Technical Exhaust help
Discussion in 'The Hokey Ass Message Board' started by 41Helen, Jun 4, 2022.
  1. 41Helen
    41Helen
    Hey all,
    I have standard SBC exhaust manifolds on my 41 Coupe. I have a DIY 2.5” exhaust from Speedway that I am attempting to hang this weekend. I ran into an issue though with the collector reducers I am using. From my measurements the manifold is 2.5” outlet, so I bought a 2.5 to 2.5 collector reducer. However the flange is no where near fitting on my manifolds. The bolts on my manifold are 2.5” apart as best I can measure. The holes on the flange for the reducer I was recommended at 3” apart.
    Anyone have any idea where I can source the correct ones that will work? Car is going for an alignment Monday, so if it’s an off the shelf option would be great!
    Thanks!
  2. Bandit Billy
    Bandit Billy
    Helen, You should mod your profile to include your location, a member down the street may have a set of collectors on their wall you could obtain.
    41Helen and 41rodderz like this.
  3. saltflats
    saltflats
    from Missouri
    Back in the day used to get them from the muffler shop.
    I'm sure a parts store can get them through Walker.
    41Helen likes this.
  4. Blues4U
    Blues4U
    from So Cal
    As always, pictures would be helpful. But if the bolts on the manifold outlet are 2.5" apart there is no way the exhaust outlet itself is 2.5", more likely 2.25" or even 2".
  5. bill gruendeman
    bill gruendeman
    Stock sbc will be smaller than 2 1/2 not sure what size, but a muffler shop should be able to form up the reducers and sell the flanges
    41Helen likes this.
  6. 427 sleeper
    427 sleeper
    Collector reducer's are for header's, not exhaust manifold's. You used to be able to get headpipe starter kits from Walker, don't know about now-a-days... ;)
  7. 41Helen
    41Helen
    Good point. I’ll do that shorty!
    Bandit Billy likes this.
  8. 41Helen
    41Helen
    This is what I measured. The output opening I believe was Looking at it correctly. But I have had a few beverages haha
  9. 41Helen
    41Helen
    Here’s the best pics I could get from underneath.
  10. 427 sleeper
    427 sleeper
    What are the manifold's off of? You're going to need the doughnut's, heat riser gasket , and heat riser/heat riser delete spacer. Depending on application, you may not need the heat riser/delete spacer. Once you get all of that sorted out, you can start with the factory style head pipe flange's.
    41Helen likes this.
  11. 41Helen
    41Helen
    They are ordered straight from Summit for a SBC.
  12. bchctybob
    bchctybob
    Most old Chevy manifolds have a 2” head pipe with a slip-over donut for a gasket. Corvette versions were for 2 1/2” pipe. If you have the factory flanges, donuts and the old pipes you can work with that and adapt it to the new 2 1/2” system. If not, you will have to find a good old muffler shop and buy some flanges that fit your manifold outlets and some tubing for stubs.
    Bob Lowry, 41Helen and 427 sleeper like this.
  13. 427 sleeper
    427 sleeper
    If it's your run of the mill, standard SBC manifold, it's usually a 2" outlet. How much of a headache is it to remove a manifold and take it to a local NAPA and match up what you need to what you have? Does Summit give any critical dimention's for the manifold's? Or do what @bchctybob said, because he type's faster than me! LOL!!! :D
    41Helen and bchctybob like this.
  14. goldmountain
    goldmountain
    Take the exhaust manifold to a muffler shop and they can make a short piece to work.
    41Helen, bchctybob and 427 sleeper like this.
  15. 41Helen
    41Helen
    Thank you all. Looks like in the interest of time I will take a manifold off and bring it to the shop Monday and go from there. Thanks!
    427 sleeper likes this.
