Technical max width tire on 4.5" wheels
Discussion in 'The Hokey Ass Message Board' started by karolko, Jun 23, 2022.
  1. karolko
    karolko
    Hi everyone,
    I posted a question yesterday about radial/bias ply tires on old bias wheels and got some great answers.
    I'd like to ask what people have successful run in terms of width on 4.5" wide wheels?
    My wheels are 16"x4.5" steel artillery from a 30-40's Dodge. would 700/16 or 750/16 be safe for the rears?
    Thanks a lot in advance
    Adrian
  2. clem
    clem
    Plenty on here have said that they have done it, ( even on the 4” wide rim with both size tyres - not much difference in them) and are happy with results.
    Personally I would go to a min of 5” rim which is what I am doing.
    Professionally, - the answer is go with the tyre manufacturer’s recommendation/specifications.
    Read this, also been a few other threads on this if you need more info.
    https://www.jalopyjournal.com/forum/threads/rear-tire-size-question.335238/.
  3. probably your headline should say tire instead of wheel
    Moriarity likes this.
  4. DDDenny
    ***le edit on aisle three please!
  5. 41rodderz
    41rodderz
    from Oregon
    So, max width tire on 4.5” tire ? :D
  6. 41rodderz
    41rodderz
    from Oregon
    Technically, it should be what maximum width tire in mm will fit on a 4.5” rim.:p
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    I edited the ***le. it used to say "what size wheel on a 4.5 wheel"
  8. 41rodderz
    41rodderz
    from Oregon
    Ohhhhhhhh:D
  9. theHIGHLANDER
    theHIGHLANDER
    7.00 is only 1½ past the rim edge at the widest point. I have 5" commercials and 7.00s, close to 1" over the edge of the wheel lip. For modern, you need to convert width from metric.
  10. 41rodderz
    41rodderz
    from Oregon
    Yeah , that is really just plain wrong :oops::D
  11. Nailhead Jason
    Nailhead Jason
    I've run 1000's of miles on 7.0 16's and 7.50 16's on 4.5 inch wheel No complaints here. The thing to remember is that you just don't have that much tread on the ground. with a 7.0 16 and a 7.50 tire the tread is only about 5 to 5.5 inches. Compare that to a 4.5 inch wide wheel, its no different that shoving a 255 60 onto a 7 inch Chevy rally on the back of a Camaro. The recommended rim widths for both size tires is 4.5 to 5.5 inches wide for the 7.0 and 5.0 to 6.0 wide for the 7.50. You will be fine. with those dodge rims.
    Flathead Freddie likes this.
  12. karolko
    karolko
    Sorry guys about the whacko job on the ***le. Thanks for rewording it.
    I'm trying to stay away from rebarreling a set of wheels, but may depend on tire contact patch as Nailhead Jason mentioned.
  13. Marty Strode
    Marty Strode
    7.50 16 on 4-1/2" wheel P1010001.JPG
  14. Dan Hay
    Dan Hay
    A696D2C4-1CDD-4A2F-AE93-6D6D51C36650.jpeg Yes it’ll be fine. 7.50 16 on a 4.5” rim on this one
  15. I have run 8.45-15 Firestone drag tire on a 15x4 wheel, on the front of a 3600 pound B-Body Plymouth with no problem. Gene.
  16. jimvette59
    jimvette59
    With that engine I would think the tire will spin on the rim in a quick acceleration. JMO
