Tech: Using Oxalic acid to remove rust
Discussion in 'The Hokey Ass Message Board' started by fiat128, Mar 6, 2008.
  1. CutawayAl
    CutawayAl
    from MI
    VERY agressive on aluminum and zinc. I have used it on corroded aluminium. I wouldn't use it on something precision, like a carb, for anything more than a very brief exposure at most.
  2. Leevon
    Leevon
    from Nixa, MO
    Fixed it, got lazy and hot-linked from another forum I posted the pic on...should be good now.
  3. Looks great!
  4. oj
    oj
    Has anybody welded the metal after cleaning? It could be a boon, i tig weld and a piece of rusty metal that has a tear or crack is hell to weldup because i can't clean inside the crack/tear, maybe i could apply some of that acid to clean out the rust and then weld.
  5. Commodoreswab
    Commodoreswab
    from West TN
    Great info, I wonder how it would work on some of the stuff we dig up. Typically we end up soaking in mauratic till the coral is removed and we can drop in the tanks to start removing the salt. Im dealing with early 1700's shipwreck pieces that have been under salt and sand for roughly 300 years.
  6. atomickustom
    atomickustom
    Thank you, that is EXACTLY what I needed to know! You just saved a carb from certain destruction.
  7. mrspeedyt
    mrspeedyt
    thanks for the tips!!:)
  8. I have a couple of front brake drum/spindles in a plastic tote filled with water and 12 oz. tub of wood bleach (got it at ACE hardware), been in there almost 24 hours, and it's still kinda pretty rusty, but there's a layer of gunk at the bottom, and white foamy stuff clinging to everything. I dumped a gallon of boiling water in on top to speed things up.... we'll see
  9. [​IMG]
    The spindles... 7 of the nuts came off with an impact no problem, kingpins took a little beating, but they came out too.
    The water probably made the stuck brake shoes worse, but a quick once over with a wire brush... and it looked good... Keep in mind this car sat in a swamp for 35 years, the i-beam was rusted clean through, and all but 3 of the lug nuts had to be torched off before it went into the goo. The cap came off with my fingers, the rod ends came out with no more than the usual effort, the kingpin retaining bolt on one came out with an impact (the other nut/stop was just flakey rust), and the cotterpins looked like they were brand new.
  10. stationWAGONS
    stationWAGONS
    from Vegas
    Oxalic acid won't hurt original paint or chrome. too good to be true.
    Available straight in granules - on West Marine's Website.
    $10 bucks or so for a bottle that'll go a long way.
  11. zomb1e
    zomb1e
    WOW! worked heaps better then the mol*** process!! thanks mister!
  12. CutawayAl
    CutawayAl
    from MI
    General rule..... the more skulls and crossbones there are on a product's label, the better it works.
  13. Atif Naser
    Atif Naser
    okay....some before and after pics...the only thin that really needed scrubbing was the rims...and that was with a SOFT toothbrush
      52.6 KB
      57.4 KB
      43 KB
      46.9 KB
      51 KB
      27.9 KB
      37.8 KB
      31.9 KB
      41 KB
      29.2 KB
  14. Jakesrocks
    Jakesrocks
    Several times folks asked about neutralizing oxalic acid. After cleaning the rust off of your parts, soak them in plain clean water for a couple hours. Common household baking soda will neutralize acid very quickly. Be sure to neutralize the acid after cleaning your parts. Any active acid left in cracks or seams will continue to eat away at the metal. It will eventually eat right through clean steel.
    The yellow color mentioned is the iron oxide which has been removed from the metal. It should wash right off, or a little rubbing with steel wool or Scotchbrite will remove it.
    I've seen green color in the solution mentioned. I'd suspect that some of the parts being cleaned had some copper or br*** with them. Possibly copper plating prior to chrome or zinc plating.
    As for health hazards. Don't breath the fumes. Don't let the dog drink from your bucket of acid. Don't let the kids wash their hands in it. Just use common sense as with all corrosive materials.
    If you like Rhubarb pie, you're eating a small amount of oxalic acid. Strong concentrations are found in the leaves, and considerably lesser amounts in the stalks.
  15. PushnFords
    PushnFords
    I have a 40 gallon tub of oxalic acid I've been using for about a year on a lot of parts. It isn't working as well now and I'm getting a lot more yellow stuff on the parts when I remove it. Has anyone tried dumping in more acid into a previously used solution or do I just need to neutralize it and start with a fresh batch? With 40 gallons I'd like to refresh it if possible....
  16. Jakesrocks
    Jakesrocks
    I'd neutralize it and start a new batch. Adding more oxalic isn't going to get rid of the yellow residue.
