Hot Rods How many are running a stick?
Discussion in 'The Hokey Ass Message Board' started by JimSibley, Jun 6, 2022.
  1. JimSibley
    JimSibley
    Man, there are a lot of bad*** 3 pedal got rods on here.
    chevy57dude likes this.
  2. 57Custom300
    57Custom300
    from Arizona
    61 Top loader 4sp. Currently installing a FE 427.
    57 avatar had a Yblock 292 5sp
    Atwater Mike and chryslerfan55 like this.
  3. Fabulous50's
    Fabulous50's
    from Maine
    This post has proven that most of us (me included) have OT gear boxes, and no one complains! More gears=more better!
  4. HealeyRick
    HealeyRick
    from Mass.
    chryslerfan55 and JimSibley like this.
  5. boozoo
    boozoo
    I'm working on it.... it aint easy cramming a clutch pedal in a T but it's getting there.
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    I found it to be fairly simple , what are you having problems with ?
  7. Flatrod17
    Flatrod17
    I had no problems putting in clutch and brake pedals in my T, its where do I put a gas pedal! I am still working on that. Need to put the body back on first.
  8. JimSibley
    JimSibley
    The healey has a small block chevy and a muncie 4 speed. The ch***is is 4 inch round tube chromoly, and the suspension is all corvette that has been narroed to fit under the little body. 0ABE7CF2-05B9-48AA-B8A0-C41D0E1CF9E2.jpeg
    M20 going behind a 322 nailhead in a '34 Chevy..
  10. DDDenny
    My M-20
  11. HOTRODNORSKIE
    HOTRODNORSKIE
    Here's one more of mine a 35 olds I'm putting a M21 behind a 303 rocket. 20220612_152721.jpg
  12. boozoo
    boozoo
    When I started, the column was right in the middle of my feet and it had a transmission hump the size of a whale (gl*** '27 roadster body...no idea who made this one). Since then, I've cut the hump out since the Nailhead bell and Muncie only need a small hump up on the firewall. The column has moved up a few inched which helps too.... so it's looking a lot better. Now I just need to make some pedals or figure out if I can make use of whats already out there.
    chryslerfan55 and 2OLD2FAST like this.
  13. Sonofabob
    Sonofabob
    My little roadster has 3 pedals :cool:
  14. deucemac
    deucemac
    Well, I guess I will enter the fray here. I have the oddball trans of the week, month, and maybe the year in my avatar roadster. I am running a 354 hemi and attached to it via a Wilcap adapter is a 1976 AMC Pacer overdrive transmission. When I say that as a reply to anyone that asks, I usually get a blank stare or a surprised "WHAT?". To explain, when I built this car, I knew I HAD to have three pedals. I worked for the Border Patrol as a mechanic in the mid 70's and se used Jeep Cherokees with Ford full syncro 3 speed transmissions, Jeep called them T150. They differed from Ford in that they used a top shifter much like 39 and older Fords did. I wanted to get a Ford full syncro 3 speed with overdrive and add the Jeep top cover. I called a friend of mine at Stick Only in the SF Valley, and asked Gordon, the owner, "what years did Ford make a full syncro 3 speed with overdrive ? ". To which he replied, Ford never did, overdrives were on the way out at that time, so if you wanted an overdrive Ford only offered the sliding gear 1st with the old Borg Warner unit attached. Then he said, "But AMC did!". I didn't realize that AMC not only used the Ford 3.03 trans in Jeeps, but in p***enger cars. Gordon told me that AMC offered fully syncro 3 speed overdrive transmission in Pacers, Gremlins , and Hornets for three years only, 1975-1977. They weren't that popular and were rare. It turns out that AMC got the transmissions from Ford and the overdrive units from Lay**** De Normanville, you know, Jags, Volvos, Astin Martins, Austin Healys and such. After a short search I found a complete unit at Turner's auto wrecking in Fresno ( don't bother checking, I got the only one Jerry had). I bought a T150 top shifter ***yria off Ebay, rebuilt the trans (just because I wanted to be prudent) removed all the side shift parafinalia and plugged the holes in the case. I installed the top shifter and VOILA!, I had an early looking modern trans with electric overdrive. Not only that, everything for the trans is available as a Ford part and overdrive parts are available through Gearvendors since they bought out Lay****! Evert hung I should need is available except the factory AMC adapter from trans to overdrive is an off the shelf item . I installed it in the car and the shifter sits less than 1" from where the original 32 shifter had come through the floor! I added a 36 Ford parking brake ***embly and it appears old time, yet everything is modern. I wired a red lighted switch to the O/D solenoid valve and it works quite slick even after almost 14 years and 40k miles. I have a Ford 9" trac-lok with 3:70 gears and it is the best of both worlds ! Even a stock 32 Ford shift knob threads right onto the Jeep shift lever! A fellow I know in the LA Roadsters has one in his deuce roadster and has made two trips around the perimeter of the US with no problems at all. I will be at the LARS Father's day meet this year. If you want to see what I have done, just look for a Washington Blue 32 hiboy with a hemi hanging over the frame rails and 14x31, Firestone double diamonds sprint car tires on the back. Stop by and say hello .
