Hot Rods Over heating.
Discussion in 'The Hokey Ass Message Board' started by Country Joe, May 28, 2022.
  1. Country Joe
    Country Joe
    I'll check that however, I think....not positive, that I have a reverse flow pump. Waiting for confirmation...
    mad mikey likes this.
  2. Mr48chev
    Counter clockwise rotation pump. That one is for a Serpentine belt. stndrdRevStrPmp_LI.jpg Water-Pump-Rotation.jpg
  3. Country Joe
    Country Joe
    Great news! Thanks for your help, Mr48.
    And thanks to everyone that offered advice. Tomorrow I'll get the right pump and take a test drive. I will report back with results . I work till 5 during the week...it might take day or three.
    210superair, mad mikey and Mr48chev like this.
  4. mad mikey
    mad mikey
    Cool Joe. I think you will have this problem licked.
    210superair and Country Joe like this.
  5. Country Joe
    Country Joe
    Thanks, neighbor!
    210superair and mad mikey like this.
  6. mad mikey
    mad mikey
    You got it brother. The reverse pump issue has happened to many. Keep us posted.:)
    Country Joe likes this.
  7. sdluck
    sdluck
    You said the intake had 4 bolts that is usually a vortec which has serpentine belt so it would have a rev pump
  8. Country Joe
    Country Joe
    Ok, just got this waterpump from NAPA. I asked for a waterpump for a 1977 monte , thinking they used v belts . I opened it up before installing and I think this is reverse flow also. Does this look like reverse flow? image000000 (16).jpg
  9. Mr48chev
    Sure looks that way.
  10. Rramjet1
    Rramjet1
    I found I had a reverse rotation pump on a 400 Sbc in a previously owned 32. It never overheated but wanted to run warm. Funny thing is the car was built in 2003 and I got it around 2018. It had been that way since built even painted the same color as the engine. My Avatar car was getting hot Monday and I found it was over a gallon low on water. No obvious bad leaks but I hadn’t checked the level since I got it a couple of years ago and it spent 6 months in AZ this year if that means anything.
  11. Country Joe
    Country Joe
  12. Budget36
    Budget36
    I have a water pump somewhere off an ‘89 IROC that ran with a single serpentine belt. I don’t think I tossed it, should be able to come across it and pop the cover and post a pic for you.
  13. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    FIRST problem a CHEVY in a Ford--- go on Ebay get a 3-4 row aluminum radiator with their shroud and fan
    and have the fan as a PULLER and a good fan temperature control set-up
    then you will enjoy your ride
    warbird1 and 36cab like this.
  14. blvdbill
    blvdbill
    change that radiator...
    firstinsteele likes this.
  15. That new pump looks to be what is referred to as a "straight vane" pump in post #62 ("solution" note section) because the 'vanes' intersect the center of the shaft. That's what I think I see but I don't know much about pumps or what you have for sure.
  16. lippy
    lippy
    from Ks
    If that pump is a straight vane, it will work either direction. Lippy
    Desoto291Hemi likes this.
  17. Budget36
    Budget36
    image.jpg Here’s a factory ‘89 IROC WP, for reference. @Country Joe
  18. Greg Rogers
    Greg Rogers
    I'm still learning about whether it is worth suggesting things....
    Blues4U and firstinsteele like this.
  19. Country Joe
    Country Joe
    Fellow HAMB Members,
    I stand before you in shame and disgrace:(.
    I have found my overheating problem. Thank you all that offered help. It was appreciated and did indeed lead me to the path of a solution.
    And I feel every thread should have closure.
    So, here is a picture of the engine I built below. Have mercy.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    Oh oh, put the intake gaskets on backwards..... dammit
  21. twenty8
    twenty8
    You gotta be happy it's an easy fix, and you aren't the first.....
  22. Country Joe
    Country Joe
    I was pondering my engine trouble and the intake gasket being installed wrong crossed my mind. I thought naw.....maybe? So, I took the heater hose ****** out of the intake and shined a light inside, over at the port and then I saw that wall of blue, DAMN IT!
    lol....I am relieved that it will be fixed with a new set of gaskets and an oil change.(trapped water went inside when I removed the manifold)
  23. wheeltramp brian
    wheeltramp brian
    I haven't personally seen that happen but now that it's in my mind, something to think about for future problems ,glad you found it
  24. Good man! Letting us know the solution, even if there's a bit of humble pie involved. Just look down, kick the ground a couple times, order a new set of gaskets (install this side up, this end to the front) and rejoice in your new cool running ride.
    The story at lunch or breakfast with your hot rod buddies will be good for a few yucks for years to come. ;)
  25. Country Joe
    Country Joe
    Thanks!
    ****oned it all up this morning. I'm going to start the engine tomorrow to give the silicone(or whatever it was that came with the gaskets) time to fully cure. Then take a drive. I am optimistic that it will stay cool.
    Joe Travers and warbird1 like this.
  26. Well*....***..... That there pulling the heater hose ****** and taking a peek is a pretty good tip, in any case. :oops: :rolleyes:
  27. Country Joe
    Country Joe
    Thanks!
    If at the very least, I now fully understand the cooling system better than I ever have. Seems like kindergarten stuff now..lol
  28. Country Joe
    Country Joe
    Thanks! I think it helped visibility that I only had clear water it the engine at the time. If it was still green liquid I'm not sure I would have seen it.
    anothercarguy likes this.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
  30. Wanderlust
    Wanderlust
    Mistakes ****, but they also include a good learning curve. Takes a big person to admit theirs, gotta love the simple fixes!
