Art & Inspiration VALVE COVERS
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jun 21, 2022.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Yes, I am aware there is a ongoing thread about polishing valve covers but say a guy doesn't want them polished rather he looking for something different, something toned down, something painted or striped, possibly he might be looking for something more , dare I say TRADITIONAL like a orange SBC 327 valve cover with the HP emblazoned on the valve cover.
    Let's see what you have done, btw if you have polished valve covers that's cool, post them if that's what trips your trigger.
    My original intent was to polish the factory aluminum valve covers that were on the 302 engine that I purchased from my late friends wife to power the Ranch Wagon, believe me they were nasty, but the inside of the engine was clean.
    I used easy off oven cleaner to degrease them and followed that up with a trip to the sand blasting cabinet, then I started sanding and about half way through the first valve cover I sat it on the freshly painted engine and realized the valve covers were going to stand out more than I wanted and become a focal point.
    I wanted to keep it looking simple and give the illusion that it could have been stock, granted most gearheads would instantly know it isn't stock but I was shooting for simplicity.
    I decided to paint the valve covers the same color as the engine, and to high light the raised portion & writing on the valve cover I used sand paper and a buffer to remove paint in the area, I even carried this through to the aluminum aftermarket breather in a attempt to keep everything looking as though it was meant to go together.
    Please share what you have done. HRP
  2. I like that!
    Ben
    Spooky likes this.
  3. kabinenroller
    kabinenroller
    I wanted to retain the factory aluminum valve covers on my Boss engine in the Cyclone but they had a small tower screwed to the top center that held the spark plug wires. I rerouted the wires, milled an aluminum rectangle that is attached to the valve cover using the existing holes then mounted a “Cyclone” interior door emblem on the aluminum plate. It looks clean and is something that no one else has.
  4. HOTRODPRIMER
    HOTRODPRIMER
    That's the kind of stuff I'm talking about, it's subtle and looks as though it could have came from the factory like that. HRP
  5. catdad49
    catdad49
    Clean, subtle and easy maintenance!
  6. 57 HEAP
    57 HEAP
    Valve cover on my "Corvette" 327.
  7. dana barlow
    dana barlow
    from Miami Fla.
    I really like shiny!! Fins that are shiny are extra cool to me.
    If only the fins are shiny with a nice back ground color=that very cool too!!!
    I wish I had a pic of the last set of alum fin Ford 5.0 that I did. I used Crinkle Finish black for the back ground and polished the fin tops after.
    :D
  8. At first glance these are just generic chrome covers but there is a subtle change:cool: B83354F0-6C67-416A-9290-107C03B37994.jpeg
  9. What change is that Scotty ?
    All I see are factory” Plymouth” Hemi valve covers .
    Look great ,,,you did a good job !
    Tommy
  10. Rickybop
    Rickybop
    I decided a long time ago, that in certain instances, I might like the simple look of standard stamped sheet metal valve covers painted the same color as the block better than shiny aftermarket aluminum.
    But I've got these. And I really like when they're nicely finished. So I'm going to polish and detail the #@%*×&! out of 'em. :D
  11. Ooooh boy,,,,,,I like that,,,,,tall deck Mopar !
    I like that intake too !
    Tommy
    Rickybop and dana barlow like this.
  12. The subtle change is " PLYMOUTH". Plymouth didn't have Hemi engines until the 426" was available.
  13. I'd like to do something like that putting the "Cheverolet" script into a set of big block valve covers.
  14. DDDenny
    Easier just to keep the small block!
  15. Did i spell it correctly?;)
  16. Awesome! That makes me feel good, I was thinking about something long those lines. A buddy thought I was going to cut the script out of a set of SBC covers and TIG it into the BBC covers. I figured that the writing would look really out of proportioned, so I would about machining (I'm a tooling designer) a set of dies to stamp it, after I resized the writing in SolidWorks to be a good proportion. NOW, you got me thinking a little, since I don't want 2K and 120 hrs. in a set of valve covers!.
  17. Dave Mc
    Dave Mc
    73 SBF had these Cobra Covers, I was told I could still use them on the replacement engine= 87 Roller 302 if I'd just remove the baffles, But I decided to buy the Larger Valve covers to accommodate the roller Rockers, Still prefer the look of the old ones though
  18. Spooky
    Spooky
    I have always liked OEM valve covers. I am using a set of '58 E 400 on my '59 Edsel Stranger project. AND- yes- scored one of those killa oval air cleaners and created a emblem to match the theme of the car.
      151.1 KB
  19. rockable
    rockable
    These were pretty rough when I got them. My powder coater made them look great, IMO. The black is powder coated, as well. 1007211506_HDR.jpg
  20. BamaMav
    BamaMav
    from Berry, AL
    I’ll have to come back and add a pic, but I took a set of chromed steel covers and put a official looking Power by Ford 302 decal on them. They look like they could have come from the factory.
  21. Joe Troilo
    Joe Troilo
  22. KKrod
    KKrod
    Clean and simple but a lot of work. I think I got the idea after my first trip to California in the 90's and seeing Isky's Maxi headed beauty. Lol IMG_5481.JPG
  23. Lloyd's paint & glass
  24. nochop
    nochop
    from norcal
  25. Just Gary
    Just Gary
    Nice. Steve's deuce 5W?
  26. goldmountain
    goldmountain
    I like the look of finned aluminum valve covers with paint between the fins but was worried about the paint sticking so instead of paint, I used red reflective tape; the type that is stuck on the back of school buses and such. Spent a long time making a template to cut out the "Corvette" lettering. Turns out, the tape doesn't work that well either. I'll get it right one of these days. IMG_1464.JPG
  27. Rickybop
    Rickybop
    It's a paint to bling ratio thing.
    Ned Ludd, raven and scotty t like this.
  28. cabong
    cabong
    Simple, no frills.....This is what the mill in my Model A looked like in 1968, and today..... Carb was from a 271/289, intake is a Buddy Bar Casting from a Cobra, and I have not a clue who made the valve covers... 289 002.JPG
