Technical ***June 2022 Banger Meet Thread - June Already?***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jun 1, 2022.
  1. Phil Damon
    Phil Damon
    from San Diego
    It looks like the Murray Horn damper. I had Murray make a custom one with grooves for a serpentine belt. He still makes them. Doesn't have a website. I just communicated with him by email. Very easy to work with.
    horn@xtra.co.nz
    Outback and Crazydaddyo like this.
  2. Crazydaddyo
    Crazydaddyo
    Thanks for the info.
  3. Fabber McGee
    Fabber McGee
    I bought a new Super Damper for a small block Chevy to put on my B engine. With serpentine grooves, about 5 inch if I remember correctly off ebay. Haven't had time to adapt it yet. A hundred bucks.
    Jet96 likes this.
  4. brokenspoke
    brokenspoke
    Looks identical to the one I bought from Murray Horn
    Crazydaddyo and Outback like this.
  5. Outback
    Outback
    from NE Vic, Oz
    Wow! I am looking forward to seeing this car come together!
    We have a Prince Henry Vauxhall in at work at the moment which has a similar styled radiator.
    winduptoy likes this.
  6. trikejunkie
    trikejunkie
    from Scotland
    I`m here - just started work on my A Coupe ! rebuilt B engine going in ,main thread on the main page under Sacramento Coupe. 20220601_170250.jpg
  7. Mainedrifter2
    Mainedrifter2
    Finally on the road and enjoying some miles on my banger. 6D61F521-9B41-4DE8-8399-4775D57C4DEC.jpeg
  8. raaf
    raaf
    Another day in paradise.
    I was told that stock Kelsey Hayes' won't fit over cast iron rear drums. Sorry to say, but that's very much true. I had to do more grinding than I wanted to get them to fit, but I think they're still fundamentally sound.
    Also, does it ever happen to you, that you collect things for a project, they sit around forever and the day you go to finally use them, you notice something that you never saw before? My "matched" set of Kelseys isn't so at all. If you look closely, these wheels are different. Maybe Motor Wheel? Close enough for me, but when you notice subtle things like this you start to think you're going a little crazy.
    Now off for blasting and paint (black).
    barrnone50, Jet96, Old Dawg and 3 others like this.
  9. T-Head
    T-Head
    from Paradise.
    I'm working on finishing up a project now and clearing up some space in the shop for the ch***is, will mock up some brackets for the seat, and work on how the radiator will be attached to the frame. The vintage racing season is in full swing now and am busy preparing two cars for that as well.
    An early Prince Henry Vauxhall is a very rare and interesting car, you are lucky to have one!
    Old Dawg, winduptoy and Outback like this.
  10. The37Kid
    The37Kid
    Is that a stock Model A color combination? If so what is it, I really like it. Bob
  11. Outback
    Outback
    from NE Vic, Oz
    We have some special cars through here from time to time. I'm more on a beer budget though so not likely to end up with anything that special in my shed. They are nice to work on though.
    guitarguy likes this.
  12. Mainedrifter2
    Mainedrifter2
    Hey Kid, I believe it is a stock color combo. Chicle Drab and Copra Drab with a straw stripe.
    The37Kid and winduptoy like this.
  13. jim1932
    jim1932
    I like the color....LOL
    The37Kid and Mainedrifter2 like this.
  14. jim1932
    jim1932
    Well, lesson learned. I replaced all the washer gaskets and the car seems to run fine. Several trips of about 4 miles each. Then I replaced the overly long water outlet studs. At 35# the damn thing snapped. Fortunately I am not too far from Al at go devil and he fixed me up with a spare and a copper gasket.
    Simmons Super Power Head, Dual 81's Burns intake and red's Header and it all runs smooth. Stock distributor but with Renners cap that runs wires.
    Old Dawg likes this.
  15. V4F
    V4F
    from middle ca.
    finally got my stuck brake drum off . had to cut it up to finally got it off . but onward & upward ............
    steve
    Outback, Jet96 and Jiminy like this.
  16. I never fit a gasket under the water outlet. Learnt my lesson breaking them in the past… I normally lap the outlet to the head and use a thin skim of sealant.
  17. 29 Speedster
    29 Speedster
    from Colorado
    9F8313C3-0697-45AF-8C8C-FF394BB3C195.jpeg 32EE70E2-CC83-4D53-9B60-10D276EC0B00.jpeg 76B126F1-693D-4E85-B374-F1E88B857C31.jpeg The engine is in the Speedster. Progress is slow ( might be me), decided to go with DCOE Carburetors, I liked the look of the Velocity Tubes. I thought it would be simple, but everything requires some fabrication.
  18. grumpy gaby 2
    grumpy gaby 2
    Hay guys, I had to go clear to page 10 to find this month's blog. No one doing anything with their bangers?
