Technical ***July 2022 - May You Be Lucky***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jul 1, 2022.
  1. Jiminy
    Jiminy
    Link to previous month: June 2022
    Coming Events: (PM Jiminy with additions/corrections)
    September 18 Auburn, CA NorCal F.A.S.T. Fall Hill Climb
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there maybe more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. Is this a month behind or have I missed something?
  3. 62pan
    62pan
    Looks like Jiminy's like June so much he decided to rerun it. Any way I'm checking in for July
  4. Troubadour85
    Troubadour85
    from Dayton, OH
    Checking in for the first time. Just got mine back on the road yesterday after redoing all the suspension, 40 brakes and sealing up the radiator and cleaning it up. First show tomorrow
    Rocket88NZ, Jet96, rwrj and 3 others like this.
  5. denis4x4
    denis4x4
    from Colorado
    Checking in
    winduptoy likes this.
  6. noboD
    noboD
    Happy 4th of JULY.
  7. winduptoy
    winduptoy
    Two Junes in 2022
    Now you know only on the Banger Board....
    Happy 4th
    Jet96 likes this.
  8. Jiminy
    Jiminy
    no June ****ed, just confused.
    Old Dawg likes this.
  9. Mainedrifter2
    Mainedrifter2
    Drove 46 miles today, my longest trip to date, before the temp spiked.
  10. Mainedrifter2
    Mainedrifter2
    Roadside attractions pop up for sale once the sun comes out
  11. raaf
    raaf
    Not a lot of progress in June...
    • Decided to go with standard '35 wires instead of Kelsey's because they don't need to be ground down in order to fit over cast iron rear hubs - but I need to find two more decent '35s
    • Found a T170 - being rebuilt at the moment
    Let's see how July goes...
    • So far so good - I received an email that my Burtz block is in the next batch!
    Wishing everyone a great 4th.
  12. Savage Coupe
    Savage Coupe
    from Washington
    More late night banger activities…
  13. Bearing Burner
    Bearing Burner
    from W. MA
    I know that this is largely a Ford A, B, T with an occasional Chevy 4. However I have a 32 Plymouth engine I would like to convert to insert bearings. Can anyone help? Rich Fox said he used Allis Chalmers
    bearings didn't remember which ones.
  14. Nothing flash or serious here, just knocked up a old style header using half a 35 drive shaft and modified a repo Riley updraft intake to a downdraft ,then made a baffle to calm it down a little, a couple of mods for September claypan racing out bush. 741FD1CB-8F99-4C60-9695-19DAE87E5D06.jpeg 54DD62CB-2CE4-4C09-BA40-5DFEE42596B9.jpeg CEBA4E7D-6497-4CB3-9D89-ED7214AC7D57.jpeg
    GuyW, edfueler, mctim64 and 7 others like this.
  15. I'm here! Under the old shade trees of ****onwillow Raceway!
    edfueler, mctim64, Jet96 and 4 others like this.
  16. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Mainedrifter2 and Jet96 like this.
  17. Dustyp489
    Dustyp489
    Checking in, Happy 4th of July to all
  18. Zax
    Zax
    Bought my first banger powered Model A Saturday. Just got it home from PA to Atlanta last night.
    GuyW, edfueler, Rocket88NZ and 12 others like this.
  19. hotrodA
    hotrodA
    Coming home from Montana I stopped in Lincoln, NE and the Museum of American Speed, aka. Speedy Bills, aka Speedway Motors.
    Things had definitely gotten better!
    It had been at least 20 years since my first visit and it was over whelming.
    One entire section devoted strictly to 4 bangers with every piece of speed equipment you could conjure up on who knows how many engines.
    Here's one of the Alexander's like mine, just 100X nicer.
    Here are a couple of unrestored survivor s****pers!
    If you've never been.....GO!
    GuyW, edfueler, mctim64 and 13 others like this.
  20. rwrj
    rwrj
    from SW Ga
    I'll check in. Been doing a good bit of driving in the speedster. The only real improvement I have made is installing a set of Flathead Ted's self-energizing brake doohickeys. I've only done the front brakes so far, but I also put on some cast iron drums up there. My old drums must have been pretty fresh, because I hardly had to touch the shoes to make them fit the new drums. The improvement is drastic. I'll get the back ones done soon.
    Oh yeah, I stuck that driver's side mirror on, too. Saves me craning my neck so much in traffic. Happy (late) 4th.
  21. Joebrownvw
    Joebrownvw
    Finally got mine running sweet! Another jet change, float level adjusted And lapped in my needle and seat took her out for a backroad blast and it cruises along super smooth now
    edfueler, Eisenmann, alanp561 and 8 others like this.
  22. brjnelson
    brjnelson
    1F6041CF-1A22-4D6A-BF1D-57DA6A6B8119.jpeg My car has been running poorly. Everywhere I looked I found a little something wrong but finally when I was goosing the throttle without air filter, I saw fuel spraying out of the carburetor at 1500rpm. That told me a compression test is in order and found two dead cylinders thank God it’s a bad head gasket instead of a bad valve.
    Get everything all ****oned up and now the car never wants to idle down it’s always idling fast. I cannot find any vacuum leaks, The air fuel ratio gage says I’m not lean.
  23. brjnelson
    brjnelson
    Jet96 and winduptoy like this.
  24. Send me PM
    Might be able to help
    J
  25. 282doorUK
    282doorUK
    A chap with a genuine '29 Ford racer turned up one evening at a meeting I was at with my Chevy racer. It is a banger with OVH and Winfield carbs, and tons more good stuff that you just don't see over here at all.
    Amazingly he offered me a blast around the field in it, what a beast, a real goose bumps moment!
    It felt like it just wanted to be flat out and sideways, didn't trust my rusty skills so only did one tame lap.
    I intended to crawl all over it in daylight and get all the info and pics the next day, but for some unknown reason he and it were up and gone early, so I missed out there. But one crossed off the bucket list for sure! :)
    This is the only pic I got..
    edfueler, alanp561, Old Dawg and 6 others like this.
  26. Gerald Sleater
    Gerald Sleater
    Been awhile since I posted, my coupe was totalled out last December due to a negligent driver who claimed they never saw me and t boned my car. Well, after 7 months and lots of blood sweat and tears it's all but done. I ended up building a new burtz block, stipe cam big intake valves dual stromberg 81's Rocket 428 head, 36 ford box. Modified ignition with a nurex kit. Car runs awesome, easily hit 60mph. 20220525_185945.jpg 20220615_202443.jpg
  27. Crazydaddyo
    Crazydaddyo
  28. V4F
    V4F
    from middle ca.
  29. Dustyp489
    Dustyp489
    Great coupe love the stands
  30. Steves46
    Steves46
    from Florida
    Just amazing! Thank you for sharing.
