Hot Rods Homogenized ‘28 roadster build
Discussion in 'The Hokey Ass Message Board' started by Anderson, Oct 24, 2021.
  1. Fitnessguy
    Fitnessguy
    Great build so far brother and love how much you're doing your own fab work. Whatever we can build we build with new parts being overpriced and most times junk! Cudos on the intake fab. something about a milling machine just gets my juices flowin!! Keep pounding away. Like the 57 sittin in the shop as well. Halfway through a full build on my 56.
    Anderson likes this.
  2. Jack Az
    Jack Az
    Dude
    You have some serious skill and tools very nice
  3. A Boner
    A Boner
    Hairpins and a tube axle…a little scary to me!
    Ned Ludd and anothercarguy like this.
  4. Anderson
    Anderson
    don’t be skurt
  5. Anderson
    Anderson
    Just for kicks, here’s the p***enger tire a good 10” off the ground with no signs of suspension bind. Between the flexibility of the hairpins with tie rod ends out back and the thin but forged bat wings on the axle, I think this is about the best case scenario for what you’re not “supposed” to do.
  6. Big mike 1968
    Big mike 1968
    That intake is really well done.
  7. Big mike 1968
    Big mike 1968
    Fab work is awesome, great rod.
  8. E.C.
    E.C.
    from Tx
    Looks good to me.
    Tman and Anderson like this.
  9. Love your build. But, if I look at your test, it appears the frame twist is acting as your suspension. The actual suspension seems rigid (the axle to frame distance on each side appears to remain parallel, as you would expect if it was on flat ground...might be camera angle trickery). Your right side shock doesn't appear to have compressed at all. But I'm only offering up my observation.
    oliver westlund and Ned Ludd like this.
  10. Anderson
    Anderson
    the shock mounts are not attached to the frame at all, just hanging off the ends of the shock.
    The front rails need to be C-notched for the spring still, so the spring is bottoming out on the p***enger side…but the fact remains that the drivers side tire remains on the ground. I’m probably an idiot but don’t think that makes a huge difference. I will replicate the test after the C-notching later on and see how it goes.
    And I also wouldn’t call it frame twist, but maybe ch***is articulation. I think a lot of folks worried about the tube axle being so rigid don’t take into account that the whole frame and body are also pivoting on the rear axle. The “math” is based on the entire frame staying perfectly level when the car has to go over a big bump. But the entire rear pivots around the top of the spring just like a factory Ford would have done. It’s a ‘28 roadster without sway bars, on narrow bias ply tires, body roll is very much expected. If you have something on coil overs out back then it’s a different story, but for this ch***is it all works just fine.
  11. 1-SHOT
    1-SHOT
    from Denton
    Any Progress lately?
  12. Anderson
    Anderson
    Currently on hold and completely dis***embled while I use the garage to put together a new daily driver…but will be back together in a couple months.
  13. 1-SHOT
    1-SHOT
    from Denton
    Is it a HAMB friendly ride?
  14. Anderson
    Anderson
    Not for long!
  15. KKrod
    KKrod
    Nice E.C.
  16. 1-SHOT
    1-SHOT
    from Denton
    Nice I love that body style. I have a 80 SS ElCamino factory 4speed with 3.08 gear and a 410 SBC the one before that I had a 64 Red ElCamino. Looks like you and I have similar taste.
  17. 32fenderless
    32fenderless
    You have a thing for elco’s? Think I followed a build on another site that had the rear shortened behind the wheels on a 66 or 7.
    Deadbird, Dan Hay and Anderson like this.
  18. Anderson
    Anderson
    Yup. My first car was a ‘64 El Camino. That ‘66 was a lot of fun, sold it when I moved down to Austin. This new one is going to be a little bit like that one, but untouched externally. Enough O/T talk though before Mark shuts the thread down :)
    famdoc3, Rolleiflex, Tim and 2 others like this.
  19. Junior Stock
    Junior Stock
    I see you gave up on the M&H’s.
  20. Dan Hay
    Dan Hay
    Not to completely derail this thread, but since they're both A bodies, what about a 64 Olds-camino? Nevermind hahaha.. carry on.
    Bill Fonzarelli and 1-SHOT like this.
  21. 26hotrod
    26hotrod
    from landis n c
    My 26T coupe is set up very similar to what you are doing. Pete Eastwood narrowed 32 frame, Superbell axle, 4 bar suspension 350-stroker(383)/350 with 8inch rear end, and dual master cylinder. Trust me, you are going to enjoy this ride!! Keep on keeping on..........
  22. 1-SHOT
    1-SHOT
    from Denton
    GTO ElCamino
  23. Anderson
    Anderson
    negatory!
    Dan Hay likes this.
  24. dln1949
    dln1949
    The new tan slab sided pick up looks to be a daily driver now. Lets stay on target and get the roadster done. I have all those pieces on a shelf in my shop (except deuce frame), it's out back. Not sure if I can get it down and work on it now so am really enjoying your (exceptionally) basic build. *****en work from the start.
  25. Anderson
    Anderson
    yeah, backordered forever and every time I called it was two months longer. I didn’t want to just keep waiting so pulled the trigger on the towel city slicks and am pretty happy.
    Tman likes this.
  26. Anderson
    Anderson
    The “tan pickup” needs a lot of work, and it’s getting it. I’ve spoiled myself with a late model tuck for the last 5 years but it has been REALLY hard to hang onto it that long. I usually get a new daily once a year on average because I get bored. This latest effort is to have the El Camino I have always wanted, which will provide the utility I will always need, with the comfort and convenience I have become accustomed to.
    So I will target that is a short period of time, then such and such will work itself out and I’ll be back on the roadster in no time…and with a new found method of how to afford putting a car together without compromise. This is an experiment that will have really long legs into my hot rod builds.
    Tman likes this.
  27. A Boner
    A Boner
    Guess you have to jack it up and down 3” about 25,000 times!
  28. Tim
    Tim
    from KCMO
    @A ***** i would ***ume the forged bat wings would put up with a lot more than a welded set up?
    I’m also trying to imagine where you could get a an old ford to compress the front suspension 3” on a regular b***es.
    brEad likes this.
  29. Runnin shine
    Runnin shine
    Wow! I’m sorry if this is arrogant but that bent portion of steel to go from bottom and top of the axle looks to be more than half as thick as I would expect using my Hillbilligy CAD program(my noggin). @A *****.
    El Camino
    “ the front is like a car, the back is like truck, the front is where I drive, the back is where I… aaaaaaah, El Camino, EL, EL, Camino, El Camino, El, El, Camino”
    Tim likes this.
  30. Anderson
    Anderson
    I’m only going to do it 24,999 times
