stovebolt intakes
Discussion in 'The Hokey Ass Message Board' started by xderelict, Aug 10, 2007.
  1. HEATHEN
    HEATHEN
    from SIDNEY, NY
    A Nicson triple sidedraft setup for the 270H/302 head
    tractorguy and rtomss like this.
  2. willys36
    willys36
    Here is a 4bbl intake I designed and built for my 230 straight 6. I had to isolate the 3 Siamese ports with metal mesh embedded with hi-temp epoxy and brazing a metal strip on the front of the bolt bosses. The separate runners are equal length and it is a 180deg design with two separate ports. I carved the body from mahogany, then made a female cast of that in plaster. Then I lined the inside with 1/4" of clay and cast runner patterns in plaster. Finally I made fibergl*** molds of those castings. I made cope and drag boxes and a custom match plate to help the casting process.
    I had a little mini-foundry in Bakersfield who cast the manifold foe me using all my patters.
    Add a 390cfm Holley and it would climb a rope!
    manifold 1.JPG manifold 2.JPG manifold 3.jpg manifold 4.JPG manifold 5.JPG manifold 6.JPG manifold 7.JPG manifold 8.JPG manifold 9.JPG manifold 10.jpg manifold 11.jpg manifold 12.jpg pontiac_3..JPG
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Looks like a nice job. Does it work well?
    54delray likes this.
  4. willys36
    willys36
    Worked like a champ!
    54delray and LAROKE like this.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    A Clark Header intake, obviously cast from a Fenton mold.
    54delray and ebs121781 like this.
  6. jimmy six
    jimmy six
    They’re only good if you use them. 95B501C6-68DB-42E1-837D-9E2BA37BC433.jpeg 0FD33510-D48A-405B-B27F-D9D5430D382D.jpeg
  7. five-oh
    five-oh
    from Arkansas
    Here's the first piece of jewelry for the 261 that will find its way into my '52. I think this and the 261 are the beginning of a very expensive detour on Sam the '52's redo.....lol
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    235 port size?
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    An intake with no I.D. of any sort. It looks like it came from the same mold as the one shown in this thread several years ago with HOT ROD cast between the two carb risers.
  10. jimmy six
    jimmy six
    Fuel won’t boil out on this one..
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Oh, no, she's all business!
    54delray and Jlsandov321 like this.
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    A pair of Bumble Bee headers; basically a pair of Clark headers with a heat riser welded to the front header. Hot Rod magazine had a small test article about them in 1953.
    tractorguy and Jlsandov321 like this.
  13. 302GMC
    302GMC
    from Idaho
    Here's what I had in the ba*****t of our old house. Pic taken c. 1979.
    Several of these are in the hands of HAMBers today.
    54delray, Cosmo49, tractorguy and 2 others like this.
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Back when you could buy them for $5-$25.
    54delray, jimmy six and Jlsandov321 like this.
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    A stock 235 exhaust manifold, split and sold by Fenton, using a special second outlet that they cast for the purpose.
    Jlsandov321 likes this.
  16. ebs121781
    ebs121781
    from Spring, TX
    tractorguy, LAROKE and Old-Soul like this.
  17. HEATHEN
    HEATHEN
    from SIDNEY, NY
    $37.50? I'll take a dozen.
    ebs121781 likes this.
  18. ebs121781
    ebs121781
    from Spring, TX
    Anyone seen, have, or know anything about this one?
    Hop Up And Motorlife, March 1954
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    No, although I once had a Chiles triple intake.
  20. ebs121781
    ebs121781
    from Spring, TX
    Is it a unique design, or a re-badge sharing a common casting with another make?
  21. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It appeared to be its own casting. No provision for heat.
  22. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Here's another rare one. Again, no I.D. on it, but an article about hopping up Chevrolet and GMC sixes in a 1954 Car Craft magazine referred to it as a product of Wayne Manufacturing.
  23. jimmy six
    jimmy six
    ^^^ I’ve got one exactly like it in my stash, a GMC. Same linkage bosses cast in. No name on it either.. ^^^ that might be a Stomberg small base, not sure.
  24. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, it's a Stromberg Aeroquad.
  25. ebs121781
    ebs121781
    from Spring, TX
  26. ebs121781
    ebs121781
    from Spring, TX
    Either Clifford made one that looks similar, or one I've seen elsewhere was mis-identified. There was a similar one recently on eBay, looked very similar to the "Clifford" I saw on another site, but the one on eBay was listed as a Nicson.
  27. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I saw it. It looks like it was patterned after the one I've got and is pictured in the article, but Pat ****s was selling the GMC version in the '90s. No idea who cast it.
  28. HEATHEN
    HEATHEN
    from SIDNEY, NY
    No name McGurk 3 2bbl setup for 270H/302 GMC 20230203_200741.jpg 20230203_200900.jpg
    ebs121781, LAROKE, VANDENPLAS and 2 others like this.
  29. Cosmo49
    Cosmo49
  30. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I've got a Clifford 4 bbl. intake for GMC, and the port size is larger than the small port head, but smaller than the large port head. Is yours like that?
