Technical 1960 F100 Front Brakes on 1940 Spindles?
Discussion in 'Traditional Hot Rods' started by Todd Wallin, Jun 1, 2022.
  1. Todd Wallin
    Todd Wallin
    Question about 1960 F100 front brakes. Will the backing plates and hubs fit on 1940 spindles? I see that the earlier (53-56) F100 components will fit with the Speedway bearing kit. Wondering about the 57-60 F100 stuff? Thx
  2. nobby
    nobby
  3. manyolcars
    manyolcars
  4. Todd Wallin
    Todd Wallin
    Yep I tried it. It's not even close. I did pick up a 51 F1 front end. They seem like they'll work.
  5. manyolcars
    manyolcars
    You can make them fit by cutting out the center of the backing plate and make a new center that fits your spibdles
  6. I think the spindle stub got shorter,and thicker from pictures Ive seen of the 57-60 front end.
    Todd Wallin likes this.
  7. Todd Wallin
    Todd Wallin
    I picked up a set of 51 F1 backplates, hubs, drums and the Speedway bearing kit. Hope this will work?
  8. nobby
    nobby
    Bearings on rock auto are two bucks each
  9. Nailhead Jason
    Nailhead Jason
    No, if you have a set and the shoes springs and hardware are good, you can put all that on F1 or F100 backing plates. I believe the wheel cylinders with work as well.
