Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. RICH B
    RICH B
    Hung around the fairgrounds visiting with old friends and watching cars go by.
  2. swade41
    swade41
    from Buffalo,NY
    I like that, I've got a 41 with a dual quad big block in it myself.
  3. mgtstumpy
    mgtstumpy
    Finally removed the FE today and installed new freeze plugs as incorrect ones had been installed when engine was put together, 1 3/4" and not 1 49/64", causing a slight weep. There was NO way they could be replaced without removing engine, there was just NO room whatsoever! :( The freeze plugs came out easy being undersized with the new ones fitting a lot more snug. I flushed the block beforehand and washed some residual crud and scale out. Hopefully my cooling issues are now addressed.
    Car is now a roller and back on hoist where I trimmed the transmission tunnel because the shifter rods were touching the metal. Again, another thing that wasn't done properly when the car was built, not by me. T10 goes back in tomorrow using a borrowed transmission jack that I used to remove it. Once car is running the 35 Chevy goes onto hoist as the 700R is toast and needs to be removed for a rebuild. That borrowed jack will come in handy for a second time. ;)
  4. nochop
    nochop
    from norcal
    Lil32, 210superair and j hansen like this.
  5. Flathead Freddie
    Flathead Freddie
    Hi Everyone !
    Finished shaping Flo's valve bowls on Cyl 5 and stretched out the bowls in 6 and 7 leaving 8 stock for comparison till others are smooth . Then went to Torrance Industrial for a homemade mandrel for barrel sanding and got a Dorney 80 grit flap wheel . That's it for today just pulled up to the beach now have a good one ,
    chryslerfan55 and j hansen like this.
  6. Went to move the project 34 Victoria to the back of shop, cross ways, to give me room to park the 47 coupe in the garage. Car was up on stands on wheel dollies, something didn't like the move, and went over sideways. No one hurt, small dent in rear quarter panel lip(beside a rust hole), and now it's settled in it's new spot. And lower to the ground!
  7. mgtstumpy
    mgtstumpy
    Transmission tunnel trimmed, engine installed with car back onto hoist for transmission installation. Shifter readjusted (White rod). I'm just waiting for new idler arm bushings, PS steer are different to MS. Header installation is next once drag link is replaced before moving onto removing auto in 35 Chevy. 288706926_556200752622646_848565631732656742_n(1).jpg
  8. 210superair
    210superair
    from Michigan
    Finally figured out the infernal rattle my car has been making. I've been trying to guess what was rattling when I hit bumps for th last few months. As always, occam's razor rules and it ended up being the lake pipe bolts had come loose. Car sounds tight and right again.
  9. milwscruffy
    milwscruffy
    Started this 3 weeks ago today and should be off the jig by the end of the week. 1932 Plymouth ch***is for a good buddy of mine. Pretty basic, partly boxed, and 1/8 " out of square over 132", so not bad for a 90 year old frame done by a couple of 60+ year old geezers ! Also of note for MOPAR fans, it'll have a 318, 727 trans and 8 3/4 rear out back. So an all MOPAR build, which isn't all that common in today's world. IMG_0338.JPG IMG_0339.JPG IMG_0340.JPG
  10. Bad Bob
    Bad Bob
    from O.C. Baby
    I redid my red tint. After about 6 months it fades to orange. I'm actually getting better at it! Haha Less bubbles.....
    40two, RICH B, Blues4U and 3 others like this.
  11. HookNBoogie
    HookNBoogie
    Yesterday, I finished up my kingpins. Reamed them out, fit them, ***embled the spindles with backing plates and hubs. Tried to finish ***embling the front end, found a couple small hiccups with the F1 brake conversion. So, today, I started addressing those issues, but it became too hot to work outside (105 degrees). Now to wait for this evening to cool down a little.
  12. nochop
    nochop
    from norcal
    40two, High test 63, Lil32 and 5 others like this.
  13. lake_harley
    lake_harley
    fastcar1953 and Hamtown Al like this.
