Projects Big daddy's 1960 El Camino
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Nov 18, 2020.
  1. Lloyd's paint & glass
  2. sidewayzz69
    sidewayzz69
    heres the way I done mine. The only thing the light or diode does is help with a back feed, to prevent a run on condition. i think. I am sure someone here with alot more wiring experiance will chime in.
  3. Budget36
    Budget36
    When I changed to an Alternator in my ‘42, I ran one wire to a bulb, bulb would light when the key was on, start the engine, let it warm up a bit then get it to about 1000/1200 RPMs light would go off and the alternator was charging.
    I think I found the diagram on madelectrical.com.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sound's like he changed it from a 1 wire back to how GM did it. If so?, (call your buddy to verify) it'll be fine. If it is, after your trip add the 3rd wire needed so it start's charging as soon as you start the vehicle.
  5. Squablow
    Squablow
    The one wire system is **** in my opinion, it's always "excited" so it's a slow drain on the battery, GM never used one set up that way, it was made for some marine and forklift applications I think.
    I have the one like you show there and I run it through an isolated light bulb to the ignition switch, it's a 2 wire plastic bulb socket so it can't ground to anything. Turn the ignition on, bulb lights up, that means it's got signal. Start the engine and get a few RPMs going, bulb goes out, now I know it's charging.
    I've always been told not to run it without the bulb. I'm no expert so I don't know exactly why, but it's really nice having that bulb anyway, I want to know the ignition switch is sending it's signal and I want to know it's charging when the bulb goes out. For one extra wire, it seems well worth the effort.
  6. 38Chevy454
    38Chevy454
    I believe leaving the exciter wire off just makes the alternator become a self energizing style. Like a 1 wire, but with the external voltage sensing jumper. It might take more rpm to self excite, but once charging it will be fine for your trip. The exciter just gets it charging soon as it is turning, doesn't effect the charging output.
    chryslerfan55 and hotrodjack33 like this.
  7. SS327
    SS327
    Just don’t use a led type of light it will never charge. Use only an incandescent type 2 wire socket and bulb. Something about needing some resistance.
    Lloyd's paint & glass likes this.
  8. Lloyd's paint & glass
    My buddy is gone on vacation. I've seen this setup on a lot of cars and figured somebody here has done it this way also.
  9. Lloyd's paint & glass
    It's working without the wire, I didn't know if it would go crazy and overcharge or some **** lol. Soon as I start the car and tap the gas pedal it goes to 14V. When Terry gets back and opens up I'll see if he can fix this other one though. He mentioned switching it to the CS130.
    sidewayzz69 and chryslerfan55 like this.
  10. Lloyd's paint & glass
  11. Lloyd's paint & glass
  12. Budget36
    Budget36
    You gotta do something about that white fuel gauge;). If your sender is compatible with a SW one, I’ve a two inch gauge I can send you.
    chryslerfan55 and Atwater Mike like this.
  13. Lloyd's paint & glass
    Lmao! I got the moon gauges from scotty, I could've sworn they were white face when I ordered the gas gauge! I'll get one later. I'd love to find a moon gauge 0-90 ohm.
  14. Lloyd's paint & glass
    The car needs a velocity stack!
  15. HOTRODPRIMER
    HOTRODPRIMER
    It's looking good, I think your gonna make it! ;) HRP
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Please please please! it's yours for the taking.
  17. sidewayzz69
    sidewayzz69
    to my knowledge 14 wont hurt a thing
  18. sidewayzz69
    sidewayzz69
  19. Lloyd's paint & glass
    I guess what I'm trying to say is if it's charging, what's the point of the other wire? Every diagram i see says it has to go to a dummy light or somewhere before it'll work?
    sidewayzz69, chryslerfan55 and SS327 like this.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It does more than say hey dummy your running on your battery. But to really get you thinking. Technically the wire from the battery terminal to #2 terminal as you have isn't the correct way of doing it. #2 terminal is so the alternator can sense the entire electrical system's voltage. That wire should "technically" be near the fuse box or ignition switch's hot lead.
  21. SS327
    SS327
    Hey Lloyd you could use the volt gauge in place of the idiot light. Just switch the wires around. And it only costs you a few minutes time and a couple of wire connectors.
  22. doyoulikesleds
    doyoulikesleds
    The wire is to energize the altenator as soon as you turn the key with out it it has to spinn fast enough to energize its self. If you car starts like mine you will spin it fast enough as soon as it starts to never notice the differnce. the one on my dads ih has been like that for 20 years or so
  23. alumslot
    alumslot
    How many volts when you turn on the lights with it running?
  24. HOTRODPRIMER
    HOTRODPRIMER
    14 Volts and your charging and the alternator is working like it should. HRP
    Lloyd's paint & glass and SS327 like this.
  25. Lloyd's paint & glass
    With the electric fan running and the headlights on its still 14 at idle. It drops down to around 13 when I turn the fans on, but it goes right back to 14.
  26. Harv
    Harv
    from Sydney
    That's the first time I've seen a velocity stack with an inbuilt subwoofer :D
    Cheers,
    Harv
  27. SS327
    SS327
    That poor dog breaks my heart. Having to walk around with a cone on like that!
  28. rusty1
    rusty1
    please remove that driver's side inner headlite bulb...thanks
  29. Lloyd's paint & glass
    Took it out for a test, probably 2 miles, breaking up around 3 grand, stopped and retarded the timing a bit, didn't break up after that. But it's dropping the nose now when it gets toward 4000 rpm, I didn't check the float level in the primary after I took the bowl off and cleaned everything out, I'm suspecting it's running out of gas. Transmission shifts out great and everything else seems to be fine.
    61Cruiser, SS327, sidewayzz69 and 2 others like this.
  30. What do expect with that junky *** Tunnel Ram on it ,,,,,,no wonder it falls over at 4 grand .
    Lol,,,,,,just kidding !
    I love tunnel rams ,,,,and I have found that a tunnel Ram will **** the carbs dry at upper rpm .
    You must have the pressure,, and fuel volume up in the rpm .
    3500-4000 is close to that limit,,,,it will nose over just like you turned the switch off .
    Of course,,,,I had two 750’s,,,on a 440,,,,,but it’s still the same general idea .
    Tommy
