Projects Door panel insert...
Discussion in 'Traditional Hot Rods' started by 409deuce, Jun 28, 2022.
  1. 409deuce
    409deuce
    Stumped at the moment. Surround will be white pearl, insert is red metal flake pleat like the seat. I like the a-pillar angle on the left side. Not sure what to do on the right side in front of the seat. Different designs considered. Thoughts...
    ccain and dana barlow like this.
  2. lostone
    lostone
    from kansas
    I like the first pic. I like the way it flows with the seat myself.
    ccain, 409deuce and X-cpe like this.
  3. dwollam
    dwollam
    1st or 2nd in that order. The 3rd, not so much.
    Dave
    409deuce likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. ccain
    ccain
    ^^THIS^^
  6. dana barlow
    dana barlow
    from Miami Fla.
    My own ideas,about design,is design of anything should flow,so if a space is to be filled,I think every one likes it,when stuff matchs up. I often made drawings before,too get ideas. In the end,a design should fit in a hole,like a jigsaw part dose.
    As a way of explanning some.; Note that the black strips are all the same wide size,plus line up with the next panel,giving it a belongs that way look I think.
    https://www.jalopyjournal.com/forum/threads/tech-sew-at-home-upholsrety-hot-rod.604077/
    alanp561 and 409deuce like this.
  7. So apparently I'm going against the grain...I prefer #3.
    You might take your question and proposed options to the photoshop thread. Their work allows you to see pretty close to a finished product before any work begins.
  8. jimmy six
    jimmy six
    In roadsters and early coupes I prefer one you if can make some kind of pocket in. They are usually near the bottom with elastic. I saw one set I liked with a zipper.
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    To be sure we agree which one is # 2, the shape that is parallelogram, looks best in my crooked eye.
  10. Flathead Dave
    Flathead Dave
    from So. Cal.
    I would add a steering wheel.
    alanp561, 409deuce and theHIGHLANDER like this.
  11. GordonC
    GordonC
    I think pic number 3. Simple straight lines work well on hot rods. Curves and what not are more for customs in my mind. If I was going to do that with the colors you have I would make an inset panel and not carry it all the way up to the window edge.
    409deuce and dana barlow like this.
  12. theHIGHLANDER
    theHIGHLANDER
    There's 2 perspectives to consider, door open, door closed. 3 serves both. The window opening is the visual guide or feature. Can't see the seat angle when the door is open and 2 angles might look a little janky when it is opened. I'd also make the panel even with the window edges vs the molding edges, for very similar reasons. The molding is heavier at the back than at the front, the gl*** opening is visually consistent.
  13. 409deuce
    409deuce
    Thanks you guys, excellent input as always. Fyi its a 40 steering wheel in white with red grips.
    The more traditional pics i look at online i realize there is definitely a trend of square boxey shapes. Leaning towards not going up to the window as well now. Here's a couple pics doing just that. Im thinking the simple square now, there's a lot going on as it is.
    GordonC likes this.
  14. abe lugo
    abe lugo
    what if the seat or the seat angle changes later? obviously do what you like and is pleasing to your eye. Def add a pocket or a pocket on the kick panel ahead of it.
  15. GordonC
    GordonC
    I think either of the two shown above would work out well!
  16. theHIGHLANDER
    theHIGHLANDER
    I like the idea of the angle in the front. And I wasn't clear, I meant even spacing from the gl*** edge, as in if it's 4" from the front gl*** edge then 4" from the back too. Just pulling a number outta thin air. And if there's no white on the seat then going up to the molding works too. Adds color volume vs making it framed but still plays along with the rest. This is fun...
  17. 409deuce
    409deuce
    Couple more
  18. stanlow69
    stanlow69
    Just pick one. You are running out of masking tape.
    dmar836 likes this.
  19. Dedsoto
    Dedsoto
    from Australia
    I'd think the first option here but with the rear edge following the door contour instead of the seat.
    My 2c
  20. 409deuce
    409deuce
    Its the size of a volleyball lol.
    stanlow69 likes this.
  21. stanlow69
    stanlow69
    Your seat seems a bit low.
  22. 409deuce
    409deuce
    definately a compact bench bench. Sight lines worked out great fortunately
  23. 409deuce
    409deuce
    Right when stanlow69 had had enough of me i went and found these 60 pontiac stars-trim today. They're going on the door panel. Got full length plain bottoms trim too. Lets start over shall we?
    Dedsoto likes this.
  24. dmar836
    dmar836
    Hmm. Getting interesting. Paralysis by ****ysis is my jam!
  25. If the "inserts" are going to be pleated, the 90-degree, straight box style is the way to go. The width should be a multiple of any number of full pleats, no half or partial pleats. Maybe round corners with a radius of a full pleat.
    The slanted "inserts" slicing across pleats at an angle doesn't work for me. Curved or arched might work, but not slants.
  26. alanp561
    alanp561
    In post # 13, I'm in favor of the first one. The front of the door is angled, the seat back is angled. Looks right. The boxy shape is just that, boxy.
  27. 409deuce
    409deuce
    The prototype is in! Only one roll of masking tape and a 60' pontiac star-chief were harmed during production.
    GordonC likes this.
