Technical Derusting panels
Discussion in 'The Hokey Ass Message Board' started by CadMad, Jun 22, 2022.
  1. CadMad
    CadMad
    44697572-205F-47D4-A56D-5BA4BF8525B1.jpeg Well I got a 25 kg bag of citric for $187 delivered. I wanted to do a test run so found a sturdy plastic tub. 5 cups of citric acid powder. And probably 5 gallons of water and chucked 50 odd salvaged bits that were heavily rusted 53 Eldo, in a car fire 40 years ago. The results in 24 hours are remarkable.
    I pulled them out for a quick look. The majority of heavy scale just wiped off. The remaining rust can soak for another day.
    reagen, Squablow, R A Wrench and 5 others like this.
  2. stanlow69
    stanlow69
    My wife will thank you for this.
    SS327 likes this.
  3. It's the cat's *** !!!!
  4. stanlow69
    stanlow69
    Without the smell if you use a bit of bleach.
    SS327 and wood remover like this.
  5. Citric acid.... I use that **** on everything!
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    You mean metal, right?
    reagen and '28phonebooth like this.
  7. milwscruffy
    milwscruffy
    I use citric acid myself also, does wonders and I'm done with it, IMG_0156.JPG I store it in empty plastic kitty litter containers and can cap it off and seal it until the next time I need it.
    reagen, Squablow and rod1 like this.
  8. Bugguts
    Bugguts
    Seat mounting brackets.
    Before & After.
    20220704_084832.jpg 20220704_084848.jpg Soaked a few days and rinsed with hose and soft brush.
    reagen and Squablow like this.
  9. CadMad
    CadMad
    I just thought I’d keep you abreast of progress. Got dash and conv bows and battery tray and anything that is rusty that will fit in a plastic drum. 7 cups in a 3/4 full drum. Less potent solution but it’s done a great job in two days. I just turned everything over in the barrel and only a wipe with a rag so far. 02CA2673-D297-42B2-8217-82F21EBECB9D.jpeg 5635D505-4459-4422-92C5-268377A79088.jpeg
    Squablow, SS327, Bugguts and 3 others like this.
  10. krazee
    krazee
    What grade are you using? Powdered BP seems to be more cost effective. Where do you purchase it from?
  11. beater40
    beater40
    Anhydrous citric acid, used by food and winery companies, I buy it from the local farm supply company. It lasts such a long time, I don't find any need to try anything else.
  12. R A Wrench
    R A Wrench
    from Denver, Co
    I have soaked a pair of very crusty hood hinges in vinegar and they came out clean, useable & loosened up. A friend has used an old crock pot with a heater on small parts, came out clean in little time.
  13. raaf
    raaf
    One warning about citric acid - depending on your mixture and duration it can be destructive at some level. Make sure your pieces are fully submerged or risk an etch line across your part where it is only partially submerged.
    And given enough time and density it will definitely go through paint.
    reagen and alanp561 like this.
  14. stanlow69
    stanlow69
    He`s right about the etch line. But that part was in my tank for 3 months. The water froze during the wintertime.
  15. Lone Star Mopar
    Lone Star Mopar
    Good info on the etch line.. Ive never had an issue but I'll keep that in mind on exterior body panels ect. Citric Acid has been my favorite method of cheap easy de rusting for years now. Did a tech on here a few years back, glad to see others using this stuff. That big ol vat of mol***es was a nasty mess. Once my brother turned me on to CA ive never looked back.
  16. SS327
    SS327
    I like a breast, but 2 are better!
  17. CadMad
    CadMad
    I understand about the possibility of the etch line having had a hood professionally stripped years ago with that result.
    In the fairly mild solution I have going presently (7 cups to close to 200 litres of water) and with twice daily rotation I haven’t found an issue. I guess if you left it for a considerable period there is a chance. I’ve got a third tank going now. Seat frames are immersed and soon I’ll be getting next doors high pressure washer to blast any residual off. 8FA61983-4635-4461-9A9B-98CD71862463.jpeg
    reagen and Lone Star Mopar like this.
  18. ronzmtrwrx
    ronzmtrwrx
    I keep a plastic air brake line with a weight on it on or near the bottom of my tank. Connected to My compressor via a small adjustable shutoff valve, with just enough air coming into the tank to keep everything churned up and moving around. Don’t know if it helps, but I’m sure it doesn’t hurt anything. :D
    reagen, '28phonebooth and Budget36 like this.
  19. Whoamel
    Whoamel
    from So Cal
    I've never heard of using citric acid until now. I'm definitely filing this away for future use..
  20. 34 5W Paul
    34 5W Paul
    from Fresno CA
    I turned a crusty rusty $100 long block into a rebuildable one using white vinegar but it's a stinky mess. Gonna have to give CA a try.
    Before looked totally wasted
    During was encouraging. Effective enough to ask if those were hone marks in the #3 cylinder. We will see what she looks like after a citric acid bath.
    SS327 and Lone Star Mopar like this.
  21. milwscruffy
    milwscruffy
    I got to thinking the other day ( I know dangerous...) I have an
    Eastwood 18 lb ********y Tumbler, wonder how citric acid would play out in it ?
  22. Ned Ludd
    Ned Ludd
    I'm reading this and glancing at the rusty '30-'31 firewall under the desk ...
  23. Budget36
    Budget36
    I think it’d work fine, but depending on what you put into it, it may wear into the tumbler.
    I recently used CA in a 2/2.5 gallon laundry soap bucket. I just stirred things up once a day.
    milwscruffy likes this.
  24. klleetrucking
    klleetrucking
    from Dalzell,SC
    I recommend caution soaking any high carbon steel such as seat springs for an extended length of time.
    When I've put any spring type metal in citric acid I can see a reaction (bubbles).
    It's not violent like an Alka Seltzer or anything but a reaction none the less.
    Some time back a guy posted he ruined a set of head liner bows by leaving them in the solution too long.
    How long was too long I don't know.
    milwscruffy and X38 like this.
  25. milwscruffy
    milwscruffy
    It'll be small parts and the body of the tumbler is plastic/nylon so the only thing that might happened to it is it may get stained by the residue which is no big deal.
