Hot Rods Where and how did you mount your tach?
Discussion in 'The Hokey Ass Message Board' started by chop job, Jun 15, 2022.
  1. 26hotrod
    26hotrod
    from landis n c
    I have a header panel above my windshield. My rearview mirrow is mounted in the middle of the panel. I mounted my tach on the left side of the mirrow. With the low roof it is at eye level & I also use it for my speedo.............
  2. klawockvet
    klawockvet
    40 Ford: On a bracket under the left windshield moulding. Easy to read and functional
    28 Ford: On a drop down bracket under the dash. Almost useless.
  3. uncleandy 65
    uncleandy 65
  4. DDDenny
    I have the same tach. mounted in the same location.
    427 sleeper likes this.
  5. I’m out of town so I can’t get a photo, but I mounted mine where the clock used to be in my ‘50 Ford coupe. It’s not a race car, so I don’t need it right in front of my face.
  6. Everyone knows FRICTION tape is traditional!
  7. jnaki
    jnaki
    upload_2022-6-16_4-2-19.png 1958 Impala choices under the dash lip. The small arrow was the final choice.
    Hello,
    My brother did not want a tach for his new 1958 Impala as he learned to shift with the “sounds” of the motor, as taught to him by several well known speed shops in our neighborhood. (Reath Automotive, Joe Mailliard, Jack Ewell/Mickey Thompson) The time it takes to eyeball the tach is wasted time in all things involved in starting line procedures.
    Plus, the only ones we saw in speed shops were the big chrome Sun Tachometers. They looked good shiny and commanded attention, but he did not want holes in his dash anywhere. It also got in the way on the column like some other applications.
    There is just too much stuff to get lined up to race. (plus, a friend’s dad, a CHP officer said anything attached to the dash is not legal) So, the sounds are a part of vision forward and hand on the shifter. A great start with power and no tire slippage is a fast start. Then listening to the peak performance of the motor to shift to the next gear. The eyes are on the starting light or the drop of the arm at the elbow. The elbow moves first, not the hands up.
    almost half the size of a chrome Sun Tachometer...
    We had been going to the aircraft surplus yards near the local airport and jet building places. There were tons of surplus stuff around. But, the local yard guy, we came to know well, told us that there was a military surplus shop back on the outskirts of Bixby Knolls on the street near our house. We knew of the surplus store as we purchased some clothes, shoes and other stuff there.
    When we got there, the store manager knew what we wanted and brought out some of his stuff. The small black tachometer was half the size of a large chrome Sun Tach and was the right size to fit under the dash lip. No extra drilling required. It even had a built in light...
    When we held up the small black tach, the only thing it covered up was the right side end with the 120 mph. We pegged the 120 mark at the dragstrip, so that told us nothing. On the street, no one goes 120 mph. So, the small black tach fit perfectly.
    Jnaki
    The column shift did not hit or get close to the tach, so it shifted smoothly every time. When we were able to get the C&O Stick Hydro installed later, the stick just did its positioning for each gear or just in "R" for race… ha, just kidding… “D” was more like it. It shifted like no other and now, it was stomp on the gas and hang on in a straight line to the win.
    The C&O Stick Hydro gave us the advantage over other stick shifts, ( 3 speed/4 speed) as they had to content with coordinating everything from the floor, pedals, and shifting levers. The Stick Hydro just jammed forward and did its own shifting when necessary. We could do manual shifting, but the power to gear ratio was too short and the advantage was to use the “D” for all gears in the quarter mile adventures. YRMV
    TerrytheK and VANDENPLAS like this.
  8. Just Gary
    Just Gary
    Hose-clamped to the column. Ho-hum...;)
    lothiandon1940 and chevy57dude like this.
  9. 1971BB427
    1971BB427
    from Oregon
    On the A pillar for my Austin g***er, but typical steering column mount for my '39 chev coupe.
  10. Jkmar73
    Jkmar73
    from Tulare, CA
    I have an OT car and mounted the tach under the dash angled towards the driver.
  11. CME1
    CME1
    Greenblade likes this.
  12. fleetside66
    fleetside66
  13. Black_Sheep
    Black_Sheep
    I have no imagination…
  14. Whatever! That is a dam clean install! Block drilled and tapped?
    Hotrodmyk, i7083 and Blues4U like this.
  15. fleetside66
    fleetside66
    I'll second that....very nice (and traditional).
    Blues4U likes this.
  16. Blues4U
    Blues4U
    from So Cal
    I have one mounted on the steering column in my 30 pickup, almost useless down there. I've thought about moving it up on top of the dash rail but thought I'd look too much like a poser with it up there, cause it's not a drag car. I still might move it up anyway, just so I can see it better, and to hell with what anyone else thinks.
    lothiandon1940 likes this.
  17. Blues4U
    Blues4U
    from So Cal
    I'll third it! :D Very clean
  18. i7083
    i7083
    @Kelly Burns that was the first thing I noticed, too! Very clean!
  19. Black_Sheep
    Black_Sheep
    Yes, with a strip of 3M industrial strength 2 sided tape for good measure…
  20. rusty1
    rusty1
    in my 37 Chevy coupe, the best place for it.
    vtx1800, Just Gary and swade41 like this.
  21. Jalopy Joker
    Jalopy Joker
    nobody has mounted one from behind? behind the dash that is
  22. I'm doing in dash but it's still in the early stages
  23. Ned Ludd
    Ned Ludd
    For me, a tach should ideally be in the dash and directly in front of me, where uppity OEMs usually insist on putting the speedometer, and as big as is practical. The speedometer could almost be in some obscure corner, as far as I'm concerned. That works with the way I drive.
    It's not part of any build I'm planning, but converting an interesting '50s speedometer with an unusual action into a tach, and then mounting a tiny speedometer in an under-dash accessory gauge panel is just the sort of thing my perverse stubbornness might do.
  24. vtx1800
    vtx1800
    The Studebaker Hawk Dash had a place for a tach, the 38 went to the top center of the dash.
    mgtstumpy likes this.
  25. MCjim
    MCjim
    from soCal
    mgtstumpy and LAROKE like this.
  26. RmK57
    RmK57
    Hose clamp on the column. I have one of those cigar shaped adjustable shift lights I'm thinking of using to replace the one here.
  27. TerrytheK
    TerrytheK
    Nothing wrong with your tach mount, but I REALLY like your "shifter boot"! Great idea!
  28. TerrytheK
    TerrytheK
    My car is absolutely no race car, so no need to keep an eye on the tach. Hid it low on the left side in the traditional "knee-knocker" position. I can glance at it through the steering wheel spokes if I want to see what I'm turning.
  29. Hank37
    Hank37
  30. Pete1
    Pete1
    from Wa.
