Hot Rods Another Fuel Regulator question
Discussion in 'The Hokey Ass Message Board' started by nochop, May 31, 2022.
  1. nochop
    nochop
    from norcal
    Setting up my Carter 4070 BD pump I called Carter Tech. I’m running 94 tri power on a 324 olds. My question originally was to ask if I needed a by p*** loop and ask about if the pump would automatically shut when the carbs had no demand. Told him how I planned to run a regulator to 4lbs as suggested by my builder. Carter tech. rep advised against using a fuel regulator as the 4070 is internally regulated. Toss the regulator or do what my builder suggested? I’ll call my builder to check in. Thanks all, I’ll put on some popcorn
  2. nochop
    nochop
    from norcal
    BTW the regulator is a Holly item.
  3. ekimneirbo
    ekimneirbo
    from Brooks Ky
    It isn't going to hurt anything to have the regulator in place, then you can see if the internal regulator is doing its job, and you have a backup if it fails. Just buy from a reputable vendor so you don't get a counterfeit one......aka........cheaper price.
  4. nochop
    nochop
    from norcal
    Thanks. I bought the regulator from Holley.
  5. frozenh2o
    frozenh2o
    from L.A.
    The second regulator will behave better if it has a higher input pressure than your desired output. If you can adjust the internal pump regulator to say 6 psi, then have your Holley drop it to 4 psi you will have a nice setup.
    ekimneirbo likes this.
  6. nochop
    nochop
    from norcal
    I’m not sure if the pump is adjustable
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I think you said that backwards. Have the external (Holley) moderate the flow to say 6 or so lbs and then the internal regulator will receive a more consistant supply to moderate further. The Holley can provide a return line to the tank so the pump is always flowing and keeping fuel cool.:)
    nochop likes this.
