Technical What are they, I have no clue
Discussion in 'The Hokey Ass Message Board' started by Stuffbuffet, Jun 8, 2022.
  1. Stuffbuffet
    Stuffbuffet
    I bought this in a box at a yard sale. Don't know what it is.
    I ***ume it's automotive, tool related since every other thing I bought was a tool or auto. It was in a red cardboard tube. About one inch in diameter but I didn't measure.
  2. Mr48chev
    They almost look like some of the pieces that I have in my late son's tool box that he made in the machinist cl*** at Perry Tech. Meaning pieces turned on a lathe while learning to use the lathe.
  3. 51504bat
    51504bat
    A drill guide to center a smaller diameter drill in a larger existing hole? Maybe used in drilling a broken recessed stud to use an EZ out? Just a dumb ***ed guess.
    Tman and firstinsteele like this.
  4. verno30
    verno30
    The barrel of a center punch?
  5. AccurateMike
    AccurateMike
    Looks like a set screw has been run up against the side of it a bunch of times. Must have fit in an adjustable fixture of some sort. Maybe holding something like an indicator on a machine or such. You will figure how to use it for something :) Mike
  6. squirrel
    put it in a flathead ford block to hold the pilot for the valve seat grinder?
  7. hotrodjack33
    hotrodjack33
    My wife has a similar looking item in her nightstand:eek::eek::eek:.
    verno30, 49ratfink, i7083 and 12 others like this.
  8. silent rick
    silent rick
    i have something similar only larger, 3/4 id by 1-1/4 od.
    i can then cut off any length i need for custom axle/wheel spacers for building custom bikes(harleys)
  9. Doublepumper
    Doublepumper
    from OR-WA, USA
    Looks similar to a lug swage tool.
    squirrel likes this.
  10. B.A.KING
    B.A.KING
    Does it have the marks on the side of it:D:D
  11. J. A. Miller
    J. A. Miller
    from Central NY
    Does she call it Steely Dan?
  12. 56don
    56don
    Its a framise. It goes inside a .......ooh, some one is at the door....later...
  13. Stuffbuffet
    Stuffbuffet
    Here's an update...
  14. But I don't see a place for the batteries!
  15. Wanderlust
    Wanderlust
    It’s one of the old manual jobbies
  16. 41rodderz
    41rodderz
    from Oregon
    Since you bought so many of them and not being sure of what they are , your a hoarder aren’t you ?:D Admit it :)
  17. Stuffbuffet
    Stuffbuffet
    Well no, I just thought since I was buying a box of misc I would just grab em all and make the deal better for me.
    I was hoping they were worth $5 a tube but idk what they are.
    hotrodjack33 likes this.
  18. 41rodderz
    41rodderz
    from Oregon
    :D There’s no shame if you are. A lot of us have that problem.:)
  19. 62rebel
    62rebel
    No markings on the tubes themselves? Odd
  20. Budget36
    Budget36
    I’d have probably bought them too…mercy.
    hotrodjack33 and bchctybob like this.
  21. Stuffbuffet
    Stuffbuffet
    Anyone want any?
  22. Almost looks like industrial carbide sandblasting tips? They usually come in tubes like that
  23. ClayMart
    ClayMart
    If you put one of them back in one of those red cardboard tubes and lay it on a park bench somewhere con****uous, I bet you the police will come by and try to identify it for you. Who knows. Maybe the FBI will even show up to help them figure out what it is.
    Problem solved.
    :rolleyes:
  24. bchctybob
    bchctybob
    What’s the other end of the look like?
  25. Stuffbuffet
    Stuffbuffet
    The first post has the bottom of them...the 3rd picture. It's flat with a C stamped in them.
    The hole is NOT all the way through and is not threaded.
    bchctybob likes this.
  26. 41 GMC K-18
    41 GMC K-18
    They resemble the roller spacer, that fits part of the cleat track system, for a late
    50's " TUCKER SNO-CAT ".
  27. ct1932ford
    ct1932ford
    I think they keep the red tubes from getting out of round.:p
    I had anesthesia yesterday so cut me some slack.:(
  28. RmK57
    RmK57
    I'd use them as solid lifters.
  29. 1pickup
    1pickup
    Teeth marks, maybe...
  30. choptop40
    choptop40
    epoxy bolts into them and would make cool grille accents , or toggle switches , etc,,use your imagination..or send them to me..he he he
