Technical trans cooler under floor, 32 Ford roadster?
Discussion in 'The Hokey Ass Message Board' started by SDS, May 28, 2022.
  1. SDS
    SDS
    If I don't run the trans cooler lines through the radiator, anybody have a suggestion on a specific transmission cooler for under the floor?
    Do I need an electric fan on it?
    Thanks
  2. partssaloon
    partssaloon
    been running my 32 with it on the floor board for 10 years with no problem. I used a larger style waffle cooler and don't tow anything. (700R4)
  3. harpo1313
    harpo1313
    from wareham,ma
    Make a sm scoop to guide the air through it .
  4. deathrowdave
    deathrowdave
    from NKy
    Mine is under the floor also . If you think lots of air doesn’t move around it , hold your hand out the window at 40 mph
  5. TA DAD
    TA DAD
    from NC
    I just installed a Perma-cool brand and was very happy with the USA made quality.
  6. BJR
    BJR
    Unless you are doing brake starts or pulling a trailer your transmission doesn't need much of a cooler. The ones in the radiator from the factory are mostly for heating up the ATF when it's below zero in the winter.
  7. Flathead Dave
    Flathead Dave
    from So. Cal.
    Just make sure the cooler is a dual p***.
  8. HOTRODPRIMER
    HOTRODPRIMER
    I've used them in the past, I try to keep them close to the frame where there is good air flow. HRP
  9. old.hot.rodder
    old.hot.rodder
    Mine has been on 30 plus years with a turbo 400. Has a very nice scoop intake on the p***enger side.
    hotrodA likes this.
  10. pprather
    pprather
    I had one in my Model A. Just a flat, generic double p*** mounted horizontally on the trans cross member.
    40k miles with C4 trans.
    100k miles with 700R4.
    Never even thought twice about it during my 27 year ownership.
  11. Blues4U
    Blues4U
    from So Cal
  12. krylon32
    krylon32
    from Nebraska
    On my deuces with automatic trans I use a B&M cooler along the frame rail and a Derale cooling pan. Never had any problems. I once had a deuce roadster with a 400 turbo and all I did was loop the line without a cooler. Drove it a long way with no problems, maybe I was just lucky?
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I put one under an o/t van. Something to think about, nothing to compare it to, but I positioned the fins fore to aft.
  14. flatheadpete
    flatheadpete
    from Burton, MI
    I use a power steering cooler from a late model Hyundai under the floor of my Shoebox Ford. It works well and doesn't take up much space at all.
  15. jackandeuces
    jackandeuces
    Something to think about ..A B&M style cooler mounted on the frame rail is probably a 100 +degrees cooler than a small cooler, in bottom tank of radiator that is already 200 degrees ...
  16. Correct. In fact my ****** guy said that for a light hot rod all you need to do is get the fluid out of the ******. My T had 80" of line looped along the frame, that all. The only time the ****** got hot was in a burnout exhibition at the Full Throttle Saloon. I got a little carried away and did about a 3" burnout on my cheater slicks. Needed a few cool evening miles to cool the ol girl down.
  17. TA DAD
    TA DAD
    from NC
    The trans fluid is like oil, you don't want it to cold.
  18. 2935ford
    2935ford
    Mine is at the bottom of the rad......seems to work just fine with my 700r4!
  19. Blues4U
    Blues4U
    from So Cal
    I wonder how many who are posting that their cooler works just fine actually have a trans oil temp gauge and know what the temp of the oil is; and where the sensor is located....
    Just Gary and SEAAIRE354 like this.
  20. TA DAD
    TA DAD
    from NC
    I know mines hot, with a 4200 stall convertor in it.
    Blues4U likes this.
  21. TA DAD
    TA DAD
    from NC
    Just random info// My son came across the country in a 99 2500 big block Suburban pulling a trailer with a total weight of 16k lbs and the trans never got over 250. That was a 4L80E with the factory external cooler and the sending unit in the pan.
    Blues4U likes this.
  22. old.hot.rodder
    old.hot.rodder
    I have a pic of mine on in my album. old pic at that.
    hotrodA likes this.
  23. Doublepumper
    Doublepumper
    from WA-OR, USA
  24. 41 GMC K-18
    41 GMC K-18
    On my 46 IHC KB-5 truck, the original radiator wasn't manufactured to accept modern day cooling lines for the TH-400 transmission. So I mounted the cooler down low under the radiator to get good airflow, I also encased it in a hardware cloth type of bubble cage, to deflect any rocks or road debris, it worked great.
    Tman likes this.
  25. Hotrodderman
    Hotrodderman
    I have a B&M cooler mounted under the floor behind transmission with a small scoop to direct air to it. I has not caused me a problem for 20 + years.
    41 GMC K-18 and Tman like this.
  26. 1971BB427
    1971BB427
    from Oregon
    Any cooler, mounted almost anyplace out of the engine bay will give better cooling than what you get running through the tiny cooler built into radiators. And it doesn't need a fan at all.
    I have two hotrods with trans coolers, both Hayden brand, and both laying flat horizontally under the cars. One is just a couple years old, but the other is 11 yrs. old, and doing great. I've always used external trans coolers for automatics, and always laying flat, with no fan.
  27. BamaMav
    BamaMav
    from Berry, AL
    I mounted mine under the p***enger side floor. I made a set of brackets to mount it at an angle, rear lower than the front. I figured that would help the air flow through it instead of just over it. It's still hidden by the frame rail from the side.
    X38, 41 GMC K-18 and Tman like this.
  28. DDDenny
    A stone guard should be considered.
    41 GMC K-18 likes this.
  29. SDS
    SDS
    Thanks!
    I ordered an 18"...you think that's adequate for a TH350 w/factory V8 convertor?
