SOLD ---348 Tri-Power, 3 Deuces, 6 Pack, 3X2, Hotrod, Rochester 2bbl, Street Rod
Discussion in 'Parts For Sale' started by Highboy32ford, Mar 29, 2022.
  1. Highboy32ford
    Highboy32ford
    City: SHREVEPORT
    State: Louisiana
    Price: SOLD
    Rochester Tri-power.....with Vintage Speed CNC machined Billet aluminum throttle bodies providing lapped ****erflies giving the best measure against air intrusion for a problem free idle. These have all new shafts, correct secondary throttle plates, correct Progressive linkage, carb arm and heavy duty torsion return springs. All three Rochester 2G's (small base) are remanufactured, coated in RED BARON and configured to function as a tri-power. Carbs are Ethanol fuel ready. These carbs have the popular side fuel inlets and will mount on Offenhauser, Edelbrock, etc. tri-power intake manifolds with a 4 bolt pattern and carb spacing of 5-1/2". Bases hole pattern are 3-1/4 x 1-7/8. Primary carb has the popular and correct electric choke housing. 3 Deuce setup for a Small Block, including Polished Progressive Linkage, Polished fuel lines w/satin fuel block and chrome air cleaners w/bases and filters. Total setup is about 775 CFM.
    CENTER CARB MODIFIED WITH:
    New Electric Choke
    Idle tubes enlarged to .034
    Power Piston Modified for Tri-power
    Mixture screw orifice enlarged to .050
    New extended br*** throttle rod with screws and primary throttle plates
    Jetted at .056 for 350 to 400+ci modified engines
    New fuel filter
    Cleaned and remanufactured with new Walker carb rebuild kit
    Center carb has your choice of manifold or ported vacuum inlets + power brake or PCV option. Fittings included.
    2 END CARBS are MODIFIED to FUNCTION AS SECONDARIES
    CNC machined Billet aluminum throttle body for small base Tri-Power
    New br*** throttle rod and screws with thicker(.080) throttle plates
    New driver and p***enger side linkage hardware - Polished
    New extra heavy torsion springs to ensure throttle plates close
    No choke plates
    No idle circuits
    No power circuit
    No mixture screws
    No vacuum inlets
    Jetted at .060 for 350 to 400+ci modified engines
    New fuel filters
    Cleaned and remanufactured with new Walker carb rebuild kits
    Shipping is actual charge in continential U. S. Set up for progressive linkage. Questions? Send a message.
    51 mercules likes this.
  2. Highboy32ford
    Highboy32ford
  3. Highboy32ford
    Highboy32ford
  4. Highboy32ford
    Highboy32ford
  5. Highboy32ford
    Highboy32ford
  6. Highboy32ford
    Highboy32ford
  7. Highboy32ford
    Highboy32ford
  8. Highboy32ford
    Highboy32ford
  9. Highboy32ford
    Highboy32ford
  10. Highboy32ford
    Highboy32ford
  11. Highboy32ford
    Highboy32ford
  12. Highboy32ford
    Highboy32ford
  13. Highboy32ford
    Highboy32ford
  14. Highboy32ford
    Highboy32ford
  15. Highboy32ford
    Highboy32ford
  16. Highboy32ford
    Highboy32ford
  17. Highboy32ford
    Highboy32ford
  18. Highboy32ford
    Highboy32ford
