcar1953
    fastcar1953
    More pictures of color. These are old parts not used. 281403565_5476530309037877_4887785118044762960_n.jpg 282028503_5476433495714225_8322815618659536723_n.jpg 283583836_5476431882381053_2273887877175436364_n.jpg
    LAROKE, mgtstumpy, TA DAD and 3 others like this.
  15. mgtstumpy
    mgtstumpy
    My upholsterer just sent me photos of the front seat from my '46 Olds sedanette, retrimmed in OEM material. I can't wait to collect it and see the rear seat when it's done. Carpet, hoodlining, door trims etc are next! A far cry from the original battered interior.;) 280063008_5285047108205308_247343145480964106_n.jpg
  16. Marcia
    Marcia
    IMG_20220524_172358306.jpg Replaced the tail lights on my 33 Dodge. There was salt in them and you could see the water line on the lens. IMG_20220524_171558437_HDR.jpg
    Almostdone, TA DAD, hrm2k and 5 others like this.
  17. Closing in on****embly of my 351 Windsor. Had the machine work done late last year but didn't begin****embly until the garage warmed up this spring. Still need little odds and ends: Carb spacer, distributor rotor, cap, adapter, plug wires and oil filter. I've got a used water pump pulley coming that I bought online and some other doodads before I pour in oil, spin the oil pump and connect it to an empty AOD to start it up and run it in. It's bored .030, crank turned -.010, has Edelbrock 1.90-intake aluminum heads, Edelbrock Performer intake, a 600-cfm Holley, an Edelbrock RV cam, Comp Cam roller rockers and a passenger-side aluminum water pump. I got the carb ($100), stainless headers ($100), intake ($50) and water pump pulley ($30) on local lists or online, so bucks saved there. The machining, pistons, bearings, etc. were around $1,300, so still think it will be coming in less spendy than a crate motor. Rebuilding the AOD to take the power of this engine will empty the wallet for sure. This marks 48 years of progress. I've just got a trans rebuild, paint, glass, wiring, driveshaft, exhaust, mounting the gas tank, upholstery, etc. yet to do. At 73, still seems doable, but I'd really like to drive it someday, too. A guy's gotta dream, don't he? IMG_2221.JPG IMG_2458.JPG
  18. hrm2k
    hrm2k
    A week or so ago, I was able to acquire a Wieand WCD4 intake and carbs from our beloved mod, Mark Moriarity. Even though they came with some cute air cleaners, I already knew what I was looking for. I found my scoops at Lucky’s Speed Equipment. I ordered and they showed up today. This is for my 1917 rpu, 283, 5 speed, jag rear. 29A15B1E-3305-48E3-8689-0A76D234E681.jpeg
  19. Greg Rogers
    Greg Rogers
    simplestone, Marcia, 40two and 9 others like this.
  20. Poverty cap
    Poverty cap
    5620D4AC-39C4-468C-A3AC-832E1F27295F.jpeg 441716BA-0CB0-46ED-B1F7-A00D11FC79FC.jpeg I’ve been working on my Belair wagon, I painted it in 2006 and it’s in need of some touching up, I’m not sure yet how much I’m going to redo but the list of body and paint work keeps growing. The last few days I’m working on the left quarter around the gas door. The pocket the filler sits in is double walled and it’s rusted, I cut out the rust and made some pieces to weld in, after it’s welded up I’ll sandblast the area and epoxy primer it.
    TA DAD, Marcia, hrm2k and 6 others like this.
  21. milwscruffy
    milwscruffy
  22. jimmy six
    jimmy six
    Snuck off to a gathering this morning in Newport Beach. Usually pretty small but by the time I left is was packed with more showing up. OT’s there too. 57 T-bird beside me started as a absolute basket and was great rebuilt by a Vietnam Veteran. 1E81A816-C74E-4D7C-A05B-4AA6C7ECC962.jpeg
    David Gersic, TA DAD, 40two and 6 others like this.
  23. redzula
    redzula
    Finishing up my engine build. Hoping to start it soon.
    knucklenutz, 40two, LAROKE and 10 others like this.
  24. topher5150
    topher5150
    Cleaned out the shed today so I can actually use it. Was gonna do some more work but it was such a perfect lazy Sunday I ended up taking a long nap
  25. Almostdone
    Almostdone
    @Blues4U : The car has 31.5 inch tall rear tires, a 9-inch with 4.11s, and 700R4 (0.7 overdrive) - that puts me at about 2050 RPM at 65 mph. So far the torque converter has been an improvement. I don’t know much about the previous one, but is was likely a stock stall, so something like 1800? The new one was made by Dice Converters near Los Angeles. It really leaves the line hard now - much better than before.
    I’m working on a problem with the trans not locking up in 4th gear (which it never has). Hope to have that solved in the next week or so. Apart from ‘that’s how it’s supposed to work’, I need to get the lockup going to make the package work with the 2500 stall and my low RPM at highway speed, etc.
    John
    Blues4U and 26 T Ford RPU like this.
  26. Gambler 1962
    Gambler 1962
    David Gersic, Lil32, 40two and 9 others like this.
  27. jimmy six
    jimmy six
    Blues4U and buzz4041 like this.
  28. milwscruffy
    milwscruffy
    Took my wagon to it's first ever show, small local one and somehow managed to get best in show, was a nice surprise and relaxing day. Amazing how many people are now into long roofs. IMG_0279.JPG IMG_0282.JPG
  29. Just looked up Craig Chevrolet in Arvada, Colorado, now it’s a brewery and tasting room. Glad it’s got a great new life and not a mini-mall!
    TA DAD and milwscruffy like this.
  30. impala4speed
    impala4speed
    Congrats on Best of Show. An awesome longroof you've got!
    clem and milwscruffy like this.
