Projects It's as bad as it looks
Discussion in 'Traditional Hot Rods' started by 1/2done, Dec 19, 2009.
  1. Jacksmith
    Jacksmith
    from Aridzona
    Wicked stance!
    1/2done likes this.
  2. 1/2done
    1/2done
    from Ohio
    I never would have thought it would be such a ****ing pain in the *** to put a Ford motor in my Ford. I had to switch to a rear sump oil pan and make an adapter for the trans mount. IMG_20200725_181710.jpg
    It's just sitting in there on a 2x4 and the trans mount right now, but the carb is dead level so I'll fab mounts for this position.
    It's low.
    Did I mention it's low?
    I hope to get motor mounts fabbed up tomorrow so I can get back to laying out floor bracing and body mounts.
    rbrewer, dana barlow, reagen and 11 others like this.
  3. nrgwizard
    nrgwizard
    from Minn. uSA
    Might be low, but it does look right.
    Marcus...
    OahuEli, chryslerfan55 and 1/2done like this.
  4. 1/2done
    1/2done
    from Ohio
    I got enough body mounts fabbed today to eliminate the post supporting the body, so I rolled it outside for a few pics.
    IMG_20200726_174550.jpg IMG_20200726_174508.jpg IMG_20200726_174536.jpg IMG_20200726_174528.jpg
    pila38, oil burner, Lil'Alb and 24 others like this.
  5. Six Ball
    Six Ball
    from Nevada
    Nice stance! It is really looking good. You have come so far. Can you turn the front wheels? They look so close in the pictures.
  6. 1/2done
    1/2done
    from Ohio
    The fenders are just sitting on there right now. I may need to m***age them a bit, I won't know for sure until I can bolt them on. Worst case scenario I have to radius them.
    chryslerfan55 and Six Ball like this.
  7. Jacksmith
    Jacksmith
    from Aridzona
    Do you need inner fenders? I have a set if you do. (they have holes for "fender well" headers)
  8. 57JoeFoMoPar
    57JoeFoMoPar
    I totally forgot all about this thread. That car is looking great man, you've done God's work. Keep it up
    1/2done likes this.
  9. 1/2done
    1/2done
    from Ohio
    After getting a trunk lid that hadn't been structurally compromised I found the rear quarter panels were nowhere near square to the frame. I started cutting and adjusting and finally said **** it. We raced in Daytona last week, so on the way back we came through Charlotte and I bought a pair of quarters from Dennis Carpenter.
    I started this build 10yrs ago, trying to fix or make everything because I was broke. That's not the case anymore.
    I'll get the front of the body and roof braced and get the old panels cut off and new tacked in and fit the trunk lid and lower panel.
    The 39 guy, Lil'Alb, dirt t and 20 others like this.
  10. lippy
    lippy
    from Ks
    I have not posted on this thread but have been checking in from time to time. I am a pretty accomplished bodyman and can fabricate when I need to and am a pretty patient guy with my projects. I commend you because every time you come across an obstacle, you say...Oh well, I'll just do this or that. Nothing stands in your way to accomplish your goal. I'm impressed. I can;t think of a higher compliment to pay a hotrodder. The car looks great. Stay on it and I can't wait to see it done. Lippy:cool:
  11. The 39 guy
    The 39 guy
    I Those new panels look beautiful! I sure could use those wheel wells on my current project. Will have to patch my originals though. Hope you show us how you install them.
  12. Six Ball
    Six Ball
    from Nevada
    That is some nice work. Fixing dents is beyond me. :(
  13. So glad this thread came back up. It shows how bad you want it and work hard you can have this. Keep up the great work.
  14. 1/2done
    1/2done
    from Ohio
    I don't have enough going on, may as well start gathering parts for a landspeed car
  15. Six Ball
    Six Ball
    from Nevada
    Is this one still going on?
  16. 1/2done
    1/2done
    from Ohio
    Sort of.
    A lot going on with other things at the moment. I did come to my senses and decide the flathead belongs in the Ford coupe, not the Willys sedan, so I'll be pulling the 302/top loader and installing the flathead/T5 setup. The 302/top loader will go in the Willys sometime in the future.
    I started the 1/4 replacement a couple months ago, not much happening lately. Current pic.
  17. Six Ball
    Six Ball
    from Nevada
    Thanks for the up date. All progress counts even if some of it is completely in your head.
    SS327 and neilswheels like this.
  18. neilswheels
    neilswheels
    from England
    good to see you're still on it. Sits great, keep going..
    57JoeFoMoPar likes this.
  19. spudshaft
    spudshaft
    Bump for hopefully an update
  20. 1/2done
    1/2done
    from Ohio
    Both 1/4s are chopped and tacked together, other than that nothing new.
    Life is in the way at the moment.
    reagen and Blue One like this.
  21. Six Ball
    Six Ball
    from Nevada
    We'll be here when you get to it. I can understand life's distractions large & small. It's not a project we really have much control over.
    1/2done likes this.
  22. 1/2done
    1/2done
    from Ohio
    Time for a long overdue update. The 1/4s are pretty much cut and spliced and tacked in. 20220627_214406.jpg 20220627_214353.jpg
    I found the filler panel below the rear window was short, besides being fubared so I bought all the inner structure pieces from Dennis Carpenter and cut the panel and located the hinges, the trunk lid now swings on hinges for the first time ever. I then started wheeling a replacement panel for the area between the trunk and window. 20220627_213922.jpg 20220625_222242.jpg
    Not setting and goals, just intended to keep plugging away till it moves under it's own power.
  23. Six Ball
    Six Ball
    from Nevada
    Someday this will all be covered by nice paint and 99% of the people who see it will not have a clue about what you have done here. I'll be a witness! Thanks!
    ffr1222k and chryslerfan55 like this.
  24. Lemme see now, I think I have everything, motor, check, transmission, check, rear end, check, axels, check, Washington blue paint, double check, enough time for a righteous burn out? ,oohhh yeah. Lol
  25. T.L.
    T.L.
    from Colorado
    It's good to see you're sticking with it...
    Bruce A Lyke likes this.
  26. SS327
    SS327
    Wow! I had forgotten all about this project. Man, you’ve come a long way baby! This thing is looking great. Keep up the good work.
    rbrewer likes this.
  27. Bruce A Lyke
    Bruce A Lyke
    slow but steady gets is done:cool:
  28. Jacksmith
    Jacksmith
    from Aridzona
    The only way to make that body style look good with a chop is via a subtle chop... you're nailin' it!
  29. snoop74
    snoop74
  30. dirt t
    dirt t
    In a word WOW!!!
