My new project 1951 Buick
Discussion in 'The Hokey Ass Message Board' started by aw1950, Oct 18, 2010.
  1. aw1950
    aw1950
  2. aw1950
    aw1950
    Getting along on the worst stanchion . Had 1/2 day off today , spent it you know where !! Have a look . Will try and be a little more fluid with progress shots in the coming weeks . Thanks to all who are the long time viewers of this journey together!
    Peanut 1959, loudbang and 54delray like this.
  3. BJR
    BJR
    Making great progress!!!!
    aw1950 and loudbang like this.
  4. aw1950
    aw1950
    IMG_3223.JPG IMG_3224.JPG IMG_3226.JPG IMG_3248.JPG IMG_3250.JPG IMG_3251.JPG IMG_3254.JPG IMG_3255.JPG IMG_3256.JPG
    Okay been working on the rear stanchions . Have them about 90% repaired. Now I don’t know if I want to keep lights in the pods or put dagmars on and call it done ! Opinions?
  5. Squablow
    Squablow
    Great to see you picking away at this yet. If the diameter was right, a pair of '57 Chevy front bumper rubber tips might look cool in that rear guard, but I could see them being reverse lights, too. Either way an impressive amount of work it took to fix those things!
    aw1950, loudbang and 54delray like this.
  6. aw1950
    aw1950
    So , been working away again . Took three days off last week plus the weekend . Knocking stuff out quite quickly . Amazing how if uninterrupted what you can get accomplished . Although you can’t see it in th pictures I got the filler panel between body and bumper done , blocked the trunk and back of the car , ready for the final coat s of high build . Worked on the rear window surround , had to slice it open to adjust for final window fitment. It’s better now .
    Made the start of a filler panel inside around the rear gl*** as it hide all the inner structure of the gl*** frame . Couple pics for the faithful . IMG_3284.JPG 66870772621__5A41C177-7E1D-4FD8-8685-483483129DC0.JPG IMG_3287.JPG IMG_3288.JPG IMG_3289.JPG
  7. Squablow
    Squablow
    That Tetris game of sheet metal seams on the inside of the rear window really shows how much work went into making that right, very nice looking results though!
    aw1950, 54delray and loudbang like this.
  8. aw1950
    aw1950
    Window surround complete, just needs painted , and urethane then drop the gl*** in . Nice streamlined look as the rubber surround is flat not bulbous as stock window gaskets . I like the look !
    1biggeorge, TomT, Rhinotoyz and 4 others like this.
  9. Peanut 1959
    Peanut 1959
    Since you asked... Ditch the Dagmars! They make the rear end look cheap and plastic-y somehow.
    If it was me, I'd make them back-up lights, auxiliary brake lights, or exhaust exit surrounds.
    40FORDPU, chryslerfan55 and aw1950 like this.
  10. aw1950
    aw1950
    Thanks for input , the jury is still out on these I ll see as I get closer to completion . The exhaust is dumped out the side quarter panel behind the wheel opening . Reverse lights may still be the option . Time will tell .
  11. Amazing work as always! I love seeing the updates. Still hard to believe what you started with compared to where the car is now. Well done sir!
    aw1950 likes this.
  12. SS327
    SS327
    Turn them into tail lights and fill in the tail lights. Dare to be different?
  13. aw1950
    aw1950
    LOL the whole car is the definition of different . Seriously though I have thought of that as well , a little concerned of them being so low . ??? Not completely convinced yet on what direction ! Thanks for input .
  14. impala4speed
    impala4speed
    Fantastic work! I really like the tail lights you have now.
    aw1950 and 54delray like this.
  15. aw1950
    aw1950
    IMG_3307.JPG IMG_3308.JPG IMG_3318.JPG IMG_3319.JPG IMG_3320.JPG IMG_3321.JPG IMG_3325.JPG IMG_3326.JPG
    So , next on the agenda ,hood . If I have attention of long haulers I wanted to have my hood open conventionally. I used 87 F150 hinges . Very basic hinge . Put them on and , no go . Lots of scratching head on that . Voila the centreline of the hinges are inboard 8” . All that is on the backside of the hood past pivot point wants to cantilever down into the cowl . No good . Sooo off come the back portion of the hood to be grafted onto cowl and move the break point closer to the front of the hood . I’ll will make more sense as I move along . In the meantime have a look .
  16. aw1950
    aw1950
    More progress shots . This ole sled is getting a little hot rod touch as well . Slight tasteful induction. Serves two purposes. The first is a way for the hot air under the hood to evacuate once I cut open the hood scoops . Air in air out principal. Secondly, it’s to facilitate the opening of the hood without binding at the cowl area . Get it all welded up and ground it’s going to be killer in my opinion !!
  17. aw1950
    aw1950
    By the way I had to take that profile shot as it’s the first time I’ve seen it outside in six months . Later !
    chryslerfan55 and 54delray like this.
  18. aw1950
    aw1950
    IMG_3347.JPG IMG_3349.JPG IMG_3352.JPG IMG_3433.JPG IMG_3434.JPG IMG_3435.JPG IMG_3436.JPG
    So here we are , showing what I did under the hood to hinge brackets. Tied the two hood inner structures together . Cowl pretty much done . Showing side profile of hood . Also rear gl*** is installed. Lots of time just for this . I have two months left to have ready for our main event car show here in town . Clock is ticking .
  19. I'd say use (kind of) dark lens in the bumper guards with LED lights. Ya can't have enough brake light in today's world of dumb*** drivers!!
    aw1950 likes this.
  20. aw1950
    aw1950
    Starting to see some paint finally . Getting the inner fenders wetted out and the headlight opening painted . Will be able to final ***emble the front clip next weekend . Wire the heads and directional lights . Get that stuff crossed off the list .
  21. aw1950
    aw1950
    Not a great shot , dusty engine compartment but the painted front clip is in place . I am in the process of blending all the sheet metal together . All welded up and filler to get the desired effect! Moving forward!
  22. Here’s an idea, put it in the pedal car on the ground next to it.
  23. aw1950
    aw1950
    LOL i figured someone would pick up on that !!
  24. aw1950
    aw1950
    Okay realized no pictures to back up the last two posts .
    I have fallen into the LS trap . This is for later down the road just to good a deal to p*** up
  25. Peanut 1959
    Peanut 1959
    You're gonna want to delete the LS reference and photos. Not H.A.M B.-friendly.
    aw1950 likes this.
  26. aw1950
    aw1950
    I forgot all about the rules !
    Peanut 1959 likes this.
  27. Peanut 1959
    Peanut 1959
    It happens!
  28. aw1950
    aw1950
    We’ll it’s been a while but I have been gathering more parts and fabricating interior panels . Picked up Eldorado seats , leather, in great driver quality condition . Got the hood to fender gaps cleaned up and the latch mechanism functioning
  29. aw1950
    aw1950
    Okay so just a hint on what’s happening later. Buick isn’t done yet but sometimes a deal comes along that just needs to be grabbed , more pictures tomorrow. Just a teeze for tonight LoL
    impala4speed likes this.
  30. aw1950
    aw1950
    Couple more from its resting place of fourty years . Resurrection is in process !! Going to be my retirement project . As mentioned above more clear pics tomorrow
