Customs New project: 56 Olds!
Discussion in 'The Hokey Ass Message Board' started by chopolds, Nov 10, 2018.
  1. pprather
    pprather
  2. chopolds
    chopolds
    from howell, nj
    Not so much! I've got engine parts ordered for months now, that are delaying building the engine (can't get cam cores, Edelbrock not filling orders).Did a lot of welding to finish up the exhaust, and now working on 'sectioning' the rear bumper overrider, so the tailgate can open completely. Been busy building other guys cars, in the meantime!
    chryslerfan55, Stogy, brEad and 6 others like this.
  3. Tony Ray
    Tony Ray
    Damn now I feel guilty!!
    Stogy likes this.
  4. engine138
    engine138
    from Commack NY
    Sweet good luck with that Oldsmomad
    Stogy likes this.
  5. pprather
    pprather
    @chopolds , any progress to report?
    Thanks.
    Stogy and loudbang like this.
  6. chopolds
    chopolds
    from howell, nj
    My next step is building the engine. I order a cam and lifter in march, and just got them a couple weeks ago! Meanwhile, 455 block bored 0.030, new pistons, rings and bearings are here. Now waiting on the crank. Out being polished, or cut, whatever it needs. Once the engine is painted and installed, I can ***emble the front sheet metal and continue. Meanwhile, building other guys' cars!
    chryslerfan55, Stogy, Sancho and 5 others like this.
  7. Peanut 1959
    Peanut 1959
    Thanks for the update!
  8. chopolds
    chopolds
    from howell, nj
    Since the Olds never made a wagon in 56, there were a lot of modifications to do to get things to work right. A small matter, was that the tailgate, when opened, would hit the license plate guard on the back bumper. I couldn't eliminate it, as the bumper was formed around it, so I had to "section" it to make it shorter. Not easy for an angled part. Not easy, as it had to be chrome plated afterwards, so the metalwork had to be pretty good. I cut and welded it, and had to add a 2 inch piece to the center of the guard, due to the angled top not reaching the widened bottom. I TIGed it together, but then had to use lead to finish off the welds, and fill the low areas.
    It's not quite perfect, as it's difficult to work with hot lead, but my plater will now copper plate it, and I can add more solder, without affecting my previous work, to perfect it. 100_2458.JPG 100_2459.JPG 100_2460.JPG 100_2722.JPG 100_2718.JPG 100_2608.JPG 100_2606.JPG
  9. brEad
    brEad
    Nicely done sectioning the license plate surround!
    OG lil E, loudbang and Stogy like this.
  10. chrisp
    chrisp
    I always heard to not use lead on a part that needs to be chrome plated but silver brazing instead, which is what I always used. Any input on this?
  11. pprather
    pprather
    I read the engine for the Olds is nearing completion.
  12. chopolds
    chopolds
    from howell, nj
    Forgot to update! Engine is ***embled, painted, and installed. Now getting all the necessary things bolted to it, to get it running. Have to do surgery on the rad support, to fit the new ch***is, inner wheel wells, too. But so far, so good. Since I got the car completely dis***embled, I had to do a lot of trial and error, as well as soliciting advice on what parts go where (as well as a bunch of my 53 Lincoln's parts mixed up with it). Sheet metal, and also various brackets and pulleys from 2 different engines, maybe complete, maybe not!
    Finished up a 66 Skylark Kustom for a friend, as well as working on Tony Ray's 51 Ford (he has a build thread here, too) 100_0012.JPG 100_0034.JPG 100_0047.JPG 100_0048.JPG 100_0069.JPG
    40two, drdave, chryslerfan55 and 17 others like this.
  13. Saturn V
    Saturn V
    from Killen AL
    Awesome build!! Olds should have built a version of the Nomad and Safari!!
    loudbang and scotts52 like this.
  14. chopolds
    chopolds
    from howell, nj
    Lots of non-traditional stuff going on to get the car reliable and running. Hope it doesn't "offend" anyone!
