Hot Rods I'm mad at my 34!
Discussion in 'The Hokey Ass Message Board' started by Rocky, Jul 15, 2022.
  1. Rocky
    Rocky
    Classified Editor
    I've been thinking I might make a run from Omaha to the west coast to visit family. I'd planned to drive my coupe out there because I'd driven it to Joplin for the HAMB drags a few times with no problems. Checked fluid levels and the plan was to do an "exploratory" run 150 miles west to Grand Island, Nebraska just to make sure everything was ok with the car.
    Every since I put the motor [Pontiac 370 cu in] together the rope rear main seal has dripped a little but not enough to worry about. I was planning to put my highway gears in the quick change but got lazy....left the 3.54s in and set off for Grand Island. At highway speeds the engine was buzzing more than I was comfortable with [3300-3500 rpm] but what the hell.
    Everything went pretty good until I pulled into a gas station at G.I. for some $4.70 fuel. I could hear the rear gear a little louder than I liked and at idle the oil pressure was lower than usual. I fired it back up and came home. I noticed the exhaust would puff a little smoke on deceleration ........ that's new.
    I made it home ok and the next day I checked the oil to see it was ok, in fact it was over full. Hmmmm....the engine is MAKING it's own oil??? Welp, I've been through this before with an old ford pickup I once owned. I have a hole in the mechanical fuel pump's diaphram! Pumping raw fuel into the crankcase! I sniffed the dipstick and the oil fill to confirm my su****ions. Smelled like gasoline. I was pissed and parked the car in the garage for almost 2 weeks without even looking at it.
    Today I actually decided to work off my 9 point list of **** to fix and number 1 was jack the beast up. Number 2 was drain engine oil, trans oil and drain rear axle. I got the engine oil drained to find the genuine plastic washer under my drain plug has a crack in it. I'm sure I'll find other stuff wrong too.
    As I think about it I shouldn't be mad at all....the car got me 300 miles of fun and was able to get me home. Tomorrow is another day. 34onstands2.jpg 34onstandsoil.jpg
  2. swifty
    swifty
    Better to find the problems on your exploratory run than on your big one. That's why you did it -right ? Now get stuck into that list and knock them all off. Then take that Ponty powered coupe on the big run.
    210superair, Tim, brady1929 and 2 others like this.
  3. chevy57dude
    chevy57dude
    No tow truck, hopefully no damage and you know what's wrong. You got off light.
    Fingers crossed that your rod & main bearings are ok.
  4. choptop40
    choptop40
    sometimes they own you ..../
  5. lothiandon1940
    lothiandon1940
    That could have been a whole lot worse. Thank your lucky stars, Rocky, and safe travels when you get things sorted and head West again.
  6. flamedabone
    flamedabone
    Damn old cars, I hate 'em....
    -Abone.
  7. Sounds like your '34 is mad at YOU!!
  8. alchemy
    alchemy
    My sedan has oil spots like that underneath every place I park it. And my drain plug gasket is actually not one of them.
  9. Dan Hay
    Dan Hay
    I got the engine oil leaks fixed with a new pan gasket and rear main seal, but the 39 trans leaks like a sieve from multiple places.
    Also, not questioning you but, 3500 rpm sounds pretty high for 3.54 gears. Are your rear tires really small? Or were you running 85-90 mph?
  10. Tim
    Tim
    from KCMO
    @Dan Hay I wouldn’t put it past him! Those Omaha hot rodders got a foot so heavy they sound like a pirate walking across the room. (Think one foot and one loud peg leg ;) )
    It’s frustrating when your find the gremlins run is fruitful, at least your legs won’t go up the wall when you lay down under the car to wrench in that garage mahal of yours :)
    no hill for a stepper like @porkn****** tells me ;)
  11. Bad Bob
    Bad Bob
    from O.C. Baby
    I think the Coupes mad at you!!! haha
  12. 2935ford
    2935ford
    That's it....get rid of it!
    Just give me a call and I'll remove that pestering thing! :(
    Hey, this is what these old jalopies do. Mostly just for fun and to keep you on your toes.
  13. Mr48chev
    Pontiac engines don't have oil leaks, they mark territory.
    In real news, if that car has a 28 inch tall tire he was cruising along at about 82 mph and if had a 27 inch tire he was doing 79. http://www.advanced-ev.com/Calculators/TireSize/
  14. 1971BB427
    1971BB427
    from Oregon
    Sounds like your plan to do some test runs was a great plan, and it didn't leave you stranded either. So really a success, although not the results you hoped for. But not a total loss, and sounds like it wont be an expensive or time consuming fix either.
    Thor1 and chevy57dude like this.
  15. blowby
    blowby
    from Nicasio Ca
    Be mad at $4.70 ethanol.
  16. Tim
    Tim
    from KCMO
    sounds about right. Most of the interstate over there is 75-80mph
  17. Hey, I found regular down to $5.75 yesterday. Happy days.
    blowby and seb fontana like this.
  18. HOTRODPRIMER
    HOTRODPRIMER
    Rocky, your coupe is like my old 1956 Harley, if there is no oil on the ground there is no oil in the engine/transmission. :D HRP
  19. guthriesmith
    guthriesmith
    Old cars ****! But, they sure are fun too!
    Thor1, chevy57dude and Tim like this.
  20. Tickety Boo
    Tickety Boo
    from Wisconsin
    Borrow some big tall tires from a buddy to make your big run ;)
  21. killbilly
    killbilly
    Jeff, I saw your sedan marking its territory at Des Moines....
    alchemy likes this.
  22. Tim
    Tim
    from KCMO
    that’s what the quick change is for ;)
  23. 210superair
    210superair
    from Michigan
    Man those drips are noting compared to my garage soot under the flathead. Been drippijg for years! Lol.
    guthriesmith likes this.
  24. Budget36
    Budget36
    Ya know what’s funny, I had a 221 FH Ford, never leaked a drop on the cement. Bought an engine in a ch***is, pulled the engine out it and put it in my ‘42 PU. Had it for 5 or 6 years before sending it down the road, but never had signs of an oil leak. Whoever put that engine together did it right.
    Desoto291Hemi and 210superair like this.
  25. guthriesmith
    guthriesmith
    That’s kinda what I was thinking. I would be pretty embarr***ed to show how much oil and oil dry is where I park my car.
    Thor1, Tim and 210superair like this.
  26. COCONUTS
    COCONUTS
    A oil leak is the best way to keep clean oil in the engine.
    slim38 and firstinsteele like this.
  27. alchemy
    alchemy
    I park over a full sheet of plywood in my garage, and even that doesn't catch every spot.
    rod1 and guthriesmith like this.
  28. 38Chevy454
    38Chevy454
    Cardboard under my old cars to soak up the drips.
    I think the test was successful. Although it creates a lot of work. Better to fix in your garage than on the road.
    slim38 and Tim like this.
  29. I worked in a gas station in 1963. A guy came in every day in a '54 Chevy to get a buck worth of gas and a quart of reclaimed oil. Had a pretty good leak. His oil always looked brand new. Never needed to change it.
    Desoto291Hemi likes this.
