Technical How much drop
Discussion in 'Traditional Hot Rods' started by Vern Lee, Jun 14, 2022.
  1. Vern Lee
    Vern Lee
    This is probably a dumb question but here goes , when you put a dropped front axle in a car , in my case a 31 Model A , do you get a true drop of what the axle is ? In other words if I put a 4 inch dropped axle in will I get a true 4 inch drop , no other changes , just the axle , or does it run more or less .
    thanks
    Vern
  2. I think you get less . I think originally they compared to a stock A axle that has about an inch.If you got another 3 inches by dropping you ended up with 4. In the end its a matter of oil pan clearance,and being able to get in,and out of driveways that count as well as not having the axle hit the ground if a tire blows.
  3. alchemy
    alchemy
    Answer is nope. They usually measure the overall drop, and don't account for any curve the stocker has. And every one is different.
    anthony myrick and High test 63 like this.
  4. krylon32
    krylon32
    from Nebraska
    For instance a 32 axle with a 4 inch drop actually drops the car between 2 and 2.5 inches from stock.
  5. Dan Hay
    Dan Hay
    Yeah I don’t why they do that. Doesn’t make sense to me, but usually a 4 inch dropped axle is around 2” over stock. Like other said, depends on the axle company, of if it’s an original being heat dropped.
    olscrounger likes this.
  6. dmar836
    dmar836
    Not a dumb question at all.
    D
    clem and High test 63 like this.
  7. Vern Lee
    Vern Lee
    That's very interesting , I think I need to go back to the drawing board on putting a dropped axle on the 31 , thanks guys , I would have been BUMMED out buying a 4'' dropped axle expecting 4 inches of drop and ending up with maybe 2'' , Seems to me they ought to be offered as what your final drop will be not just the drop of the axle , but that's just me , tanks again for the info .
    Vern
    High test 63 and Squablow like this.
  8. krylon32
    krylon32
    from Nebraska
    Dropped axle, Reversed eye spring, Flatter front cross member all combine to lower the front Go to Anson Axles Instagram page for a good look at dropped axles.
    clem likes this.
  9. 38Chevy454
    38Chevy454
    If you want 4 inches of drop from current height, and the dropped axle gives you 2 of the 4, then you need to do the rest with suspension. Such as a flatter leaf spring, reversed eyes on leaf spring, modified crossmember, as some ideas. Plus playing with tire height and wheel diameter.
  10. BJR
    BJR
    I think the drop is measured from the spindle centerline. so a stock axle has some drop built into it from the factory.
  11. adam401
    adam401
    The number on any axle is the distance from the top of the spring perch boss to the top of the kingpin boss. So on a stock model a axle if the top of the kinpin boss is 2.25" higher than the perch boss, and you have it dropped to a 4" axle, youve lowered the vehicle 1.75"
    If you install a reverse eye spring you lower the car the height of the eye which I believe on a 28-34 is 1.5" but maybe Im a little off I dont remember. Often though you are removing a worn out standard eye spring and installing a fresh reverse eye spring and it'll basically give zero drop haha.
  12. Eddie
    Eddie
    from Georgia
    Excellent question! I, for one, and many others just learned something.
  13. Dropped axle, reverse eye spring and flattening the crossmember are the common drop methods
  14. Vern Lee
    Vern Lee
    I'm familiar with a dropped axle and reversed eye spring but flattening a cross member is a new one I've never heard of that ?
  15. Vern Lee
    Vern Lee
    Just watched You Tube on a flattened cross member , Now I see what you were talking about , thanks for info ,I see speedway sells one that will lower the car 2''
    Vern
  16. Here’s a flat one compared to a what should be a 32
    Just Gary and panhead_pete like this.
  17. Vern Lee
    Vern Lee
    Thanks for the pics for comparison , you can really see the difference in them
    panhead_pete and anthony myrick like this.
  18. dmar836
    dmar836
    I would say that the cross member drop would be fairly nontraditional - at least for a kid in his parents garage back in the 40s/50s. They did all sorts of stuff with OA though.
  19. alchemy
    alchemy
    My brother has a 29 coupe with a 4" dropped axle, and a reversed eye spring. His tires tuck up very nice into the fenders. No need for a flattened crossmember on a full fendered A.
    05snopro440, olscrounger and dmar836 like this.
  20. HOTRODPRIMER
    HOTRODPRIMER
    My '32 pickup had a nice drop but I used a Ch***is Engineering 4" dropprd axle, a Model A flat crossmember, a mono reversed eye front spring, combined 6:eek:o/15 wheels and tires. HRP
    It was pretty low. HRP
    Stock
    Dropped
  21. Vern Lee
    Vern Lee
    this is my A I want to lower
    hfh likes this.
  22. alchemy
    alchemy
    So go stick a tape measure above your tire. Subtract two inches for the axle, one inch for the reversed eyes, and another inch for flattening the spring out a bit. Is that enough? Fairly easy to get another inch from flattening the spring even more. That enough?
  23. Vern Lee
    Vern Lee
    this is the look I'm after , I think a full 4 '' would do it
  24. Atwater Mike
    Atwater Mike
    In the 'old days', Marty Costello was thinking about buying 'Mor-Drop' axle co. from Mr. Moore.
    American Auto Supply had Mor Drop axles on the wall, exchange basis: $10.95, '28-'36.
    I took my stock '36 axle down to Mor-Drop, and the old man laid my stock axle under a dropped one.
    The drop was 2-7/8". That was his standard drop.
    I have 2 of those original dropped axles today. One under my '27 tub and one under my '27 Highboy roadster.
    Checked them the other day, they are both 2-7/8" drop over stock '36.
    Other people's drops may vary...but this was the Oakland Standard.
  25. dmar836
    dmar836
    So Vern, this has been covered before but I just took a few measurements for some one-stop numbers.
    Taking the measurements from the spring perch bosses up to the top of the kingpin bosses:
    >The stock A axle is 1 3/8"
    >The Okie Joe 4" dropped A axle is, go figure, 4"
    >Stock '35 axle(a common swap) was 2"
    I used straight edges for the dropped A and '35 axles and nylon strings on the stock A as it is a runner. These measurements are about as precise one might get on a built car. I would trust them for anything I would order.
    So a 4" drop axle on a Model A is 2 5/8" overall drop from stock. I asked OkieJoe about that when we flew over there. He said 4" was and is the most common drop because, "It just works and looks so good."
    Your A is already awesome but I actually think the 4"(2 5/8") drop would look great on your A! If you didn't like it, it would be an easy swap and sell. A new front cross member would be a lot of unnecessary work and possible spring interference (IMO) for what you could easily get from a 4" dropped axle, reverse eye spring, and your present tire combo.
    Save your time and money - you are way closer than you think!
    JMO,
    D
    fiveohnick2932 likes this.
  26. Vern Lee
    Vern Lee
    dmar836 , Thanks for taking the time and effort to take these measurements , it helps a lot.
    Vern
    dmar836 likes this.
  27. Ned Ludd
    Ned Ludd
    That's good information right there: thanks. The way axle drops are described is very ambiguous, and doesn't tell you a lot if you don't have an axle in front of you.
    dmar836 likes this.
  28. twenty8
    twenty8
    I would guess that the wheel/tire diameter is smaller on this one, giving a bit more drop.
    NoSurf likes this.
  29. sloppy jalopies
    sloppy jalopies
    buddy had a stock spring and a de-arched one... looked to be about 1.5" difference...
  30. Vern Lee
    Vern Lee