  15. Splitbudaba
    Splitbudaba
    9622D699-1C28-44AA-A8EA-B1FD4F409BD1.jpeg Here’s my Hurst that rows the gears in my 81’ Super T10. Cut the shifter most of the way thru, bent it for clearance and welded it up. This version of the T10 has a 3.42 first gear. Guess it’s good I put in a quick change and 30 inch tall cheater slicks!
  16. 6sally6
    6sally6
    T-5 rowing-machine in my "M-word" hot rod! (Of course!!!!! It's a hot rod after all)
    6sally6)
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    I cut my pedals out of 3/8" cold rolled with my sawzall , 1 blade each . my right heel is at the juncture of floor to trans hump . gas pedal is actually over the trans hump ! Just lean your foot at an angle . The only good thing about working with previous work , is you can see whast didn't work ... Oh wait , that's engineering !
    boozoo and chryslerfan55 like this.
  18. HealeyRick
    HealeyRick
    from Mass.
    Very cool, bet it flies. BTW, you have the chrome flashes on the front fenders on backwards, just flip them side to side. Don't want to anger any purists!
    JimSibley likes this.
  19. Busted Knuckles
    Busted Knuckles
    52 F1 Ford truck with Chrysler Hemi and a 4 speed here.
  20. chevy57dude
    chevy57dude
    Frankentrans as I call it. M22 ***embled from parts. Out of the El r ight now awaiting the new engine. 20220612_203334.jpg
    chryslerfan55 and High test 63 like this.
  21. JimSibley
    JimSibley
    Oh, thats funny. I just put them back the way they were when i got it.
  22. High test 63
    High test 63
    IMG_20210525_184342567_HDR.jpg IMG_20210925_222508388.jpg sm 465 in the AA '29, m20 in the roadster.
    chryslerfan55 and chevy57dude like this.
  23. Fabulous50's
    Fabulous50's
    from Maine
  24. blowby
    blowby
    from Nicasio Ca
  25. klawockvet
    klawockvet
    RTS in the roadster. T5 in the 40 and the F100. IMG_3136.jpg IMG_3793.jpg IMG_4431.jpg
  26. WB69
    WB69
    from Kansas
    Nothing but sticks in every hotrod that I've ever owned.
    Fabulous50's likes this.
  27. e z i
    e z i
    Good ol Saginaw 4 speed and a 327 in my 32.
  28. SS327
    SS327
    63 Bel-Air, 350, m20 Muncie and 2:73 rear gears. Got one hell of a top end!
  29. Lone Star Mopar
    Lone Star Mopar
    3 speed column shift on our 52 Styleline deluxe needs rebuilt but still runs as is and weve put maaany a slow mile on it as is.. Ive got a 261 w a T5 behind it and a 57 Chev rear and drivesahft ready to swap in that. I Still have the factory Saginaw 3 speed in my 64 C10 rebuilt and converted to floor a
    Shift. Id like another gear but it runs damn good w the 283 as is. Got 3 speed floor shift behind the 283 in Pops old 29 Coupe, it works great as is too ! Also have a fresh T5 Dad was going to put in it but the body has to come off for that and I dont even want to open that can of worms right now, It runs great as is so... Have the original Muncie 4 speed in his old 65 GTO also. Have a fresh one a freind built too so that will go in when I have the 389 rebuilt here asap & I'll likely swap the current one in my C10. The only cars we have that are automatics came that way from the factory and also are the ones my wife drives. Her 57 Chevy wagon we swapped the PG for a 700r4 same with the 64 Elco.
  30. If I didn’t know any better I’d say the boy is hooked ( addicted that is, he’s got it bad, the sickness that is)
    John Starr and chevy57dude like this.
