Technical Manifold discovery
Discussion in 'The Hokey Ass Message Board' started by Andy, Jun 25, 2022.
  1. Andy
    Andy
    I found someting unexpected in a manifold. I was cleaning it up prior to blasting it. I was feeling down in the carb holes. I found they were radiused on the bottom. Never saw that before. Then I found something else. The p***age to #2 and #3 was completely blocked! Mud dobber wasps had built a home way up in the p***age. I don't think the engine would run well that way. Further inspection found they had also blocked #5 as well. A lot of effort with a wire got them open. I will have to soak it to make sure everything is gone. fullsizeoutput_322a.jpeg P1050765.JPG
  2. lippy
    lippy
    from Ks
    That was the first cylinder de-activating system and mileage enhancing device. Courtesy of the Wasp's. :D
    Almostdone, Johnny Gee, SS327 and 3 others like this.
  3. guthriesmith
    guthriesmith
    Yep, those ******s get everywhere...
    C5974250-1C8E-41DC-BB75-61067E05D72E.jpeg B72608FC-F0A0-4FF8-A0AD-3B9BF0A11A32.jpeg
  4. Shouldn't store your good Chrysler race parts outside in the Garden (actually I think that's a Desoto manifold).
    Spooky and VANDENPLAS like this.
  5. Andy
    Andy
    KD 500 325 Dodge 1957
    The whole project is for sale if anyone needs a Hemi.
    I think the manifold sat in a barn for 50 years.
  6. Budget36
    Budget36
    Tman and VANDENPLAS like this.
  7. guthriesmith
    guthriesmith
    Those are actually from Texas where they do everything bigger. :D
    G-son, Bob Lowry, 325w and 3 others like this.
  8. I'm not that far from Kerrville and, yea, I got 'em too. They love my garage but they mostly build their adobe pueblos inside of storage boxes. If they were airplanes, my place would be an airport.
    A pest control guy told me that they leave a pheromone scent that encourages more activity, even a year later.
    chryslerfan55 and Tman like this.
  9. Rickybop
    Rickybop
    I can't think of anything much worse than that. Little bugs that want to put gritty dirt in your engine? Maybe that and mouse pee that encourages heavy rusting.
    I'll be looking real close at any engine I start for the first time.
    SS327 and chryslerfan55 like this.
  10. Andy
    Andy
    Kind on the same. theme. Went to a run and a guy had a brand new built engine in a car that would not start. Everyone tried all sorts of things. Nothing worked. Finally someone pulled the carb to check it out. Duck tape was found covering the manifold flange.
  11. Rickybop
    Rickybop
    So it's good to tape off all the orifices to keep the critters out.
    Just be sure to remove it. LOL
    KKrod likes this.
  12. belair
    belair
    My dad had an engine he was going to use sitting on the floor in his shop. Two months later it wouldn't turn over. Mice had filled up every cylinder with deer corn.
    Thor1, chryslerfan55 and tractorguy like this.
  13. 325w
    325w
    At a shop near here someone bolted the headers on a crate motor. Motor was fired and the red plastic plugs shot out.
    Tman, Dan Hay and Andy like this.
  14. Bob Lowry
    Bob Lowry
    Was it a mouse motor? If so, that may make sense...
  15. spanners
    spanners
    The dobbers get in my oxy cutting torch and spare welding nozzles.
    saltflats likes this.
  16. saltflats
    saltflats
    from Missouri
    They will pack the nozzle on a pressure washer. :mad:
  17. main-wire
    main-wire
    Hi Andy- Do you still have your 57 Dodge hemi for sale? When you say "whole project" are you talking about the engine only? Thanks, Wayne
  18. High test 63
    High test 63
    I had em pack the muzzle of a 30.06 Springfield rifle one day as it sat on the rack at a shooting match. Luckily i had a habit of checking the bore prior to loading.
  19. indyjps
    indyjps
    Yes, I blow them out of my eaves every fall, started following up with a light mix of ammonia and dish soap in the pressure sprayer wash bottle, getting less and less.
  20. pprather
    pprather
  21. Andy
    Andy
    The 325 is gone. I was going to put it in my roadster. There were more complications than just pulling the 241 and installing the 325. I have a 270 I am going to build now.
    Tman likes this.
  22. main-wire
    main-wire
    Tanks. 325s are getting hard to find.
  23. Rickybop
    Rickybop
    With this thread in mind, I dis***embled the 440 that's been sitting here for a while.
    Sure enough... Yuck.
    But intermittent liberal use of WD-40 warded off any damage.
    Tman likes this.
