Technical ***June 2022 Banger Meet Thread - June Already?***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jun 1, 2022.
  1. 25mercury
    25mercury
    Retson, what's the oil pump off your front cover off of ?
  2. I wish! Highschool sports left me with a bad back.
    Good question, I have no clue. There isnt any markings, but I plan on tearing it down!
  3. I know this is more about hopped up bangers , but would anyone have a parts drawing showing the order of ***embly of parts for the input shaft for an early gearbox with a multi plate clutch?
    Trying to track down a reason for the shaft to have excessive end float.
    Thanks for any help, I’ve also asked on the barn ,just putting it out there.
  4. Fabber McGee
    Fabber McGee
  5. Fabber McGee
    Fabber McGee
  6. Thanks Fabber McGee, that’s exactly what I was looking for, very much appreciated.
  7. Savage Coupe
    Savage Coupe
    from Washington
    Late night banger activities.
    Jet96, Old Dawg, v8flat44 and 9 others like this.
  8. Up to no good I can ***ure you.....
    Damn nice looking, J
    Savage Coupe and Dustyp489 like this.
  9. Thanks Fabber,
    Got this from another member on the barn, which was what was missing.
    Obvious to some but not to whoever built the gearbox in my banger.
    “The on'ly protection the multiple disk clutch has is the addition of two extra oil baffles just forward of the transmission front bearing.”
    Thanks again, it may help someone else also.
    Jet96 likes this.
  10. Dustyp489
    Dustyp489
    Now that is something to get me moving again
  11. set me on fire
    set me on fire
    The local shop I brought my motor to for overhaul called and said they didnt have the proper machine to do the line bore for the crank journal bearings so I collected my stuff and drove up to Berts in Denver and a month later get the call the block is no good..bummer. so I put out a call to the model A club and a more than geneous member gave me 3 blocks. All have issues but Im banking on a 37 diamond block that has close to std bore and just looks to be in better condition than the other 2. Not counting on luck but crossing my fingers anyway 20220614_104806.jpg
    Outback, v8flat44 and Gerald Sleater like this.
  12. Crazydaddyo
    Crazydaddyo
    John, can you finish this one for me ? 20220619_161001.jpg 20220619_161009.jpg
    Outback and winduptoy like this.
  13. Did you get that from Troy at the roadster show? I ended up with the bare castings.
    Yeah, we can work something out, going to have to wait until after Bonneville.
    Was finishing up header for my car, much easier to just buy one.... 90 header 3rd attempt.jpg
  14. He had some cool Kong pans, but those blank front timing cover castings were cool!
    winduptoy likes this.
  15. Crazydaddyo
    Crazydaddyo
    Yes, It should fit my crank and rods nicely.
    No hurry. Fit it in when you can.
    If you want it done right ....... You have to do it yourself, It looks good!!!!
  16. F.A.S.T is starting up again! For those of you that hadn't jointed, here's the application that just came last week.
    Outback, Jet96, brjnelson and 4 others like this.
  17. modelAsteve
    modelAsteve
    Sent mine in the AM
    brjnelson likes this.
  18. 29 Speedster
    29 Speedster
    from Colorado
    Nice work on your headers. I like your work, our headers upload_2022-6-24_17-47-46.jpeg
    are similar.
    Outback, Dustyp489, Old Dawg and 2 others like this.
  19. 29
    oh ya baby, twisted curves of beauty!
    I am not convinced the tubing size on mine is big enough, just an experiment.
    John
    Outback and Old Dawg like this.
  20. Here’s one for y’all
    Outback, skip65, brjnelson and 5 others like this.
  21. winduptoy
    winduptoy
    New Burtz block IMG_20220624_183859216.jpg Had a couple of moments with it. The oil galley plug at the rear seeped...was able to reach in and back it out and then goop up with 620 Lock***e, what I should have used in the first place IMG_20220624_182022236.jpg then the rear counterweight hit the back of the IMG_20220625_160904154.jpg dipper tray...oil pan back off. At least it wasn't fatal.
    I'll let you know how it runs after break in
  22. Hi Retson, would you have any other photos of the drive area of the red Magneto drive?
  23. I can snap a few next time I'm at my parents house. This is a SM Smiley Martin drive, but for some reason it doesn't have the base for a mag or water pump. I'm a little confused still on what application this was used for.
    Outback and Barrelnose pickup like this.
  24. Thanks, looking at maybe fabricating one .
  25. Lots of interesting stuff here, any idea on the head, homemade?
    barobert likes this.
  26. Not home made that is a McKinney REM OFFY head sitting on a Donovan block
    About as radical as you as you can get
    J
    Outback, Dustyp489 and Crazydaddyo like this.
  27. winduptoy
    winduptoy
    IMG_20220314_102641721.jpg IMG_20220314_102719909.jpg IMG_20220314_102826903.jpg The photos I took before I sent it to him
  28. 283D2079-98AF-4CB3-A818-0B78D700AD49.jpeg C09B49D9-A58E-4214-9855-9200AC2EC9E5.jpeg Found it this weekend
    Ready for a mag to mount
    J
  29. winduptoy and Outback like this.