  17. PushnFords
    PushnFords
    I need to mix a new batch of OA and don't remember what mix ratio I used last time. After searching it seems most people recommend 1-2 heaping Tbsp per gallon of water. So:
    1 Tbsp leveled oxalic acid = 10.5 grams per: http://www.chymist.com/M***-volume equivalents.pdf
    1 gal of water = 8.34 lb = 3782.96 grams
    So
    1 leveled Tbsp acid per 1 gal water would be: 10.5g/3782.96g = .278%
    2 leveled Tbsp acid per 1 gal water would be: 21g/3782.96g = .555%
    I'm using a dip tank with 40lbs of water in it. So according to my calculations using the figures I found for leveled tables****s I'd need 1.85lbs of oxalic acid. BUT...all of the posts I found recommend a heaping tables**** (not exactly an exact science) so 1.85lbs wouldn't quite be enough. If I shoot from the hip and go with 4lbs of acid per 40 gallons of water I think I'd be ok. Anyone mixed up a big batch to know how close I'm at? Shipping is high so I'd like to get enough the first order. I think I used a LOT more acid than that in the first batch so if I can dilute it and it would still work I could save a few bucks.
  18. 38Chevy454
    38Chevy454
    Good source for oxalic acid is Amazon. Just type in oxalic acid and you get lots of hits for whatever quan***y you want. I bought 10 lbs for cheap, it is great for cleaning out a rusty cooling system. In addition to some of the examples shown earlier in this thread.
  19. PushnFords
    PushnFords
    The last batch I bought was from Van ****'s taxidermy...I ordered baking soda at the same to neutralize it. I'll compare prices once I figure out how much to order.
  20. OIF1
    OIF1
    from Reno, NV
    I know I'm totally resurrecting an ancient thread, but I couldn't resist posting some pictures of some bumper brackets I needed to clean up today. I love the information resources on here and really appreciate the sheer amount of knowledge everyone p***es on in their posts. I've been using the info from this thread for the past 7 or 8 months and it's been a wallet saver for sure. Now instead of looking at a part for my 37 sedan and saying "nah, I'll p*** on that cause it's too rusty," I'm like "hell yes I'll take that!" Now if only you guys could find a way to soak stainless trim pieces to remove dents and dings! Really though, I appreciate the great job you all have done to help each other out on here and p*** that priceless knowledge on.
    Here some pics to show how great oxalic acid works (as if you needed anymore convincing): conveniently for this post, they didn't fit in the bucket all the way so you can see the same piece of metal as its own before/after.
    ImageUploadedByH.A.M.B.1470632516.329660.jpg ImageUploadedByH.A.M.B.1470632568.703094.jpg ImageUploadedByH.A.M.B.1470632698.268486.jpg ImageUploadedByH.A.M.B.1470632708.356835.jpg
  21. indyjps
    indyjps
    Just ordered wood bleach from amazon. I'll be giving it a try.
    My father has used it before to strip anodizing from stainless trim at higher concentrations. IM if you want details I can find out.
  22. Time for a bump. A great topic.
  23. GizmoJoe
    GizmoJoe
    Been a few years.. wow. A blast from the past.
    I hope you all are well. Even the mouthy ones. KIDDING! :)
    Good old Spamazon made it easy to get the stuff here.
    It works well enough for what I use it for.
    I have too much to do and am very slow moving so I still prefer mol***es (which is slow like me) since it's not as nasty on parts.
    After I mixed up a batch of the oxaclic acid a few years ago, I put a rim in it. I had done some welding (MIG) on that rim before dipping it.
    I had yet another health issue and the rim was left in the mix for over a week.
    When I finally got back to it, the rim itself looked ok but the weld was all but gone. It had oodles of tiny holes in it.
    I ground off the remaining weld and rewelded it. Rim seems fine.
    I've used reverse electrolysis, mol***es, vinegar, oxalic acid and phosphoric acid. They each have their pros and cons. But if I have a part that is important or "tender" in any way I pay up and buy something EavoRust or Rust 911 or whatever. Those generally don't attack things like br***, rubber, plastic, etc so they seem to be the safest for those parts.
    Tman likes this.
  24. It would be nice to have a master thread with all of the rust removal methods. Maybe some late night I will start one linking all these threads together in one place?
  25. GizmoJoe
    GizmoJoe
    That certainly would help folks.
    If I can ever get some decent health for a reasonable period of time I'm hoping to do some ewetoob videos of the methods. But I'm not betting any money on that.
    Tman likes this.
  26. scotts52
    scotts52
    oliver westlund likes this.
  27. oliver westlund
    oliver westlund
    Im sold, im gonna try it on that 55 grill
    scotts52 likes this.
  28. scotts52
    scotts52
    I believe I read that evapo rust is just oxalic acid that's already been mixed with water.
