Technical Radiator location on 1933 ford frame
Discussion in 'Traditional Hot Rods' started by Omarsvette, May 26, 2022.
  1. Omarsvette
    Omarsvette
    from Arizona
    The crossmember to my 33 ford coupe frame is different that my model A. Just to verify the radiator locates on top of the spring channel right? Not the other odd “ear holes” Which are for what?
  2. alchemy
    alchemy
    In front of the crossmember. There are special tabs up front.
  3. gimpyshotrods
    gimpyshotrods
  4. Bandit Billy
    Bandit Billy
    It may not help a ton since my frame is custom built but this is where mine bolts up.
  5. gimpyshotrods
    gimpyshotrods
  6. Omarsvette
    Omarsvette
    from Arizona
    The tabs in front of the crossmember made sense. I have the same diagram I was confused about “fender stay mount”
  7. rusty valley
    rusty valley
    They bolt onto the cross member, not visible in the drawing. There are I believe 3 different versions of mounts, and a couple different cross members too I believe. A big thread on the barn about it a few years ago.
  8. hemihotrod66
    hemihotrod66
    Here is my 34 frame which has the stock radiator mounting points in front of the spring mount...The mounts to the rear of the spring is where the stock flathead was mounted Build picture 1.jpg
  9. gimpyshotrods
    gimpyshotrods
    Yeah, those holes are about where the radiator mounted on previous generations of Fords.
  10. Omarsvette
    Omarsvette
    from Arizona
    So what are the holes on top of the spring channel for?
  11. Omarsvette
    Omarsvette
    from Arizona
    CCA6EFAD-79A0-49E9-9931-D4F01B3F427D.jpeg This is the radiator mounting holes right?
  12. rusty valley
    rusty valley
    The top holes mount the fender support brackets that go thru the inner fenders. Yes, you circled the radiator holes
    hemihotrod66 likes this.
  13. jimvette59
    jimvette59
    The big holes are for motor mounts .
  14. Omarsvette
    Omarsvette
    from Arizona
    Thanks fellas
  15. Omarsvette
    Omarsvette
    from Arizona
    So I won’t use that hole since I’m going fenderless? I will use the hood and inner fenders.
  16. rusty valley
    rusty valley
    No, no need for that bracket on a manly fenderless car. Fenders are for sissys
    Omarsvette likes this.
  17. Omarsvette
    Omarsvette
    from Arizona
    I have a aftermarket aluminum radiator. How does the hood and grill attach to the radiator? And how does the hood attach to the cowl?
  18. Bandit Billy
    Bandit Billy
    The grille mounts to the radiator using 4 brackets, 2 per side. My 34 used these, the 33 is similar.
    The screw heads slip into the slots that hopefully your radiator came with like these on my radiator
    The hood attaches to the cowl using this bracket which I believe is the same 32-36, then you hood hinge bar slides over the bracket on the cowl and
    rusty valley and Omarsvette like this.
  19. Omarsvette
    Omarsvette
    from Arizona
    Awsome thank you.
  20. Omarsvette
    Omarsvette
    from Arizona
  21. Omarsvette
    Omarsvette
    from Arizona
    These are the holes you mentioned? Also note location of radiator, that’s correct?
  22. hemihotrod66
    hemihotrod66
    Algoma56 and rusty valley like this.
  23. rusty valley
    rusty valley
    Well, NICE model 40 you have there for sure, but think of the money you save by not trying to find 4 good fenders,...that would buy a lot of beer
