Anglia Gassers
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Jul 26, 2012.
  1. 65pacecar
    65pacecar
    from KY, AZ
    congratulations, great find.
    cardealer likes this.
  2. Sky Six
    Sky Six
    from Arizona
  3. 65pacecar
    65pacecar
    from KY, AZ
  4. Magfiend
    Magfiend
    Mine is looking for a new home...although it is more like an altered...
    Stogy likes this.
  5. seadog
    seadog
    Quain Stott’s latest…
  6. 427 sleeper
    427 sleeper
    Is that Donovan's old car or is it a new build?
  7. seadog
    seadog
    I’m not sure. I’ve been away from the SEGA circuit for a couple of years, but I’d guess that it probably is the old car. Regardless, it’s a top notch build.
    427 sleeper likes this.
  8. 65pacecar
    65pacecar
    from KY, AZ
  9. 65pacecar
    65pacecar
    from KY, AZ
  10. 65pacecar
    65pacecar
    from KY, AZ
  11. 65pacecar
    65pacecar
    from KY, AZ
  12. 65pacecar
    65pacecar
    from KY, AZ
  13. Sky Six
    Sky Six
    from Arizona
  14. 65pacecar
    65pacecar
    from KY, AZ
  15. Speed Gems
    Speed Gems
  16. Sky Six
    Sky Six
    from Arizona
    I don't know, maybe someone here can help out.
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Tom Langton, Marv Wiegand, and a third person whose name escapes me.
    NHRA record holder and multi event winner with an inline six or four.
  18. Sky Six
    Sky Six
    from Arizona
  19. Sky Six
    Sky Six
    from Arizona
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    There is one aspect of the Anglia body design that I do not like.
    THE ROCKER PANELS
    Look closely at all the Anglias. At least all of the ones that kept the rocker panels under the doors. [Some builders eliminated the rocker panels completely.] The door has a raised sweeping character crease that ends midway along the lower edge. The rocker panel should have a corresponding crease to look right to me.
    Additionally, the front fender has a bead along the lower edge that ends halfway around the back of the fender.
    Very early Anglias had running boards. They bolted to the front fender and the rear fender and the rocker panel. They were eliminated, but the rocker panels were not revised to include a crease to match the door. Because the bead ends half way around the front fender it is common to find cracks where the bead ends. On SuperDave's '48 car we rebuilt the front fenders and rolled a bead around the bottom of the front fender.
    I will do that on the Attic Anglia, as well as adding a crease to the rocker panel to match the door. I did not do that to SD's '48 and its always bothered me.
    Dig the "One Holer" grill.
    Jalopy Joker and 1934coupe like this.
  21. 65pacecar
    65pacecar
    from KY, AZ
  22. 65pacecar
    65pacecar
    from KY, AZ
  23. 65pacecar
    65pacecar
    from KY, AZ
  24. E93a
    E93a
    Very good point about the beading round the front wings/ fenders. When I started looking at these cars in the late 60s most were rotted there and / or crudely filled with plastic filler and it took me a while to learn that the beading didn’t go right round.
    As regards the rocker panels I have seen several Rods built with the swage line added as you suggested. The black car is Model 7Y not an Anglia. These were built 37-39. The same one hole grille was unique to these and Thames /Fordson E04C panel vans.
    THE FRENCHTOWN FLYER likes this.
  25. 65pacecar
    65pacecar
    from KY, AZ
  26. 65pacecar
    65pacecar
    from KY, AZ
  27. dnegel231
    dnegel231
    This is not Donovan's car it's was one of the other guys called "Happy Daze".
  28. 65pacecar
    65pacecar
    from KY, AZ
  29. 65pacecar
    65pacecar
    from KY, AZ
  30. 65pacecar
    65pacecar
    from KY, AZ
