Hot Rods Where and how did you mount your tach?
Discussion in 'The Hokey Ass Message Board' started by chop job, Jun 15, 2022.
  1. 427 sleeper
    427 sleeper
    I think it depends on the build. G***er style looks good on the dash. Street Machine style looks good hose clamped to the column. Personally, I prefer the column mount. :cool:
  2. Canuck
    Canuck
    Didn't want to cut any additional holes in dash or mount on top of dash. Made a bracket on lower left bottom of dash for tach and a starter ****on. Tach is a old 765 model with sender mounted with fuse panel. Six grand was enough for the Nailhead.
  3. I've seen you post this before, to me that is the epitome of cool!
  4. Ziggster
    Ziggster
    Some pics I’ve saved over the years for inspiration.
    9F54F61D-ACD7-4A0E-9B59-0757D871E91D.jpeg 63317D9B-6053-4C57-B619-A6A5A19C8333.jpeg F208FA91-457B-4DA4-99B6-D53BB5BF8FAF.jpeg 54EEC15B-3140-445F-BE1C-F35DAC7CB87A.jpeg 84B43734-238B-40EE-B770-D03C2C023EE9.jpeg
  5. 57JoeFoMoPar
    57JoeFoMoPar
    I put mine in the middle of the console. I retrofit these gauges into the car and didn't want to cut up the dash or otherwise have gauge panels hanging off the bottom of the dash. Obviously they're out of my line sight, but this isn't a performance application and just having them there will at least tell me what I need to know. IMG_5453.jpg
    Cooon and mgtstumpy like this.
  6. Ned Ludd
    Ned Ludd
    Ziggster likes this.
  7. donsz
    donsz
    Here is mine, on my 1957 pickup: cut up an exhaust pipe, welded it to the dash, and mounted a tach inside. Chrome bezel is from a metal travel cup.
    don
    Budget36, mgtstumpy, Bugguts and 8 others like this.
  9. HarryT
    HarryT
    20220621_141818.jpg 20220621_141700.jpg 20220621_141700.jpg Homemade mount under dash rail.
  10. Sky Six
    Sky Six
    from Arizona
    Mine is conveniently located near the other gauges. Please disregard the red line, it just looks impressive. If it ever got near 5 grand it would be raining pistons in Phoenix.
  11. On the dash, there was a half inch hole in the dash, I think for the radio antenna? I took a 1/2" by 1 1/2" carraige bolt put it in a lathe, ground the square off, then bored a 3/8" hole thru the center and chamfered the opening a little. I made a plate to bolt the tach to and used the bolt, some rubber and washers to bolt it to the dash in the 1/2" hole. Then I used the 3/8" hole to run the wires thru. Gene.
    Update...I started thinking about the hole size, thought 3/8 sounded a little big to me. So I went out and measured this morning. Correct size is 5/16". Memory please come back!
  12. theHIGHLANDER
    theHIGHLANDER
    I went under the instrument panel like a few others. Being the obsessive **** that I am sometimes I had to have the tach and 1953 Sun vac gauge at the same hgt and face angles.
    Sky Six, mgtstumpy, scotty t and 2 others like this.
  13. Joe Troilo
    Joe Troilo
    I didn't put it there but I left it there.
  14. loveoftiki
    loveoftiki
    from Livonia,Mi
    On the dash..Made a little mount out of aluminum, polished it, and used a screw from the speaker to hold it on, tach bolts to that..have it angled to face me…wrapped the wire and ran that through the speaker grill..
  15. saltflats
    saltflats
    from Missouri
    Mines mounted where I can't see it, not a big deal. I listen to the engine.
    427 sleeper likes this.
  16. Stllrng.
    Stllrng.
    Here’s mine. Not much special but it’s out of the way and yet I can still see it when I’m driving .
    Joe Troilo, Just Gary and mgtstumpy like this.
  17. mgtstumpy
    mgtstumpy
  18. Bandit Billy
    Bandit Billy
    On my roadster it's on the column in an aluminum cup
    No hose clamps on this one,
    On my OT dune buggy I stole an idea from @Moriarity on his wild *** Futurian. He didn't have anymore of these boat deck tach mounts in his inventory and the shop he purchased his cast aluminum ones from closed during the flu thingy and didn't reopen yet. So Mark sent me pictures and dimensions so we could built one.
    I purchased a 3" diameter,45 degree, stainless steel street elbow from Summit and chopped it off to fit and @Pist-n-Broke tigged up a mount plate with 3 studs to fasten it to the deck. A little door edge molding around the base and tach firmly secured with silicone. Liberal amount of polishing of course. The result is a cool hood tach that stares you right in the kisser.
  19. SDS
    SDS
    Skip the speedometer (who needs one anyways)...
  20. Dune buggies are kewl!:D
  21. choptop40
    choptop40
    Looking good on a hood....
    Bandit Billy likes this.
  22. 427 sleeper
    427 sleeper
    Vroom-a-Zoom-Zoom!!! :D
    Bandit Billy and scotty t like this.
  23. saltflats
    saltflats
    from Missouri
    In my Chevelle I gutted the clock and installed a tach in it. 12 o'clock is 0, 1 o'clock is 1,000 rpm and so on.
    Man I should get this one back on the road.
  24. 427 sleeper
    427 sleeper
    Now THAT'S ^^^^^^ a Killer idea!!! :cool:
    scotty t and saltflats like this.
  25. saltflats
    saltflats
    from Missouri
    Sure had a lot of fun in that car. Not sure I could get away with it now. Must be why I stick to the race car.
    Traffic has changed a lot form back then around here.
    scotty t likes this.
  26. seb fontana
    seb fontana
    from ct
  27. lothiandon1940
    lothiandon1940
  28. Budget36
    Budget36
    Always liked those Pontiacs with the hood tachs!
    lothiandon1940 likes this.
  29. lothiandon1940
    lothiandon1940
    On the column once again, this time in the '40. thumbnail (17).jpg thumbnail (16).jpg
  30. Budget36
    Budget36
    chevy57dude and lothiandon1940 like this.
