Projects 1949 Buick Sedanette Mild Custom Build
Discussion in 'Traditional Customs' started by rockable, Mar 16, 2019.
  1. 123pugsy
    123pugsy
    Damn...........:mad:
    rockable likes this.
  2. rockable
    rockable
    Different. First time, it was #2 intake. This time, it was #1 intake. Both lifters on either side looked great on the first one. I've not pulled #2 yet.
  3. i.rant
    i.rant
  4. SS327
    SS327
    Well it’s not a bad block. That ****s! This **** that is going on with cams is totally out of control. It feels like the cam companies don’t care either. They get to sell more cams and lifters. I have to wonder if they aren’t doing this on purpose to sell more expensive roller conversion cams. Let’s face it, why sell someone a cam and lifters when you can sell someone a cam, roller lifters, pushrods and new valve springs. And at a higher margin too.
    Thor1 and chryslerfan55 like this.
  5. BJR
    BJR
    I hope you are running the engine in on a stand, and not going through all the work putting the engine in the car each time.
  6. rockable
    rockable
    Im doing this with the engine in the car, Brian. ☹️
    JalopyJimbo, Thor1 and BJR like this.
  7. rockable
    rockable
    Well, well, well. As the NFL refs say, "Upon further review....." it appears lifters are at fault.
    The lifter on the bad lobe on cam #1 had the check valve installed incorrectly.
    When I removed the lifters for cam #2, they all looked good. No wear. I then noticed that #1 intake and #2 intake were dead. They had no springs in them!
    So, it appears I can just replace lifters and put my intake back on. Of course, I have to lube everything up and go through break in again.....once I source another set of good lifters. I have 29 good ones but dont want to reuse them with this cam. Correct?
    LAROKE, Thor1, BJR and 3 others like this.
  8. SS327
    SS327
    Wow, quality control at its finest. Sorry for your bad luck. But it’s still not right.
  9. BJR
    BJR
    That's a real bummer having to do that twice working over freshly painted fenders. I feel your pain. Just think about how much fun it will be to finally drive your 49. Good luck, Brian
    Thor1 and rockable like this.
  10. rockable
    rockable
    I am encouraged that my engine is going to live with the replacement lifters on cam #2. Unfortunately, my new power steering pump is bad and going to have to be replaced. I am replacing the front brake rotors in order to get rid of a high speed vibration. My fuel tank sending unit is not working properly. Also, I am trying to eliminate leaks in my A/C. The debugging list goes on. It seems to be impossible to get quality parts on the first attempt. I drove the car about 150 miles this past weekend. Stay tuned.
  11. vtwhead
    vtwhead
    Drove the car! That is great, it has been a trying mission to get there. Feel for you buy glad you have been able to see the road p*** by. What's up with the ps pump?
  12. rockable
    rockable
    PS pump quits when it gets hot. It's slipping oil as the oil gets thinner. Had to be ****ty manufacturing, probably too much side clearance on the rotor. I did everything right. I sold hydraulic equipment for 38 years. I know a little about how vane pumps work. Tuff Stuff is sending me a new one at no charge.and
  13. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I just read the other day on another cl***ic car web site ( I think the AMC/ AMX ) website that there are some brands / - some known name brands cam and lifters are mfg'd coming from China that are not heat treated correctly / heat treated and those companies are scrambling with QC issues. ( I would imagine refunds as well).
    Let me go back and find it ( tonight) and I'll post the info.
    I would have any new cam and lifters checked before I install in anything now.
    It never use to be that way but unfortunately it is now.
  14. rockable
    rockable
    This was not heat treating. This was improper ***embly, both times..
  15. rockable
    rockable
    Off the top of my head, a faulty power steering pump is something I never would have anticipated. At least the manufacturer is sending me a new one. In addition, my new tires are "unbalanceable". We will be talking to them tomorrow. The beat goes on.
  16. BJR
    BJR
    Do you have a black cloud following you around? A lesser man may have given up and sold it by now. At least you got to drive it. Once it is all straightened out all these problems will be just a distant memory.
  17. @rockable IMHO, now is NOT the time to buy a lottery ticket......
  18. rockable
    rockable
    :D:rolleyes:
    BJR likes this.
  19. 40FORDPU
    40FORDPU
    Times like these, are when I have to correct my wife when telling friends and family.."he just loves working in cars"..at times not so much.
    Hopefully once sorted, you'll have a chance to enjoy your car.
    Thor1, BJR and rockable like this.
  20. Dick Stevens
    Dick Stevens
    Au contraire, now is the time to buy a lottery ticket in the hope of surviving the out of control inflation!
    chryslerfan55 and Thor1 like this.
  21. EBW
    EBW
    Curious if you have Cokers. Had them on my 52 Buick and switched to Diamond Back due to the Unbalanceable way. Expensive lesson I had to learn.
  22. rockable
    rockable
    Yes but I also have them on 2 other cars. We are trying to work it out with them.
  23. 40StudeDude
    40StudeDude
    Sorry to hear of your engine problems, and the other stuff as wel...we all go thru it. IF you read the saga of my '55 Cadillac build, you'll remember toward the end of the first drive of 90 miles on the highway at 70 mph, my brand NEW Cadillac 500 ci engine spun a bearing...!!! It was back to the garage for me too...I was so mad at the car, it sat in the dark garage for two months before I decided to pull the engine and send it back to the builder...Debugging a new car is a whole new experience for any builder...you'll eventually get it on the road...good luck...!!
    R-
  24. rockable
    rockable
    I will, Roger. This ain't my first rodeo but it sure seems like my most aggravating. o_O
    brEad, Thor1 and chryslerfan55 like this.
  25. rockable
    rockable
    Well, latest update is that the 2nd set of Coker Tires were no better than the first. After trying balance beads and Road Force Balancing, we gave up and ordered Diamondback tires made on a BFG TA Radial tire. The bad news is their lead time is 2 weeks WITH expedited service charges. I moved the car to the back of the shop. I will get the Plymouth ready to go to Columbus. Perhaps I will get to drive the Buick to Louisville.
    The replacement power steering pump seems to be ok. The list is getting shorter but the wait is killing me.
  26. EBW
    EBW
    This was the same issue I had with Coker and then DB. But I had to wait 4.5 months for my Diamondbacks. I will say this, they are worth the wait with zero issues.
    40StudeDude and rockable like this.
  27. Fat47
    Fat47
    There has been so much discussion of problems with Coker's here on HAMB that I ordered Diamondbacks a year or two ago. I didn't have a wait problem and they seem to ride good on the limited drive time I have done so far. I think you will find the switch worth while.
  28. 40StudeDude
    40StudeDude
    I think the problem with Cokers is that they are mnufactured out of this country, there is no 'quality control' on them when they are made. I had a set of Cokers on my '55 Caddy that a friend gave me--they lasted three weeks simply because they leaked under the whitewall. I've run DB's for well over 15 years now (I'm on my second set on the '55) - I put the old ones on my '48 Caddy now and STILL NEVER have problems with them...!!! Took the Cad to Salina last year with them on it...!!!
    R-
  29. guthriesmith
    guthriesmith
    Not to get us off track, but I was checking out your 48 at Salina and didn’t even realize it was yours! Very cool car! :cool: I hadn’t been to Salina in 10 years and have pics of your 55 somewhere from that one.
    jim snow and Thor1 like this.
  30. rockable
    rockable
    Good to know, Roger. Thanks. Have you posted a build thread or any updates on the '48?
    jim snow likes this.
