Projects Jalopy...which motor...which steering box
Discussion in 'The Hokey Ass Message Board' started by alphabet soup, Jun 23, 2022.
  1. I have been working on this Model A, C-cab, Jalopy type thing for a while. My uncle was supposed to take it, but has backed out. Not sure what I am going to do with it, but I do know it needs a differnt motor-trans combo. The motor builds coolant pressure, looses OP and smokes when hot. And the Fordomatic leaks from every hole. Right now I have to choices, a '67 283 and PG that runs really good or a 2000 Pinto and C-4 thats about the same. I can get either one for about $400. What would you guys do?
  2. Speed Gems
    Speed Gems
    You forgot to set up a poll, but I'd go with the '67 283.
  3. lothiandon1940
    lothiandon1940
    Same here. That 283 would look right at home in there.:)
  4. 3W JOHN
    3W JOHN
    One of the best sbc ever built, go with the 283. HRP
  5. chop&drop
    chop&drop
    122 c.i. or 283 c.i.? Definitely the 283.
  6. Jalopy Joker
    Jalopy Joker
    What rearend in it? Home made frame? Strong enough for V8 torque?
  7. loco55
    loco55
    283 for me.
    alphabet soup and Tman like this.
  8. 57JoeFoMoPar
    57JoeFoMoPar
    The 283 all day
    alphabet soup, SS327 and Tman like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Wait!, this must be one those who want's ice cream questions asked by Bobby's mom and to all his friends as well.
    [X] Yes = 283
    [O] No = That other engine
    chryslerfan55 and alphabet soup like this.
  10. rpu28
    rpu28
    from Austin
    alphabet, there are roughly one gazillion rods out there with SBC; I'd go for the Pinto engine just to be different.
    But that's me. I'm an aggressive gambler. Mr. Vegas.
  11. jimmy six
    jimmy six
    283’s didn’t have any torque. 2000cc Pinto engines belong in dirt track mini stocks.
  12. No brainer................
    alphabet soup likes this.
  13. MeanGene427
    MeanGene427
    from Napa
    There's a guy here in town that has three different Model A's with turbocharged Pinto engines, run very well, very clean installations, and draw a lot more attention than belly-****on engines
    SS327, alphabet soup and partssaloon like this.
  14. chevy57dude
    chevy57dude
    283 is traditional!
    Great, great little engine.
  15. chessterd5
    chessterd5
    from u.s.a.
    Is it the aluminum powerglide?
    Then I would go with the 283. There is so much different power options depending on how you want to build it. And if cost is a factor, I don't think you could build another brand of engine cheaper than a SBC.
  16. J. A. Miller
    J. A. Miller
    from Central NY
    283
    Pintos are beans you put in your chili.
  17. Copy cats, copy cats!!
    Pinto
    Ben
    warbird1 and alphabet soup like this.
  18. 5window
    5window
    I'd vote for the 283 but the frame question is valid. Hard to tell from one photo, but it looks a bit small.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    there are no pinto parts, including their IFS that belong anywhere near a hot rod... yes 283
    -Brent-, 26 T Ford RPU, Paul and 12 others like this.
  20. SS327
    SS327
    283 and a 4 speed!
    alphabet soup and chevy57dude like this.
  21. jimmy six
    jimmy six
    So does every model A’s to me.
    If left alone a 67 283 has 195hp and and an aluminum PG. Paint it orange with a stock black air cleaner and it definitely wouldn’t look like ANY typical SBC; instead it would look like you removed it from a wrecking yard in 1968..cl***y.
  22. lothiandon1940
    lothiandon1940
    ....That's hilarious.:):D:):D:):D:):D
  23. El Hueso
    El Hueso
    Here's your answer
  24. d2_willys
    d2_willys
    from Kansas
    Model A? Wouldn't that be a FURD! So, why not go with a 302 and C4 or AOD or even a stick? Besides the 302 block is much narrower than the SBC. I know you have the 283, but that Powerglide, not good. If you do decide to go with 283 either use a Turbo 350 or a 700R4 or 2004R transmission. My preference to 283 with a dual range 4 speed hydramatic out of a chevy truck.
  25. chevy57dude
    chevy57dude
    The OP, Gene said the PG runs fine, light car it'll be great! Traditional engine, traditional transmission. No need to street rod the thing with modern AOD, or go to the expense of a stick. Not with a buy in of $400.
    chryslerfan55, Jet96, X-cpe and 7 others like this.
  26. Flathead Dave
    Flathead Dave
    from So. Cal.
    Why not freshen up the flathead? If not, I would go with the Pinto.
    I like to keep Fords as Fords.
  27. silent rick
    silent rick
  28. lothiandon1940
    lothiandon1940
    ....Well said.
  29. squirrel
    keep shopping
  30. Looks like an 8BA,,,,,,,those engines can be rebuilt !
    It looks good,,,,,it’s not terribly hard to go through one,,,unless you just have your heart set on replacing it ?
    The Chevy 283 is a fabulous engine,,,,,,,probably look right at home in there .
    Like the man said,,,,,,you should have added a poll to this thread,,,LoL .
    Tommy
