Hot Rods DENNIS FRINGS 29-- GRAND NATIONAL Roadster show bound.
Discussion in 'The Hokey Ass Message Board' started by Frames, May 28, 2022.
  1. Frames
    Frames
    2022-05-23 22.22.12-3.jpg 2022-05-28 11.14.52-1.jpg 2022-05-28 11.14.52-2.jpg 2022-05-28 11.14.52-3.jpg SEPTEMBER  11 2013 002.jpg img503.jpg After the 29 setting still for about 5 years I am starting on the doors. I am installing the L shaped lips that the aluminum skins will wrap around. Many hours are required fitting the L shaped lips for a perfect outer skin fit. The front L's will be inset 1/8" at the front coach reveal and perfectly flush with the quarter panel at the rear. I used an .063" feeler gauge at the rear. That is the thickness the skins will be. Damon Detmer will be doing the skins. He has thousands of hours more experiance than me. The second last picture is a 28 I built [ 2" added to the top of the body. ] with the D D installed skins. The doors fit the body perfect and the door gaps are perfect also. PS: My hood sides will require sanding on the ends to make room for primer and paint. Also note. No visable fasteners.
  2. 26hotrod
    26hotrod
    from landis n c
    No fasteners on the hood sides!!? You must share that secret with us, please?........
  3. Frames
    Frames
  4. If not for self promotion and your ONE cheerleader....................................
    HEMI32, seabeecmc, Budget36 and 5 others like this.
  5. Frames
    Frames
    A bracket welded to the cowl. A bracket welded to the nose. Bolts go in the hood side flange. Hood side flange at the bottom, bolts go in to the frame. A slight concave shape to the front and rear of the hood sides holds the hood side tight to the nose and cowl.
  6. Frames
    Frames
    Also the belly pan which has a 1 " radius on the bottom has no fasteners showing. Don't tell anyone. It's the frame.
    catdad49 and Hamtown Al like this.
  7. Frames
    Frames
  8. Frames
    Frames
    It's been a long time since I purchased the 1- 800 door hinges. As I recall the hinge boxes protruded quite a bit into the ****pit. What's up with that? 2022-05-29 09.16.46-1.jpg 2022-05-29 09.16.46-2.jpg After reworking this is what I ended up with. With about a 1/8" gap the doors will still open fine.
  9. 26hotrod
    26hotrod
    from landis n c
    Thanks for the info Dennis. You are a gentleman hot rodder............
    Hamtown Al likes this.
  10. Frames
    Frames
    It does not say no fasteners on the hood sides.
  11. Frames
    Frames
    I said No VISABLE fasteners. The grille I made also has no VISABLE fasteners.
    chryslerfan55 and big duece like this.
  12. 26hotrod
    26hotrod
    from landis n c
    ^^^oh visable!!! You know you are dealing with a n old man here...........
  13. Frames
    Frames
    No visable fasteners on the grille either. Check the fit. * Hidden shock mounts and headlight mounts. 2022-07-03 10.56.16-2.jpg
    chryslerfan55 and Dean Lowe like this.
  14. Frames
    Frames
  15. pprather
    pprather
    No 'visible' fasteners.
    Just Gary likes this.
  16. X38
    X38
    My roadster wheels have no visable fasteners. Trick, but secret.
    chryslerfan55 and Tman like this.
  17. Frames
    Frames
    Trick, but secret. Ah shucks now I can't get to sleep thinking about your innovative wheels.
  18. Frames
    Frames
    I used a 265 S B C engine and the later 153 tooth flywheel. I built a shallow circle track type oil pan to get the engine down low. 2003-12-31 23.00.00-20.jpg 2003-12-31 23.00.00-25.jpg The smallest production flywheel that I know of. I drilled the block to use a late mini starter. Starter works perfect. You have to look close but I made the spark plug wire looms. The flange between the upper firewall panel and the lower panel faces rearward not forward into the engine compartment like a stock Model A.
  19. Frames
    Frames
    bttt
    y'sguy likes this.
  20. Frames
    Frames
    bttt
    y'sguy likes this.
  21. y'sguy
    y'sguy
    from Tulsa, OK
    I'm not sure I've ever commented on your work, but I've always been impressed with itand your knowledge base. I have to admit thought I was originally ****ed in by your y-block track rod.
  22. 26hotrod
    26hotrod
    from landis n c
    Thanks for the update. I am coming down to your shop one day and agrivate you. I'll bring my coupe........
  23. Frames
    Frames
    BTTT. I added 2 comments. Just trying to keep MY car alive.
  24. The37Kid
    The37Kid
    Good luck with the build and Grand National show. There is something special about this car, it cough my eye early on, stance is perfect.
    Bob
  25. Frames
    Frames
    I often said the first thing a money bags owner will do is have the Hilborn converted to E F I. When the rod shop owner picked up the car he asked " Will a 4 barrel carb fit under the hood?" I guess the buyer can't afford the E F I conversion.
  26. Frames
    Frames