    I'll have to bump it back up with a question. I have been looking for an external oil pump to be driven off the front of the cam gear for pressurized system on my Chevy banger. Not having much luck so far. Any suggestions? About all that I have found currently is 4-cylinder jeep, 6-cylinder flat head Mopar, and big block Mopar. None of these turn my crank. Be safe and have fun!
  19. You could try a Barnes single stage.
    winduptoy, burl, 40 Olds and 7 others like this.
  20. wheeltramp brian
    wheeltramp brian
    Geez John that motor is a beauty!
    Stan Back likes this.
  21. Thanks Brian
    That ***** has put down a ton of rubber on the roads
    J
    Outback and Old Dawg like this.
  22. grumpy gaby 2
    grumpy gaby 2
    Thanks, John, for the barns idea. Will check with them Monday. Like Brian said, that engine looks great!
    Mine will not look one third that great, I'm trying to make it look like a 20's backyard bult speedster. Be safe and have fun!
  23. brokenspoke
    brokenspoke
    I don't think that oil pump was around in the 20's
  24. grumpy gaby 2
    grumpy gaby 2
    So far, I'm not finding anything that looks close to 20'ish, need to widen my looking somehow or hide the new one. Things that were around when I was a kid are not now!
    Outback likes this.
  25. nutrocker
    nutrocker
    Lovely looking motor John.
    Mine made it to Pendine Sands in May and ran pretty good. We get a half mile run up from standstill, then our speed it calculated by measuring the time taken to p*** through the 330 foot timed section.
    This year my car did 102mph at 4300rpm. There’s a bit more to be had with a few minor tweaks for next year.
    For this year I changed the car up a bit too. Cutting the cowl off in front of the doors and fab’ing up a new shorter and wider one. 32 grill shell. New hood and sides. Changed it over to centre steer and mounted the radiator in the turtle deck.
    This year I found the Saturday early morning sand very slippery, and still sawing at the wheel in the timed section. An old iPhone with a couple of magnets glued on the back stuck to the dash with a speedo App I could see that my entry speed at the first flag was 100mph. Still accelerating I had s timed speed of 102.06mph.
    The second run on Saturday afternoon the sand felt better, much less sawing at the wheel, and once into third (top) gear it was stable. I entered the timed section at 102mph but a step out at the rear knocked it down to 99mph at the exit flags.
    Over night I removed the headlamps and fitted a couple of flat washers under the dump valve spring in an attempt to get a bit more speed for the Sunday.
    Sadly though, a strong headwind put pay to beating any of Saturdays speeds.
    Quite happy for now though, and the car ran great and never missed a beat. Only the second ever vintage 4 banger to get over the 100mph in the 10 years it’s been running, and a bit faster than a fair few flathead V8’s and even some of the overhead valve V8’s too.
    photos by various photographers that I’ve taken off the internet, credit to them.
    91E23156-2FB2-4B86-9C8C-1C5AA3649E53.jpeg 31D06306-AD4E-4AB2-B8CC-265B2760E606.jpeg 0689735B-D692-4CAF-8F99-FF88D355EA18.jpeg 74C99D77-96EA-43CF-91FB-E6F1BC003017.jpeg E8E258D7-861E-4E86-A3B7-A6A17063AB6C.jpeg 263620B0-3855-4D25-A424-999DB46D2DD8.jpeg 30D34FEE-2C32-417E-85C5-DD3716511881.jpeg 8E6F3CD3-E157-41AB-83F3-86F6A29D387F.jpeg 445FCACE-2C85-4127-AC93-5E668F8B7637.jpeg DDFBA269-E2C7-4390-803E-7054B8E2B0E3.jpeg 3B60516E-279A-469E-A223-38E57E0E385B.jpeg
  26. studebakerjoe
    studebakerjoe
    @grumpy gaby 2 for a front mounted old timey looking pump I would look at maybe a John Deere 820 oil pump or if you want one mounted on the side of the block driven off generator or similar might look at the Detroit 71 series oil pump. It would need a bit of modifying but could work.
    v8flat44 likes this.
  27. Not bad speeds considering you fellas are running on sand; and our old buggies are about as aerodynamic as a galleon at full sail! Keep up the good work!
  28. grumpy gaby 2
    grumpy gaby 2
    Thanks Studebakerjoe! The John Deere 820 looks pretty good, but I don't see a pressure relief valve. Will have to figure that too. The only problem for me is that I was raised on nothing but RED tractors! I'll just have to close my eyes! I also see what you mean about the Detroit 71 modification for side mount. Thanks! Be safe and have fun!
  29. Decided to mess around in the shed for a bit today, and got things looking a little bit better!
    Just need a battery and the yellow engine will fire! A369E29F-08C8-4EBA-8DC3-4883AD4BDD6A.jpeg 7EBDE9C1-203F-4032-A32C-C60C4DF8FBC7.jpeg
  30. studebakerjoe
    studebakerjoe
    BeaverMatt and Outback like this.
