Technical Lee Pratt Nomad fender flares...?
Discussion in 'Traditional Customs' started by lucky, Jun 27, 2022.
  1. lucky
    lucky
    Does anyone here have the skinny on how he extended the fender lips on his Nomad? Newly formed sheet metal, or wire rod method? Ryan? Anyone?
    39custom, Dan Hay and Gasser 57 like this.
  2. Tim
    Tim
    from KCMO
  3. stanlow69
    stanlow69
  4. Ralphies54
    Ralphies54
    Bondo!! And maybe metal welded to fender lip first. It's a custom after all, buckets of bondo is ok .
    lucky likes this.
  5. lucky
    lucky
    They look a lot different up close than I thought they were.
    Seeing that close-up, you might be right @Ralphies54
    WalkerMD likes this.
  6. 55blacktie
    55blacktie
    If you must run wider wheels and tires, try different offset, or narrow the axle. I don't know how anyone, in good conscience, could do this to a 55-57 Nomad.
    Kelly Burns and rbrewer like this.
  7. lucky
    lucky
    Anyone can do anything they want with their own car
    Silva, egads, chopper99 and 8 others like this.
  8. I would.
    It’s just a car
    It’s just metal
    The next owner can do whatever they like
  9. stanlow69
    stanlow69
    It was originally built in the 60`s or 70`s. It was just another car back then. This is not a restoration forum.
    Silva, 1Shot-Scot, egads and 8 others like this.
  10. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Nomad I had, I bought as hawk meat. Sold it as a hot running junker for thrice the price.
  11. Tom davison
    Tom davison
    from Phoenix AZ
    I knew 50 years ago, not sure now, but I believe he framed the perimeter of the openings first with a metal strap, maybe a quarter inch by inch-and-a-half, that's what gives it that sharp, flat edge. Maybe quarter inch by two inch strap.
  12. gimpyshotrods
    gimpyshotrods
    The museums are full.
    Cut it.
  13. lucky
    lucky
    Thank you, Tom!
    guthriesmith likes this.
  14. chopolds
    chopolds
    from howell, nj
    Lee built a copy of his original Nomad he had back in the day. So this is a newer build. Seeing as Lee is a talented customizer and metal shaper, I'm sure it's done to a pretty high standard. Not a bondo bucket, as some Neanderthals claim.
    That said, I did a similar job on an OT car. Easy to do with a shrinker-stretcher, and hammer and dolly. Or with a hammerform. Very little filler needed!
  15. lucky
    lucky
    I believe he found the original midway through the rebuild. He did use the front sheet metal from the new build on the original car though. In short, this is mostly his original Nomad
    drdave, Sancho and guthriesmith like this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    anyone that thinks that it is blasphemy to modify or customize an old car is probably on the wrong forum, I would suggest they find a restorers forum to join. Around here cars are for having fun with , and not worrying so much about what they are worth
  17. Had a guy one time say “I’d like to do (fill in the blank modification) but my car is original and I don’t want to cut it”
    The car had the flaty replaced with a sbc, auto, dropped axle, open rear end and no fenders.
    So I guess, some time in the future, the owner thinks he might reinstall a flathead, stock axles/springs, fenders and mechanical brakes?
    A restored car isn’t original either. It’s just a custom built back to OE specs.
  18. El Pratt
    El Pratt
    Tom Davisons explanation is pretty close. Flat sheet metal, trimmed to fit was welded to the wheel opening then another piece was made with a 90 degree bend and a shrinker/stretcher used to conform to the wheel opening. The edge was trimmed to 1/4 inch and welded to the lower piece. The top half is welded to the body using the stock Chevy wheel well radius to transition the new flare to the fenders and quarters. hope this makes sense.
    lowrd, drdave, Silva and 14 others like this.
  19. lucky
    lucky
    It makes perfect sense, I really appreciate you taking time to answer! Gorgeous car
    Sancho, LOST ANGEL and gimpyshotrods like this.