  14. nochop
    nochop
    from norcal
    Your probably right, I’m posting on two or more threads. I think I’ll just keep posting to my build thread “blowing this thing apart” save some bytes.
  15. fastcar1953
    fastcar1953
    @lake_harley Now that the shows over am I'm rested got some work done. first coat. Sealer. Paint soon I hope. 289632612_5578633172160923_3768469921224680811_n.jpg 289789802_5578634465494127_8627893936655955736_n.jpg 290323561_5578635582160682_4798774002217701175_n.jpg 290868644_5578633668827540_9049674725092317036_n.jpg
  16. lake_harley
    lake_harley
    You're going to have a very happy bride when you get her Nova back on the road!
    Lynn
    chryslerfan55 and fastcar1953 like this.
  17. fastcar1953
    fastcar1953
    Yes I will. I will be happier though. A lot of work for such a little car.
  18. SpeedyAtkins
    SpeedyAtkins
    Gave the 50 a bath, flushed the radiator and drove it around for about an hour to see if the water wetter stuff actually made a difference. Actually seemed to help with the Florida heat.
    Came home, and scrubbed out 70 years of dust from the trunk in preparation for the new whitewall spare that’s gonna live back there.
    chryslerfan55 and Blues4U like this.
  19. I drove my avatar to work today ( blasted thing had 6 months of tree pollen on it, aaaachhoo!) after work I came home and proceeded to remove the aforementioned tree pollen, I now feel better.
  20. Blues4U
    Blues4U
    from So Cal
    20220627_200824b.jpg Test fitted new wheels I picked up at the swap meet at LARS this month. Now to decide what tires to run on them, I'm leaning towards some cheater slicks from Towel City on the back (but I will entertain any suggestions, rear wheel size is 15 x 8 1/2; front is 15 x 6.
  21. If you’re going to run cheater slicks ya gotta do at least one burnout. Just sayin.
  22. guthriesmith
    guthriesmith
    Drove to work then took the boys out to eat at this strange looking place on Route 66 with a big pop bottle out front. :rolleyes:
    B274CCF1-82B7-4790-A812-073C46F56116.jpeg E929DEAD-9001-43EA-B7D6-861132A333A2.jpeg C5F7A5D0-6089-4960-B477-4BED6160D9FE.jpeg
  23. spanners
    spanners
    Good to see those younguns are doing what they do. Staring at their phones instead of watching the scenery go by.
    High test 63, Lil32, LAROKE and 3 others like this.
  24. guthriesmith
    guthriesmith
    No doubt. Thankfully, these do actually enjoy the scenery too. I just happened to catch both of them obviously looking at something more interesting than cars on the highway...:rolleyes:
  25. spanners
    spanners
    It's good they are along for the ride at least.
    Blues4U and guthriesmith like this.
  26. vtwhead
    vtwhead
    We have eaten at Pop's several times. Neat place especially at night when the bottle is all lit up.
  27. guthriesmith
    guthriesmith
    Yep, us too. Nice that it is only about 30 minutes from where we live. I think my son only wanted to go there so he could get a bunch of different kinds of pop. :D
  28. Rusty Heaps
    Rusty Heaps
    78AC9F4E-82D8-4193-86BE-3A8522854114.jpeg FC1C3B2D-209F-4DC0-877A-669634CA8691.jpeg Prep work for the paint job.
  29. Blues4U
    Blues4U
    from So Cal
    that's cool, I dig it. But maybe it should go in the Antiquated forum instead of here. The mods get touchy with off-topic photos and discussion. This thread has been closed once before because of that.
    Hamtown Al and j hansen like this.
  30. jimmy six
    jimmy six
    Purchased the rubber inner fender panel to upper A-arm years ago but never found the Ford part #16050 brackets to mount them and decided to fab my own. Didn’t think about the front end being lowered 2”. Made a difference and the deflectors look pretty good. P***enger side was a pita due to the AC pump and lines. Just something for a bored retired guy to do. 6DB37C5F-E67E-4326-8169-3AE7AD758E3B.jpeg