    Modified the front wheel wells, and radiator support to fit the different suspension, and be able to run a 4 core alum. radiator, to cool the big 455. Painted the front end inner sheet metal, but have to go over the undercoating. I bought a gallon of cheaper stuff, and it split and peeled on me. Upol Bedliner going on after I knock off the bad stuff.
    Semi-Frenched the headlights. Since I'm going for more of a "concept car" vibe, instead of Kustom, I wanted to keep the stock bezels, but the Kustom guy in me wanted to change them, too. So, I compromised. I cut off the outer part of the bezel, just using the inner, and extended the fender to meet the cut down bezel.
    Also been getting stuff back from the platers..front and rear bumper from Tri-City Plating, and pot metal and brackets, pulleys, from Super Chrome in NJ. 100_0048.JPG 100_0053.JPG 100_0073.JPG 100_0069.JPG 100_0075.JPG 100_0084.JPG 100_0080.JPG 100_0081.JPG
    BigRRR, SS327, 40two and 19 others like this.
  15. K13
    K13
    Thanks for the update Mark. Looking really good.
    OG lil E and loudbang like this.
  16. Rickybop
    Rickybop
    X2! So cool.
    And great compliment.
    But actually understandable why no one's done it before. Look at all that work... vision... commitment. It's gonna be sumpin'.
    belair, loudbang and OG lil E like this.
  17. Rand Man
    Rand Man
    Such an amazing amount of work. Well done.
  18. pprather
    pprather
    Hoping for an update. Love this build.
    SS327 likes this.
  19. Tony Ray
    Tony Ray
    This thing is awesome in person! There is a lot more done but some idiot brought a shoebox to him and he been spending a lot of time on that..
    40two, brEad and pprather like this.
  20. chopolds
    chopolds
    from howell, nj
    As we all know, customer projects usually have priority over personal ones! Besides getting the engine just about ready to fire, I got the dash body worked painted, and buffed. Started ***embling it (also made AC duct pods in the dash). Bought a new windshield at Carlisle, went to cut it, and broke it. Made a fan shroud, as the fan extended below the radiator by a couple inches. Hoping to start it soon, and find another windshield, maybe a good original one. The new ones are thinner! 100_0250.JPG 100_0262.JPG 100_0280.JPG 100_0281.JPG
  21. pprather
    pprather
    Good progress.
  22. chopolds
    chopolds
    from howell, nj
    New Year's progress report. Almost nothing new!:(:(:(
    Still searching for a good 'old' windshield, and finally got out all the bracket/pulley/fan/shroud issues figured out, so it's ready to fire the new engine. Haven't been loafing, though, I did get Tony Ray's 51 shoebox finished (for now), and running and driving. He'll be back in fall for paint.
    Also finished the bodywork on the rusty 57 Olds I've been patching up, got the Candy Apple red stripe painted, and then shot the back half in Caddy Diamond White pearl, with extra gold pearl mixed in. Then the Holidays, and a sinus infection halted all work in the shop! Hoping 2023 will work out better for building the Olds-Mad. I do have an upholstery guy lined up, and materials 100_0513.JPG 318180653_1345948056215536_4903255200319310621_n.jpg Tony_sidetrim.jpg chosen, and bought.
  23. chopolds
    chopolds
    from howell, nj
    Mid year progress report! Engine is running, and broken in, no issues! Brake system also up and running, should move on it's own now. The biggest problem I've had since, is the windshield. I bought a brand new one at Carlisle, from Auto City Gl***. right before the next Carlisle event, the guys decided I should try to cut it, just in case it broke, I could buy another one! Lots of faith in me!
    Well, I did break it. It's the second brand new one I've tried to cut, and broke. With the old original windshields, I've got a much better track record, around 4 out of 5 not broken.
    So I've been searching for an original gl***, and finally found one in a junkyard in Philly. Paid WAYYYY too much for it, and it has a star crack right in the driver's view. But, I brought it home.
    After trying all winter to buy bags of dry sand, to blast it, I finally just went to Tractor Supply and bought some Black Diamond. Since I'm blasting outside, it's hard to try and recycle it, so lots of wasted money. But it did the job!
