Projects Another Deuce Rdstr project.
Discussion in 'Traditional Hot Rods' started by Baron, Feb 5, 2019.
  1. jimmysweden
    jimmysweden
    from sweden
  2. Baron
    Baron
    Thank you. I cut the flange down on the F100 box and re-drilled the three mounting holes. I've done that a a few of my Deuces in the last 20+ years. The sector shaft is located in the original hole in the frame. I don't have that measurement right now, but can get it for you. I can also take a picture of my extra steering box. In the meantime, this frame diagram may help.
    rod1 likes this.
  3. FORD FAN
    FORD FAN
  4. FORD FAN
    FORD FAN
    Thanks, Baron. I could use that measurement. Don't know why I'm even worried about having the exact location as I'm limited by my header clearance anyway. Did you shim the flange out to get the box in proper orientation?
    Baron likes this.
  5. Baron
    Baron
    5" from the center of the sector to the center of the first firewall bolt. Here is a picture of my spare box.
    rod1 likes this.
  6. FORD FAN
    FORD FAN
    Thanks again ,Baron. I'll try shimming the box out with washers or a spacers first, then as a last resort , weld on a fabricated flange at an angle to fit the deuce frame angle
    Baron likes this.
  7. The ideaman
    The ideaman
    I like it with the Halibrands. How about a video of it running. I bet it sounds great.
    Baron likes this.
  8. NoSurf
    NoSurf
    Beautiful hotrod.
    Baron likes this.
  9. Baron
    Baron
    Sart156, shortypu, V8-m and 7 others like this.
  10. DDDenny
    Oh man, that looks like black cherry in that light!
    Love it!
    Baron likes this.
  11. dln1949
    dln1949
    Baron, it just gets better looking the more you drive it.
    Andy and Baron like this.
  12. Baron
    Baron
    Thanks !
  13. Baron
    Baron
  14. Baron
    Baron
    My wife and me out cruising in the Rdstr this last summer. My Deuce Rdstr , 2022.jpg
    V8-m, KKrod, Just Gary and 14 others like this.
  15. Atwater Mike
    Atwater Mike
    I wouldn't change a thing! Roadster perfection.
    Baron likes this.
  16. NJ Don
    NJ Don
    +1, Beautiful!
    Baron likes this.
  17. Baron
    Baron
    brEad, alchemy, NoSurf and 10 others like this.
