Projects S.E.G.A. Olds build
Discussion in 'Traditional Hot Rods' started by Saturn V, Oct 11, 2021.
  1. Saturn V
    Saturn V
    from Killen AL
    I have 2 right now. Still looking for more! I'm hoping by the end of the yr to order a billet crank.
    AHotRod likes this.
  2. Saturn V
    Saturn V
    from Killen AL
    Drilling for the splayed caps this evening. I used a transfer punch to find my angle and center on the holes. Then swapped to a drill bit the same size to spot drill the block. Then went to a U bit to drill for tap size. I'll set up to tap the holes later in the week. IMG_20220531_181312800.jpg IMG_20220531_181321518.jpg
  3. Atwater Mike
    Atwater Mike
    Always was drawn to manual machining. Use your head, find solutions.
    Go, man...Go!
    OahuEli, Saturn V and 427 sleeper like this.
  4. bobss396
    bobss396
    Look at the venerable AK47 rifle, drawn up on paper, no CAD or CAM available. They were reading off machine dials. It was more of a discipline than anything.
    Tman likes this.
  5. Saturn V
    Saturn V
    from Killen AL
    That and constantly checking every move you make.. I put indicators on the travels of any machine I'm not familiar with.. something I learned the hard way working in plant maintenance!
    bchctybob likes this.
  6. DDDenny
    Manual machining..........what else is there!
    Saturn V likes this.
  7. bobss396
    bobss396
    My Bridgeport DRO took an Amber Heard on me a few years back and is beyond help. So now I dial everything off. The old Travel Dials worked pretty well once you got the hang of them.
  8. Saturn V
    Saturn V
    from Killen AL
    Putting wrinkles in holes tonight! IMG_20220602_181935669.jpg IMG_20220602_184052241.jpg
    winr, catdad49, AHotRod and 13 others like this.
  9. 427 sleeper
    427 sleeper
    These kind of processes have always amazed me! I wish I had the Patience, Skill, and equipment to do this kind of thing! Lookin' Good Brother!
  10. Looks very racy!
  11. Saturn V
    Saturn V
    from Killen AL
    I thank you all!! I wished I could still be able to do it in a timely manner, like 5 yrs ago. But I can still do it. Just takes way longer!!
  12. bobss396
    bobss396
    Saturn V and Outback like this.
  13. Saturn V
    Saturn V
    from Killen AL
    Never,,,ever,, been told that before! Lol ***anium? Two rusty 5/16 nuts maybe!!
    RustyDogg and OahuEli like this.
  14. Saturn V
    Saturn V
    from Killen AL
    This is the final product. We have about 5 of these to do!! It's how we pay to play!! IMG_20220604_114413017.jpg IMG_20220604_114424904_HDR.jpg
    winr, catdad49, AHotRod and 11 others like this.
  15. 427 sleeper
    427 sleeper
    Watching in AWE!!! :cool::cool::cool:
  16. I’m not a machinist, so maybe I’m ignorant. How hard would the rear main have been, and how much or little would it have added to the strength, if you had done a upgraded rear main cap? Not criticizing, just asking! Could you have added a strap to that cap? Seems I’ve seen that done too.
    Saturn V and Brand Apart like this.
  17. bobss396
    bobss396
    The rear of the block is pretty stout as it is and the area is quite busy as it is. You'll be running into what is known as diminishing returns to do much of anything else with it.
  18. Saturn V
    Saturn V
    from Killen AL
    That pretty much covers it. The cost of making the rear cap and fitting it to the block plus the time. The money could be better spent somewhere else.
    I've seen the rear cap strapped before, but the engine had a belt drive oil pump. Which is not allowed by SEGA.
    ottoman, bobss396 and SilverJimmy like this.
  19. Garlic Slinger
    Garlic Slinger
    I see you have both "D" and "DX" blocks. To this point have both required the same machining operations?
  20. Saturn V
    Saturn V
    from Killen AL
    Yes, both take the same operations. The D block will have 1 more that can be done with a hand drill. I'll post pics of what needs to be done later this week.
  21. bobss396
    bobss396
    I hardly question the abilities and knowledge of someone with an expen$ive block strapped to a Bridgeport table with the head ****ed off on an angle. :cool::cool:
    SilverJimmy and Saturn V like this.
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    And here is proof why my threads are completely inadequate after reading this one.
    Outstanding.
    RustyDogg, guitarguy, OahuEli and 6 others like this.
  23. mjlangley
    mjlangley
    from SE MI
    Cool build, thanks for taking the time to do***ent it and share it!
  24. Saturn V
    Saturn V
    from Killen AL
    The 1st 2 pics show you the difference between the D and DX blocks. With the D's they had a problem with cap walk with over 22-1 compression ratio. As you can see, GM's fix was a slight counter bore. So we duplicate it. IMG_20220608_193628428.jpg IMG_20220608_193641344.jpg IMG_20220608_193945627.jpg
    catdad49, brEad, AHotRod and 4 others like this.
  25. Saturn V
    Saturn V
    from Killen AL
    I didn't think when I was asked before about the operations between the D and DX. The DX has one more major job to be done. The lifter bores need to be bushed. This particular ones lifter bores will be bored and reemed for a 1" bushing. Then honed for a .903 lifter.
    catdad49 and bchctybob like this.
  26. Saturn V
    Saturn V
    from Killen AL
  27. DDDenny
    Impressive!
  28. bobss396
    bobss396
    Looks like money... $$$$$$..:cool::cool::cool:
  29. Saturn V
    Saturn V
    from Killen AL
    Thanks guys!! It's a good feeling to be able to p*** this along! None of my kids could care less!! I blame it on Thier mom! Lol
    catdad49, bchctybob, brEad and 7 others like this.
  30. Saturn V
    Saturn V
    from Killen AL
    Picked up this little thing today. I'm going to be cutting on the firewall some more!! IMG_20220611_174015689.jpg
    winr, catdad49, bchctybob and 9 others like this.