    Did more little things, like building a coolant overflow tank, making new doors for the fresh air vents, as I removed the factory housings to put the break booster on the firewall. Lots of little stuff, but I foresee driving it by the end of the year!
    Next hurdle is to try and get the Nomad seat to work in the Olds body. The rear end kick up is around 4 inches higher in the Olds, so the seat has to fold down, but raise up 4 inches to match the cargo floor, and rear kick up. I'm guessing custom hinges are in the future! Oh, and I'm working with a bunch of rotten wood, and rusty metal, that call themselves "a seat". 100_0593.JPG 100_0595.JPG 100_0656.JPG 100_0658.JPG 100_0594.JPG 100_0592.JPG 100_0597.JPG
    Nominal, 40two, Tony Ray and 9 others like this.
  24. pprather
    pprather
    As a former Nomad owner, I've been following with interest this unique build.
  25. brEad
    brEad
    Nice work on that overflow tank!
    patsurf likes this.
  26. chopolds
    chopolds
    from howell, nj
    Been a while, but I'm pretty slow! Did finish bodywork on a nice 55 Chevy, HOK Orion Silver and Candy Apply Red on the roof. As well as some other work, including helping put Kenny's 54 Plymouth on newly fabricated ch***is with C4 Vette suspension.
    As for the Olds-Mad, serious surface rust inside the roof made me remove the roof support rails, (millions of spot welds!!!!!), repair the rot, sand, abrade, and acid scrub the rust, and put it all together again. I also stripped the interior sheet metal to bare, and epoxy and Zolatoned it. Next, I wan to try to fit up the gl*** in the quarters, but seems the curved gl*** gaskets are unavailable, for the time being. Guy who made them supposedly went out of business during CoVid. But I keep looking! 100_0703.JPG 100_0715.JPG 100_0719.JPG 100_0720.JPG 100_0996.JPG 100_0994.JPG 100_1003.JPG
  27. chopolds
    chopolds
    from howell, nj
    Still on it, still looking for a front windshield. Spent almost 3 weeks straightening and polishing the '98' side trim, and some of the Nomad side gl*** trim. When going to install the trim above the doors, they came up too short. SO luckily, I had a few extra pieces of Nomad trim, and I cut one up to extend the stainless rain gutter covers. Now I have to figure out how to do the roof rail seal, as they aren't being made any more, and I only have one!
    Also found rot under the factory lead seam, so off it went, and replaced with some steel. 100_1044b.JPG 100_1047b.JPG 100_1050b.JPG 100_1076.JPG 100_1078b.JPG 100_1079b.JPG 100_1084b.JPG
    brEad, SS327, Sancho and 8 others like this.
  28. pprather
    pprather
    Nice steady progress!
  29. chopolds
    chopolds
    from howell, nj
    Now we're getting somewhere! Played around with one of the curved quarter windows, cut it down, tried to find the correct gasket for it, but none available. So I found a replacement that is pretty close, it just doesn't have the front side correct for installing the stainless trim, and sealing the sliding window. But it fits, and it's (temporarily) in!!!!!
    SO, getting more confidence, I went to Carlisle, and bought a new front windshield. Up from $300, 2 years ago, to $450. Making me even more nervous to try and cut it. Well, after taking a couple weeks to get up my courage, I did it! After tweaking it, with a belt sander for a few days, it looks like it will work.
    So, also installed the hood, and found that it needs some reworking on the front lip to match the grill/bumper. Some from previous repairs, some from just factory mismatching.
    Got on the upholstery guy's *** to at least get me my front seat done, so I can take it for a ride! I had to make molds off of the old seat skirts (cheap-o plastic) and make stronger fibergl*** ones. 400.JPG 402.JPG 416.JPG 412.JPG 413.JPG 415.JPG
  30. chopolds
    chopolds
    from howell, nj
    Power washed it and rolled it outside. I even got to DRIVE it back inside the shop! 397.JPG
