Technical 1960 Ford Falcon Wagon
Discussion in 'Traditional Hot Rods' started by Jason Bell, Jul 13, 2022.
  1. Jason Bell
    Jason Bell
    from Forney TX
    Hey All,
    Hoping to get some confirmation before I proceed. I have a stock 1960 Ford Falcon Wagon with 4-lug setup. Does have the Maverick 8" rear end. Looking to put a 15x7 Wheel with a 195 55 15 tire. Maybe a 205 55 15 on the rear. Or maybe a 60 series. The wheels are a Legendary HB 44 wheel from Eckler/CJ Pony. Will this fit??
  2. gimpyshotrods
    gimpyshotrods
    Probably not.
    The outer wheel houses on the early Falcons "pinch" toward the center as they go up.
    On my 1960 Falcon sedan I run 195/60-15's on 15 x 7" wheels, with 4-1/2" backspacing. The only way that I was able to do this was to build mini-tubs for the outers, and push them to the outer quarter skin. They would not fit otherwise. I am also running reduced sized front wheel arches on the rear.
    I have a Ranger 8.8, that is 56-1/2" wide, with the drums, but run SVT Cobra discs, so it is a little wider, as the hats are thicker than the drums. The axle is the same width as the 4-lug Maverick.
    The stock axle on the Falcon is 56" wide.
    The wheels that you have selected have 4-1/4" backspacing. Given my rotor hats, this would put your wheels, and my wheels in about the same place.
    Budget36 likes this.
  3. Jason Bell
    Jason Bell
    from Forney TX
    Thanks. Great info. Seems like I get information that it most likely won't then I hear yes.
  4. gimpyshotrods
    gimpyshotrods
    Here's a detail shot of the "pinch" in the stock outer wheel house. IMG_20171124_153021.jpg IMG_20171124_153006.jpg
    The outer mini-tubs that I made are fairly simple.
    In the inside picture, the quarter panel still had the stock wheel opening.
  5. Jason Bell
    Jason Bell
    from Forney TX
    Looks Good. Guess if i have to open it up no worries. I am a Fabricator so not a big deal. Was only hoping to not have to make an major modifications. Guess i will know next week when i get the wheels and tires. Thanks for the information again
  6. Jason Bell
    Jason Bell
    from Forney TX
    Morning Sir,
    Thought you may be curious on the wheel fitment. Other than rolling the wheel well lip I got good clearance. If I really push the car extremely hard on right hand turns I get a real slight rub. That I think I can also fix.
  7. sbf001
    sbf001
    from New York
    I run a 225/45/17 square set up on my 1960 falcon wagon. Rear ford maverick rearend, SN95 rear disc with 1/2 in spacer. Front SVT cobra 13in brake upgrade with 1in spacer. The rear fender lip was rolled, no other modifications to the wheel tub.
  8. gimpyshotrods
    gimpyshotrods
    My sedan is about 3-inches lower than that, so that helps you out. I cannot go lower without getting a fix-it ticket, and/or getting stuck getting out of the driveway.
    If you pull the wheels, you should be able to to spot where they rub.
    A bossing mallet, or a rubber hammer should be enough to move the metal away. It's not that thick.
    You might need to repeat this a couple of times to make certain.
  9. Jason Bell
    Jason Bell
    from Forney TX
    If I was lowered 3" the car would not go many places. Pictures may not show it but the car is lowered and sits pretty low. Has a great stance. The rub was just a big glob of undercoating.
  10. gimpyshotrods
    gimpyshotrods
    I made the middle of my exhaust system out of 14ga, and have a small skidplate on my T56.
    I just drag it.
